Question about KitchenAid Kitchen Ranges
How do I reset on a F2 ?
Tried to clean oven on self clean, it never happened, got a F2 message
    Sergeant:
    Scholar:
  • 96 Answers
Going through all the comments mentioned above it seems that all of you have the same problem. Your appliance Control board is not working. Either try finding a new board or get it repaired.
To find a new replacement part/ part repair service. I would suggest www.partsimple.com part prices low compare to other competitors as well fast shipping.
TV parts Water Filter Washer parts Laptop Parts Replacement Parts...
Posted on Apr 24, 2015
    Prodigy:
    An expert who has answered 500 questions.
  • KitchenAid Expert
  • 644 Answers
Does it just say "F2", or "F2 E1" or "F2 E6" or some other "F2 - Ex" error code? On KitchenAid wall ovens, I would frequently encounter an F2-E6 error, and when you would press the Bake key, it would beep out a "morse-code" message (beep beeeeeeep beep beep beep). And in that case, you would have to replace the electronic oven control.
Posted on Nov 27, 2014
SOURCE: self clean light blinks when you turn oven on (oven does not work)
I had this same problem with mine (still posted under unsolved) This is the simpler model with the old turn style knob and the lever you slide over to lock the door for cleaning What I think (keep in mind I know little about ovens, more about cars) is that the switch that tells the oven the door is latched is staying engaged, and this is part of the lever mechanism. I cleaned and lubed this mechanism (obviously I would guess you want to use a food safe lubricant) and then moved the lever several times with the oven on so I could see if it turned on. After a few tries the cleaning light went off and the oven light came on. No, its not really a technical answer, all indications to me where that the problem was in the switch which is part of the latch mechanism. Good luck
Posted on Dec 25, 2006
  • 213 Answers
SOURCE: Need to clean oven GE true temp self clean
the oven temp sensor is bad. replace temp sensor to solve problem
Posted on Nov 19, 2007
SOURCE: GE true temp oven f2
This happens every time I clean my oven. It overheats, shows the f2 light and BEEPS loudly. The only way to stop it is to turn the oven off at the breaker box, wait until it cools (usually 2-3 hours), flip the breaker back on and start the process all over again until the unit is clean. If it's not to dirty, sometimes it's easier to juat use Easy Off.
hope it helped
Posted on Jan 09, 2009
  • 22 Answers
SOURCE: Self Cleaning light comes on and flashes when you turn on oven!
It sounds like you have a defective Oven control module. (TO8 Control) is the part that controls all oven functions including clean,clock,timed bake, ect. Item is easy to replace yourself.
Posted on Mar 30, 2009
SOURCE: Ran Self Cleaning - Display went blank & Oven Door stayed locked
You need thermostat limiter #8300802. It is on the back of the stove behind some sheet metal towards the top. With shipping this part is about $39.00. But don't waste your money. If you replace it, it will burn out again! I am currently trying to find a way for either a class action lawsuit or a total recall. Kitchenaid/Whirpool is well aware of this problem. A $1500.00 stove and it won't self clean.
Posted on Apr 07, 2009
Tried to do self cleaning on oven, about 10 minutes in got "f2 locked door" and it won't clean. what is that all about?
Error code F2 on clean cycle is indicating that the maximum permissable cleaning temperature has been exceeded. (or it's got too hot!)
However it seems unlikely that that would happen in just 10 mins. more likely it is a problem with the oven temperature sensor which should be checked over as should the lock switches..
Dec 14, 2010 | GE JRP24 Electric Double Oven
I was doing a self-cleaning of my Kenmore oven. I tried to open the oven by moving the lever to the left, and it would not budge. Then I started getting a warning beeping and an F2 message. How can I get...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 06, 2010 | Kenmore Ovens
Self-cleaning oven F2 error message
Well I found three all same series... If it's occasional I'd leave it 'till was always on? Anyway .....
F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC)
OR....
F2 Oven temperature sensor shorted Replace oven temperature sensor
OR
F2 Temperature runaway detected (Bake/Broil: 600 - 700 F; Clean: 930 - 1000 degrees F). Sounds alarm and resets to non-cook mode. Check relay board for stuck contacts. Check oven temperature sensor for normal room temperature resistance (1085-1097 ohms at 75 degrees F). Check sensor wiring connectors for a loose or high resistance connection. Check electronic range control (also called clock or ERC) functions Replace relay board if necessary. Replace oven temperature sensor if other components check normal. If failure repeats, replace electronic range control (also called clock or ERC)
Feb 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
F2 appeared on the screen during self-cleaning
F2-During BAKE
Control senses oven temperature above 615F-630F
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
F2-During CLEAN
Control senses oven temperature above 915F-930F
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Apr 16, 2009 | GE Profile Spectra JBP95 Electric Kitchen...
Self-clean turns off after 5 minutes with F2 error message
Hi MaryB,
F2 error code means that the oven temperature is too hot. You will have to replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Apr 15, 2009 | Thermador C272 Electric Double Oven
F2 message when self cleaning
I have the exact problem, had a service man look at it while still under warranty. He said it was fixed and left. Tried it again, same problem. Called him back 2 times after that, he quit responding to my calls. By tyhen warranty expired and GE refused to do anything.
Nov 07, 2007 | GE JKP45 Electric Double Oven
F2 error message
Hvace, F2 is a shorted temperature sensor. Probably took it out with the self clean...Catriver..post back.
Aug 31, 2006 | Whirlpool GBS307PD Electric Single Oven
Open Questions:
Kitchen Ranges Logo
394 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
