How do I hook cable up to my ws-55513 - Televison & Video
    Master:
  • 876 Answers
The manual (available here):
http://www.searspartsdirect.com/partsdirect/user-manuals/WS55513-mitsubishi-parts-TV-manual
says to connect to ANT-DTV if it's cable for digital broadcast
Posted on Nov 11, 2014
  • 1694 Answers
SOURCE: Mitsubishi WS 55513...
www.chrisandnat.com/projects/blinkingtv/blink.htm
Also,check three 4 amp surface mount fuses on trace side
of board.............T.
Posted on Apr 24, 2008
SOURCE: Blue Scrren
have you tried changing cables or running setup from "Device" menu? Keep me posted....
Posted on Jun 14, 2008
SOURCE: mitsubishi WS-55513 won't turn on
from what i know thru extensive research.....and i mean alot the dm board (as in the whole thing) is not all bad its thecapacitors on the dm board that are supposably cheap O'z if you know what i mean. there should be 4 of them. you can buy the replacemnets from radio shack for about 8.50. if you know someone who is handy with a soildering iron, or a freelace electically type then ask them if they can put the new ones on for you. the correct one you need are -40 degrees to +85 degrees Celceus...tolerance +20%, now this is important 1000microfarad.... now these capacitors cant be less than 16V they can be over but not under.... typical brand to get is xicon....you have to remove the dm board which is in a metal shield once the back part of the television is removed you will see it cause it looks like it should be in a computer. but apparently this is typical and its a very simple fix but everyone that is capable to fix it want to bend you over and do you dry....mitsubishi should be ashamed of themselves for not correcting this themselve and offering help with cost.. hope this helps guys!
natalie
Posted on Jan 20, 2009
bugpowder
  • 28 Answers
SOURCE: Mitsubishi WS-55513 55 in. - Picture to latge for scheen
Change your Display Format (widescreen mode) . You're using ZOOM. Press FORMAT on the TV remote control to cycle through the available display formats.
Posted on Feb 10, 2009
  • 556 Answers
SOURCE: hey anyone there? I have a WS-55513 with a
There are 4 capacitors on the dm board that cause this problem if they are not puffed up, however the dm board will need to be replaced.
Posted on Dec 06, 2009
I bought a used mitsubishi ws 55513 and when i turn the tv on is says 480i stretch. How do i use the 1080?
U don't get to chose modes.480,720 and 1080 it chose by the tv show itself.Want more 1080 must have HD package from cable or satalite compannies.
Jan 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 wont go from 480i t0 1080
Tries CBS or NBC channels have HD if displayed 1080i than ur box is working.The shows must say HD or Display 1080i to work HD programming.
Jan 15, 2010 | Mitsubishi VS-60111 60" Rear Projection...
I got a Mitsubishi WS-55513 55 in and the guy said i have to replace a fuse do you know anything about a fuse and the cost
What does the set do when you try to turn it on? What does the led light on the front of the set do?
let me know so i can help
Tim Nolan
Sep 17, 2008 | Mitsubishi WS-55513 55" Rear Projection...
How do you hook up a Playstation 3?
The cable that comes with the PS3 can be plugged into the front flip up panel for initial setup. However, you'd be better off getting a PS3 component cable and using one of the component connectors in the rear of the set. The 55513 doesn't have HDMI, so that option is out. If the PS3 was previously connected to a HDMI TV, you'll need to reset it by holding the power button down for quite a while while turning it on. I did it a while back and I think that's what it was. This will bring it out of HDMI mode and back to compsite. Hope this helps.
Jul 08, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blinking light no power
Same here Once I plug the tv WS-55513 to 120 volts the green blinking timer blinks endlessly
Jun 24, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blue Scrren
May 17, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Wanting to get my full hdtv out of this tv 55513
Are you trying to use the red/blue green component cable or HDMI cable? You may have to go into the menu on your cable box and specify which cable you want it to output to.
Jan 25, 2008 | Mitsubishi WS-55513 55" Rear Projection...
How do I change the Format from 480 1080i
Make sure that the DVD player is set to output 1080i. Then, check that you have hooked up the DVD player to the TV via the HDMI cable. If you are using something other than the HDMI cable, they the best you can do is 480p.
Dec 22, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
