I have a toshiba satellie L300D laptop that I have not used in 4yrs but want to get stuff off of it. I can not get it to turn on. I have charged it and the green power button lights up but nothing comes on the screen.
    Master:
  • 752 Answers
You could try removing the hard disk (search Toshiba website or consult the appropriate manual or search the internet for how to do this; try http://www.insidemylaptop.com/; there's probably an instructional video on youtube) and connect it to your other computer with the USB, by using a caddy/enclosure with an appropriate Internal interface (probably a SATA), or by using and adapter/cable. Either should cost no more than $10US / £5.
This might help you to recover any data you want. Better, make a clone of the Toshiba's HD (identical copy) so that you have a instantly useable back-up of that disk. This does not solve the problem that your laptop doesn't turn on however. Do you remember why you stopped using it ? It may be because it had developed a fault !! But problems with turning on can be any one of many. Start with checking that the PSU/mains adapter is actually working properly. Ask for help on the Toshiba users forum probably accessible through the Toshiba website.
11.November.2014
Posted on Nov 11, 2014
SOURCE: Toshiba Satellite A15-S129 PC Notebook will not turn on
I have the same problem. What I have found with mine is that if I can get the battery to take just a little charge then I can get it up and running. Here is how I do it. Disconnect AC power leave the battery in and start the laptop. As soon as thing start to run I plug the AC back in and it works fine from there on. Now mine is flashing as well now and I have a dead battery and it will not restart. Something I have noticed thought is it appears that the yellow light is blinking a code. This is what I have come up with. I appears to be flashing 323 as the code or could be 2 shorts 1 long then 2 shorts and then 3 shorts.
Anyone know where to find info on these flashing codes.
Thanks
Posted on Dec 14, 2007
SOURCE: my toshiba 2455-s305 wont boot up
If you are familiar with your laptop, i.e. the locations of hard drive, try to take it out of the its bay and put it back again. Also, if you can have someone check your battery packs, because from my experience with this laptop, when the battery packs is not charging well, i got some booting up problems.
Posted on May 19, 2009
frankzjm
  • 191 Answers
SOURCE: NO VIDEO OUTPUT FROM LCD OR EXTERNAL MONITOR ON TOSHIBA SATELLITE L20 LAPTOP
you may do follow steps
1) eheck memory : reseat all RAM or change other same model RAM
2) take out wireless card at back of laptop MINIPCI. try it
3) still nothing run, your otherboard hardware damaged, need to change the motherboard. the parts please reference here
http://shop.ebay.ca/items/__Toshiba-Satellite-L20-motherboard_W0QQ_kwZToshibaQQ_kwZSatelliteQQ_kwZL20QQ_kwZmotherboardQQ_ckwZlaptop?_trksid=p3286.m104.l1200
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
Posted on May 22, 2009
  • 490 Answers
SOURCE: toshiba equium m40x won't power up
whats happening is that the cpu is overheating and shutting down the computer due to your fan not spinning, if you wish to test this remove the bottom panel and remove the fan and its cooling tubes should all be one part (quite easy 3 or 4 bolts) and blow on the cpu or put a pedistal fan facing it or any other form of cooling that wont damage it, and try to start it if it boots for a while it is the fan and you will need to replace it, i had this exact problem yesterday
Posted on May 27, 2009
myrlex
  • 674 Answers
SOURCE: We went to use our Toshiba L305D laptop. All
try to remove the battery fact then open it.. if the same problem..
check the inverter of your pc.. try ot use safe mode. restart your computer then press f8 select safe mode
Posted on Jun 25, 2009
My Toshiba L300D laptop needs resetting to factory settings.. how do i do this?
if yr laptop still can logon, recover yr system use system recovery on yr laptop, if not use cd recovery or recovery partition on yr laptop hard disk
Feb 19, 2011 | Toshiba Satellite L300D-ST3501 Notebook
How do i replaced the charger socket in my l300d toshiba laptop
I have come across this issue in a number of Toshiba laptops recently. The DC jack assembly (which includes a wiring harness and the DC jack) actually breaks away from the bottom laptop housing. What I have done is to glue the jack back in place using a hot glue gun. You need to be careful and observe how the right speaker (located on the top housing) is situated. Be liberal on the glue and make sure the jack is encased in the glue. I have not had any units returned after this was done.
Good luck
May 15, 2010 | Toshiba Satellite L300D-ST3501 Notebook
I have a Toshiba Satellite L300D and its not charging the battery I have replaced the battery and it still the same
Hello.
Please checj with the battery model might not be compatible to your PC. Ir that because you have connection problem. Maybe you have wire shortage. check with you provider so that this will be fixed or be replaced with a new one that functions well.
Blessings.
Feb 20, 2010 | Toshiba Satellite L300D-ST3501 Notebook
Ho do i turn on my bluetooth for the L300D?
Toshiba Satellite Pro L300 PC Notebook does not have Bluethoot device inbuild. You have to connect a external device for use.
Thanks.
Feb 03, 2010 | Toshiba Satellite Pro L300 Notebook
When i use my laptop with a tilt stand, it shuts down, no reason!
Please check your battery, it is having some loose contact problem OR can you check if the problem persists when it is running normal and you are changing the angle of LCD monitor ?
i am sure the problem is with battery connectivity only. Please get it checked.
Mar 16, 2009 | Computers & Internet
Wireless device disabled
Go into setup routine and enable wi-fi.Save and exit. Usuall you have to press delete or some other key when first turned on,to get into the setup screens and BIOS.
Dec 27, 2008 | Toshiba SATP L300D Notebook
Type of wireless
http://explore.toshiba.com/laptops/satellite-pro/L300
this shows all the l300d models at the bottom and what the card is in it. I would get the newest available for speed, and reliability. it is N. an N router will be backward compatible with B, G, and A
Dec 22, 2008 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
