Question about Sharp EL-2630PII Calculator
Paper feed not working E on screen - Sharp EL-2630PII Calculator
Paper will not feed through printer part
cut the paper evenly with scissors before attempting to feed it into the paper entry port. If you just rip it, it will jam or fail to feed.
Nov 06, 2013 | Casio Office Equipment & Supplies
Paper will not "feed" from
this is an issue with the papper feed and pickup rollers if it is not taking the paper from draw you need to replace the pickup and feed rollers also check the paper feed clutch if no good replace as well
Also make sure also make sure the paper is being lifted up when you close the draw you should hear the tray lifting the paper up to the feed system
Feb 17, 2011 | Minolta EP4000/5000 CS/PRO Copier
Get Print error occured on screen,sounds like
check for possible paper scratch inside or in between roller, try to feed paper manually by turning roller. and observe if no abstraction when feeding also check if sensor key is working.
Apr 09, 2010 | Epson Stylus Photo RX620 All-In-One InkJet...
Cannon pixma ip 4600 error code 5700 - paper jam
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
Sep 02, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Wont grip paper on feed, keeps 'saying' paperjam
I have had this problem after printing a large batch of sheets on a heavy matte photo paper. The roller picks up a 'polish' from the surface coating and then fails to grip. I have tried cleaning the roller, with some sucess, but the best solution I have found is to feed through several blank sheets (just page throws in a Word document) of a ordinary 80 gram paper. Doing this between smaller batches of the photo printing seems to keep things flowing.
Jun 24, 2009 | HP Photosmart 2575 All-In-One InkJet...
Mp780 - Paper attempts to feed and fails Message: Load paper
Your paper feed source is wrong .Go to the printers control panel and change the feed source.
If all you do is 8.5X11 you can go into the maintenance tab and choose it to automatically change paper trays by selectin auto continuous feed.Make sure paper is in both trays of the same type and size.You will hear the printer try and grab the paper three times then it will automatically switch to the next tray.
Jun 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
No paper feed
what is the printer brand and model#? also try making sure the paper is in far enough and isn't sticking, and the paper guide is tight
hope this helps
Apr 09, 2008 | Office Equipment & Supplies
Paper feeder not working
Are you sure the correct paper feed has the paper and the machine knows to pull from that feed?
There are two paper feeds on this unit.. one in the tray down front and one in the rear top. There is a switch on the left hand side of the front panel and whichever feed area you want to use should be GREEN...
Let me know.. we'll go from there if that's not it.
MaggieB
Feb 13, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Paper Jam
Check carefully, maybe you have just small peace of paper on the sensor actuator.I suggest to inspect whole path of paper.
Feed,transport,fuser.
Nov 02, 2007 | Dell 3000cn Color Laser Printer
Will not feed paper
There could be a small piece of paper or other matter blocking the feed. Try feeding a piece of thin card- simple load and eject don't try to print anything. Or Put a vacuum nozzle in the slot to suck any debris out. Come back for more advice if this is not the answer.
May 08, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Sharp EL-2630PII Calculator Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
