Question about Craftsman 21" 179cc* Single Stage Snowblower w/ Electric Start - MTD
Is the spark plug on my new snow blower already set to the .30 gap at delivery?
I am having a very hard time getting the plug out to check the gap- hard to reach and almost seems tilted- plug wrench hardly moves it?
  • 430 Answers
It,s already set to specs when u buy it u need to call The service center or store where was bought...being new u should not do anything to some thing new and still under warranty
Posted on Nov 10, 2014
Snow blower sat for about 2 yr's had hard time getting it started.now it's surging when it's running.
Hello, I suggest you adjust the idle mixture screw on the carburetor to smooth out the surging.
Feb 14, 2016 | Garden
CHANGE SPARK PLUG ON TORO CCR 3650 SNOW BLOWER
First disconnect the spark plug wire from the spark plug. Then use a socket wrench to remove the spark plug. Install the new spark plug into the cylinder head and reconnect the spark plug wire. The Toro CCR 3650 uses a NGK BPMR4A plug gapped to 0.032".
Jan 25, 2016 | Toro Garden
Brand new. Why can't I get it to start?
Have you used the snowblower recently or is this the first time. Can you explain as to different things that you have already tried. For example Checked for spark, Fuel, plastic key is there, has the outside air temperature changed?
Remove the spark plug after you try and start it and see if the spark plug is wet with gas, if so the plug maybe fouled under compression a new plug will be required. If no gas is present on the plug, there may be some ice in the carburetor from water in the gas. This is why i had asked if there was a temperature change. A trick that I tell my customers is to warm up around the carburetor with a hair dryer or heat gun. Do not get to close remember gasoline is present.
Jan 23, 2016 | Cub Cadet Snow Blowers. 24 in. Two-Stage...
Craftsman electric start snowblower wont start
That's refreshing! You've already done a lot of the work!
First, try regapping it at about .040, see if it starts there. If not, check compression.
Does it generate any spark at all? Try it with a screwdriver instead of the spark plug. If none, track back to the magneto - also check any shutoff wiring at the magneto.
Um... you DID put fresh gas INTO it, right? 8) If you take the bowl off temporarily, does gasoline drain freely from the bottom of the carburetor?
Mar 01, 2014 | Garden
Can't start poulan ppbp 30 cc gas blower
At all? Check the plug to see if it's wet. If so you are getting fuel so problem is spark. Get a new plug and gap properly. What else have you tried?
May 06, 2012 | Poulan Garden
What is gap setting for spark plugs on vw polo genesis 1043cc with cat converter petrol
the spark plugs must be change at 30 000 k/m if you use gasoline (octan 95) the gaps are already fix distan. 1.5mm . for new spark plugs , it will come up by use and consumptions , check the distan. for the metal on the meddle par must be 2.5 mm for new spark plugs by consumption it will go down to the meddle white cover.
Jul 19, 2011 | Volkswagen Polo Cars & Trucks
Have a 5.5 HP Tecumseh engine in a snow blower with starting problems. This is a 4 stroke engine that is 3 years old. Engine won't start, not even a sputter. Have clean gas, fresh oil change and a new...
Check the spark plug that is gapped 0.020" for blue, snappy spark. If weak or nothing, expose the flywheel and ignition module, then turn the flywheel until the magnets are under the module poles. Insert a thin business card into the pole gaps, loosen the module screws and allow the module to contact the magnets. Tighten the screws and rotate the flywheel somewhat to release the card. Rotate the flywheel one full turn to make sure the gaps don't close up further. Remove the ignition switch wire from the module coil, and try for spark again--if nothing, replace the module. If the initial check for spark was fine, then pour a little fuel into the cylinder head through the plug hole and try for start. If it fires several times, you have fuel delivery problems. Check for fuel flow from the tank by removing the fuel line at the carburetor--it should run out in a thin stream. If nothing or just drips, check the fuel filter for plugging. If ok, then remove the carburetor, disassemble, and clean the interior with spray carburetor cleaner. Use of compressed air will help clean any small passages. Hope this helps!
Dec 04, 2010 | Garden
Craftsman 21" 179cc* Single Stage Snowblower w/ Electric Start - MTD Logo
91 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
