My power will not come on i have replace the power button board and the power jack and still it wont come on
  • 430 Answers
Have u tested the charger to make sure it is putting out power?
Posted on Nov 10, 2014
Testimonial: "brand new charger"
  • grove_jimmy Nov 11, 2014
    it has a brand new charger
Wont start when I push button.
Make sure when you put it back together that you did not forget to plug in the power button or button cable. Also the battery may not be charged if it is new. Batteries do not hold charge being li-ion for a long period of time.
Apr 15, 2014 | HP Mini Computers & Internet
Msi vr601 power jack
If it is the power connecter (DC power jack) inside the laptop, then you have two options. One is to replace the mother board or two, replace the connector. Both require you to know how to almost completely disassemble the laptop and put it back together and replacing the connector also requires you to know how to solder.
Oct 18, 2012 | MSI VR601 (9S7-163C44-492) PC Notebook
Wont start up
Remove the battery and AC Adapter cord, and press and hold the power button for 30 seconds. Then, without replacing the battery try plugging in your AC Adapter to see if you get any love. If that doesn't work, remove the AC adapter, reset the board again, and this time hold the power button down as you plug in the AC Adapter cord. If you still don't get any lights, you could try removing your memory, reset the board, replace the memory, plug in the AC Adapter, and try one more time.
If all of this fails...you should take advice from experts,call at-http://www.vtechsquad.com
Sep 05, 2012 | Acer Aspire 7750G-6662 - Core i5 2.4 GHz -...
HP TouchSmart tx2 wont charge or start
Most likely the power jack has gone bad. This happens regularly on laptops. Some laptops have a replaceable circuit board with the jack but most are soldered directly to the main board. If separate board, most cost under $50 and jacks themselves are usually under $10. Either way you have to have the skills necessary to take the laptop apart and soldering skills if it does not use a replaceable board.
Aug 21, 2012 | Computers & Internet
My laptop shuts off after i turn it on.why
Does your laptop even begin the boot process where it displays stuff on the screen? Do you hear fans running, disk drives running, see lights, hear the cd drive click once and notice a light that comes on the cd drive door briefly when you press the power button? If not you computer either has a bad power cord, a bad dc power jack where the power cord plugs in, a bad mother board or static build up. 1) lets eliminate static buildup by removing the power cord and the battery then press and hold the power button for 30 seconds. Then replace the power cord but not the battery and hit the power button. If it boots up you had static build up. 2) Take an ink pen and put in in the slot where the power cord plugs into the laptop, if it wiggles loosely then your dc power jack which is soldered onto the motherboard needs to be replaced. 3) If the power jack is tight and when you plug in the power cord if you don't see any lights or hear a fan, disc, cd drive, then you can almost bet your power cord is bad. 4) If the power cord is ok then you have a mother board issue. Normally motherboards will give some beeps or constantly blinking lights when you plug in the power cord and try to boot up. These beeps or blinking lights will tell the technician what is wrong with your computer.
Mar 19, 2012 | Acer Aspire One Netbook 8.9" Notebook
Power problem
Here are some ideas you can try when troubleshooting power issues with a laptop:
1. Plug the laptop into AC power.
2. Take out the battery.
3. Try a different outlet.
4. Look for the light that indicates that the AC adapter is plugged in. If that light isn't on, try plugging and unplugging the AC power jack and moving it around until the light shows its connected. If no light comes on, its possible you have a bad DC jack or the AC adapter needs to be replaced.
5. If the indicator light is on and the laptop won't power on, then it's possible you have a bad switch board or stuck button. Make sure no buttons are stuck. Conversely, push hard on the power button and move it around in order to make sure you're making good contact.
6. If you know the battery has a charge, unplug the AC adapter and connect the battery. If it turns on then you can be sure you have a bad DC jack or a bad AC adapter.
7. Replace the switch board and/or the flex flat cable that runs from the switch board to the mainboard.
8. If your laptop has another button that turns it on, such as an internet button, try that button instead of the normal power button.
Hope one of these ideas helps.
Thanks for using FixYa.
Mar 03, 2011 | Computers & Internet
I got a compaq c36 it was working fine but now it wont switch on or anything do you now what it could be
6. If you know the battery has a charge, unplug the AC adapter and connect the battery. If it turns on, then you can be sure you have a bad DC jack or a bad AC adapter.
Mar 01, 2011 | Computers & Internet
My Garmins 530 wont power up and I have replaced the power pack
PRobably a defective logic board at this point. Was the jack loose before? Can you measure if the voltage goes in using a multimeter? If the jack is connected properly and it does not turn on, it's your board. If all else fails, there are third party Garmin repair services that will fix it for cheap.
Oct 10, 2009 | Garmin Rino 530
Exact same thing
Usually this means replacing the motherboard, but you could also have a bad power supply/charger. How old is the computer and is it still under warranty?
Aug 09, 2009 | Dell (8N816) Motherboard
HP Pavilion dv4000 PC Notebook Power jack problem
I am sure that power jack is a part of your mother board but you can also replace a new power jack for your mother board. I know that if you send it to HP they will charge you 398$ for repairing the notebook. I will give you a link from where you can purchase a power jack with a nominal price. You can fix it by yourself or you can go to any electronic shop for foxing this. It is as simple as soldering the new power jack on the mother board.
The web link is:
http://www.laptopjacks.com/product/HP-Laptop-DC-Power-Jacks.html
Regards,
Krishna Teja
Feb 21, 2008 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
