I need to know what part to get for my t.v
There is different colors of lines all through out the middle of my t.v
  • 1,680 Answers
Replace tcon board of the right make an model
Posted on Dec 18, 2014
What is the factory serting for the thread tension on a Janome Memory Craft 3000?
Factory setting is usually the midway point between high & low number. Sometimes it is specifically marked on the dial with a red line or a different color. Of course, this is only the general setting. Every machine is different (especially after use) so this setting needs to be tweaked. Even different kinds of fabric will require a tension tweak. The tension is correct when both threads meet in the middle of the fabric.
Dec 27, 2016 | Janome Sewing Machines
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Televsion has black screen with a thin colored line thru the middle you can see movement on the line . its like the screen shrank down to just this little strip
This is exactly what has happened. the vertical deflection section has failed. It could be a myriad of different things and if you are not technically minded and have an oscilloscope then all you can really check is the integrity of the soldered joints on the circuit board. Who knows you might get lucky! Good luck
Jul 13, 2014 | Zenith SY2551S TV
Color stain
Laser, inkjet??? Model Make ??? You need to be more specific.it makes a difference on the type of ink used.
Sep 06, 2012 | Samsung Clp-325 Colour Laser Printer
Hello, my problem is, when i print a copy I receive a blank line, it seems like the ink is finish or the middle of the ink is finish or don't have ink. don't know what to do I tried to clean the toners and...
If you are seeing a white line down the page in one or more areas, but it is printing fine in others it is most likely your toner or your drum. Try taking the toner cartridge out and shaking from side to side to evenly distribute the toner and break up any lumps that might have formed while it sat around. If that doesn't work take out your drum unit and look at the drum roller (don't touch it!) if you see lines or color differences on it then it might need to be replaced.
Aug 18, 2010 | HP LaserJet CP1515n Printer
Tv just looks like i folded picture need help on configurance set
The tv have a problems known as a convergence problems,it dead.U have tools,soldering iron,solders.U know how to do solders?Try Ebay.com to buy a convergence Fuse(FL231).The big block of plastic call the FBT.Resolder the FBT.The 3 three fuses caps on (FL231) beside it.The covergence fuse cap in middle is dead,replaced the covergence fuse cap in the middle will solved ur convergence problems.
Jul 17, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
1998 mustang gt coil wire diagram
If the colours on the new plug are different,no problem. Just make sure the same amount and colour go back to the original holes/terminals.
If you still need help, you should let us know which engine you have.Also if it is a 2V or 4V.
Jul 27, 2009 | 1998 Ford Mustang
AKAI PT5598HD
Your set has what is know as "convergence problem" because of the bowed lines and ghost in different colors,is really not an easy solution,the set should have 3 amplifiers(one for each color)and they need to be replaced with an exact replacement,sometimes just by replacing them the aligment should be close but soemtimes you nned to get into the service menu to do some adjustments,the amps(IC's) are mounted on heat sinks and all 3 have the same part number on its face,they normally read STK--- ---,every set uses different amps,If you are familiar with tv service you have now a place to start working but if you are not too familiar be safe and call for help from a servicer.Let Us know if you need more information.
Oct 31, 2006 | Akai PT5598HD 55" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
