Question about Plumbing
Sewer smell in house from septic tank and idle system
The house has a private lift station to move sewer to the main. Also the house hasn't been used much
  • Sam Gibson
    Sam Gibson Oct 29, 2015
    Jason, I'm sorry to hear about the smell coming from your septic system. Have you had the chance to speak with a septic professional? It seems like septic systems could be a bit tricky, especially if they hadn't been used in awhile. If you do have someone come out, it might be a good idea to find someone experienced and reputable. http://bledsoeandlinnseptic.net/Services...
    Habit-Forming:
  • 76 Answers
If the house has been sitting for a long time, the traps may have dried out and are not stopping the sewer gasses from being trapped back, flush all toilets and run some water in all the sinks and tubs, to refill the p-traps, also don't forget to pour some water down the washer drain pipe. HOPE THIS HELPS...
Posted on Nov 10, 2014
    Sergeant:
    Habit-Forming:
  • 138 Answers
Some times blocked drain lines or vents bringing about trap siphonage or sewer gas backups into the building can have as a segment or a can be a primary cause of septic system drainfield failure. This septic drainfield failure in turn may be due inadequate maintenance.
Call a local contractor and fix your problem.
Posted on Mar 31, 2016
I have a septic tank . Can I use the expense of cleaning out my septic tank as a water an sewer exp ?
If you are on mains water as opposed to a well, you shouldn't pay the waste water disposal part of the bill.
If you mean on your taxes, no, unless you are self employed and have a home office.
Jan 07, 2017 | Plumbing
Rotten eggs smell
The smell is sewer gas coming back in the house from the sewer or septic tank ether from a dried out water trap in a floor or fixture drain, or from the roof vent, or a hole or separation in pipe or fitting. Like wax ring under toilet. First pore water down every drain to fill any trap that might have gone dry, then flush toilet or run washer or drain bath tub.This will displace gas in pipe and will cause the smell to increases if there is no smell then the problem is fixed if not check roof vent it may need a charcoal filter on top, There is no water trap on air vent on roof and is an open hole to the sewer or septic, The heating system in the winter or AC in summer will draw the gas inside from the vent.If it is the vent you should be able to smell it from outside. If all tests fails You will need to have a smoke test done. A smoker is set up outside and the line is filled with smoke and will show where gas is coming from. Also it might be a good ideal to check all gas fittings in case it is a gas leak.
Jun 15, 2014 | Plumbing
Smell of rotten eggs in shower drain
This is likely "sewer gas" and can cause headaches, dizziness, etc. if you remain exposed to it for a prolonged period of time. This originates mostly in the drain openings of fixtures that are seldom used - such as sinks and showers of basements, guest rooms, etc.
When these fixtures do not get used regularly, the relatively small amount of water that is designed to always be present in the "trap" portion of the drain pipe eventually evaporates. This trapped water prevents the the gasses in the sewer / septic system from passing through the trap. Without it, these gasses will rise through the pipes connected to the sewer / septic system and exit into your living space via the drain opening in the floor drain, shower, tub, sink and even toilet if left unused long enough.
It is usually resolved very easily by slowly pouring about a 1/2 gallon of water down the drain. The water now isolates the drain opening from the sewer / septic system and effectively stops odors from escaping. If you find that this is happening regularly (often from floor drains in dry basements) you should slowly pour water 1/2 gallon of water into the drain, and then add 2 to 3 ounces of cooking oil. The oil is lighter than water and will sit on top of the water surface. Oil does not evaporate and blocks the water from evaporating through it. Evaporation of the water in the trap will take place from the sewer / septic side of the trap, but it occurs at a much slower rate.
After filling the traps with water or water & oil, just ventilate and you're done!
Apr 03, 2014 | Maax Breeze: One Piece Round Shower...
Smell of sewer in the house
Ensure all your additional rough in plumbing is capped, and toilets or sinks that are not used for long periods of time , sometimes p traps may dry up allowing sewer gasses to enter the home so use them once in a while or fill with water once in a while ,same with floor drains. If that isn't it check that you have them installed.
Jan 06, 2014 | Northstar Sewer And Drain Cleaning...
Sewer smell coming from sink when water runs into drain
is there a trap in the sink drain just under the sink
if not put one in
a trap holds water in a bend so sewer gases dont come up through the drain
Nov 20, 2013 | Dishwashers
Anyone can suggest me some sewer tank maintenance tips?
I think you'd avoid poring detergent water into your sewer tank and mustn't use hard cleaner to clean your toilets as it will kill all the bacteria in our sewer tanks or never flush plastic items.By following these tips you can increase the life of your septic tank.http://www.ps2i.biz/plumbing-services
May 23, 2013 | Washing Machines
Septic effluent pump loses prime
DONT TRY TO EMPTY THE TANK, RAISE THE FLOAT LEVEL. THIS STOPS THE PUMP FROM SUCKING AIR WITCH CAUSES THE PUMP TO LOSE PRIME,
WOW THAT WAS A EASY ONE. ....NEXT
OH AND YOU MIGHT NEED A CHECK VALVE ??
JAY THE POOL PUMP MOTOR REPAIR GUY LONGWOOD FLORIDA
Sep 11, 2012 | Monarch Pumps BE-S75 Wastewater Pump...
Do the saniflow toilet need to be plumbed in to mains waste? I have a patient who needs a toilet located outside the house that needs to be trouble free
Hi and welcome to FixYa, I am Kelly.
In short yes it will need plumbed with a smaller drain line to the home waste drain.
The unit uses a fast-rotating blade to reduce waste and toilet paper in the flush water, which is immediately and entirely released under pressure through "small-diameter piping" to the sewer or septic tank. No special maintenance is needed and the pump is sealed for life. This simple and cost-effective alternative to conventional plumbing is ideal for basement renovations and other home-improvement projects. Properly sized, a Saniflo macerating system can handle all the fixtures in a bathroom, including the sink, shower, tub and toilet & endash; even on a septic system. What's more, these fixtures will work up to 12 feet below and as far as 150 feet away from a septic tank or sewer line.
Go to this page and download the manual for the installation instructions:
http://www.saniflo.com/Downloads.aspx
These are all the installation downloads available on that page:
Installation Instructions:
SANIBEST SANIGRIND SANIPLUS SANICOMPACT SANIPACK SANIALARM SANISHOWER SANISWIFT SANIVITE SANICUBIC Classic SANISTAR SANITOP
Thanks for using FixYa,
Kelly
Jun 01, 2010 | Home
I am getting a bad smell when I run the washer. What can I do about that?
first u have to determine where the smells coming from if its coming from the drain line you can go under the house and install a p trap and that will allow the line to hold a lil water and stop the smell from coming out of the septic tank or sewer whichever u use
Feb 26, 2010 | Washing Machines
Sewer Gass after using Bocsh 300 washer
When you have problems with sewer gas smells around a
fixture, there can be a number of causes.
1. Sewer gas coming back up into the home
a. Blocked vent.
b. No vent.
2. Leaking drains that cause rotting below the floor.
3. Moisture that causes mold buildup.
4. No trap on your sink.
5. One roof vent on septic system.
6. Toilet needs to be reset and calked.
Sewer gas can come back up into your home, when the
trap completely empties after a letting the water out
of a fixture, when the trap dries out, or when it is
sucked out by another fixture flushing. When water
goes into a pipe, it first has to push the air ahead
of it, if there is no place for it to go, it comes up
the trap. This causes a buildup of pressure if there
is no vent.
If there is a vent, the pressure is relieved up to the
roof, carrying with it all of the yucky smells. When
the water runs down the drain, the air behind it has
to be replaced, if its not, the pipes will try to ****
it from some drain...typically the shower drain, but
sometimes the floor drain when its close to a washer.
When vacuum draws air in through the trap on the
laundry tub it also takes the water out of the trap,
leaving an opening where the sewer gasses can come
back up from the septic system .
Think about your pipes as if they are a drinking
straw. When you put a straw into a glass of water,
the water fills the straw. But if you put your thumb
over the end of the straw and pull it out of the
water, the water (or liquid) stays in the straw. This
shows you, air has volume. When you remove your thumb
from the end of the straw, the water flows back into
the glass. This is the principal of a vent.
So if you only have the smell when a fixture is
running, the trap is refilling after the fixture and
blocking the sewer gasses from coming into the home,
but your vent is probably not functioning.
In addition, if you have only one vent up through the
roof on a septic system, you can get sewer gas smells
coming up through your home. As the wind blows
across the roof, it pressurizes the plumbing system.
Since the septic tank is full of water, the wind
cannot go into the septic tank. So it bubbles up through the
traps into the house. Installing a vent on an
opposing roof pitch, helps to relieve the pressure buildup,
since the wind then is only hitting one side of the
roof.
Floor drains are succeptable to this type of pressure.
If your drains are partially clogged it can work
similar to a clogged vent. Since there is no place
for the water to go, it forces the air, which is much
lighter up through traps, bringing sewer gas into the
home.
If your fixture is not set right or is wabbling, the
traps or wax ring that seals it underneith may not be tight.
When this happens, if you empty the fixture, sewer gas
will come under the sink into the room.
Each of these senarios will require a different
solution. The key to solving your problem, is having
the right questions to ask when the plumber comes out
to look at it. The previous information should
provide you with a basis for the questions you need.
Make sure before you call a plumber to check
cleanout covers and pipes to see if they have
openings to the sewer. If you have an opening
without a trap, you will get sewer gasses.
In conclusion, if you don't have a vent inside the
wall which equalizes the air pressure inside the
pipes, if you are on a septic system with only
one roof vent, if the vent is clogged off due to
sludge and soap scum, if you don't have a proper trap
on your sink, or if the drain is clogged, sewer gas can escape
into your home.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Plumbing Logo
919 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
