Question about Nexgrill Charcoal and Gas Grill Combo
Used two times and now the flame wont go any higher ..just stays on low
Flame stays on low will not go higher when turned up
Low burner flame in main oven
There may be a problem with the igniter. they get old and don't open the valve completely. You could have a bad regulator.
Oct 05, 2014 | Kitchen Ranges
Hello, we have a 3 switch stainless grill that has NEVER heated up properly. It always seems to stay luke-warm. Please help.
First, how high are the flames when turned to high as opposed to the low setting on each of the 3 burners? If there's no significant difference in height between the two settings, here's what I want you to do.
Turn off the gas tank (that's assuming you are using a 20lb LPG cylinder) and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the Tank Valve ON very, very slowly, until it's fully open. Now, light each burner individually turning them to high. Are the burner flames higher than before? If so, you just solved your problem.
Remember to turn the tank ON very, very slowly after turning it off to change the tank or if you turn the tank off after each time you grill. Also, when grilling preheat the grill with the lid closed, after lighting the burners.
Hope that solved your problem ... Happy Grilling!
Feb 15, 2011 | Ducane Rottisserie 2004 (LP) All-in-One...
The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
Mar 10, 2010 | GE Cafe CGS980S Kitchen Range
Flame wont stay on, runs for about 5-10 secs and
usually the thermocouple wears out. Make sure the thermocouple is in the flame, if it is, and it still wont stay lit I would change that first.
Feb 28, 2010 | Mr. Heater MH175KT Open Flame Utility
My BBQ flame stays on low
i would check the gas tubes for spider webs
Jan 06, 2018 | BBQ Guys BBQ400C/G42 Grill
Pilot light wont stay on
yes there should be a screw to turn near gas control knob at front there is one for each burner and the oven
Aug 26, 2009 | Ovens
My ventless gas heater has an uneven flame with orange tips, the flame toward the outer edge is higher than the flame in the middle, and also,when I light the heater, it doesn't just give me a piolot...
This sounds like your gas valve is weak. An orange flame has to much gas and not enough air mixture. Have you trie to ajust the air mixture. If it won't ajust then you will need to replace the valve.
I hope this helps.
Oct 24, 2008 | Heating & Cooling
Gas Grill - flame always stays on high even though I've turned in on low
hey buddy that use to happen to me so what i started to do was once the fire was high i use to turn the gas off i hope this helped.
 infamouspk
Oct 07, 2008 | Sport & Outdoor - Others
Simmer is to hot
I am hesitant about answering your question because if the flame is adjusted incorrectly it could be dangerous.
Remove the knob and look inside the stem of the gas valve. You will see a very small adjustment screw. This is where you adjust the flame for the burner.
What I usually do is light the burner and turn it to the lowest setting. Hold the stem in this position and turn the screw. They are usuall kind of stiff to turn.
You want to adjust the flame so that it just comes to the top of the burner cap at the low setting.
This is the important part!!!
When you have got the flame adjusted, put the knob on and turn the flame to high. Quickly turn it from high to low, if the flame goes out, adjust it higher. Repeat this test until you can turn it from high to low quickly and it stay lit.
Also important to remember. When turning the screw, a little turn goes a long way.
Post back if you have any questions.
Oct 31, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Nexgrill Charcoal and Gas Grill Combo Logo
87 people viewed this question
Top Nexgrill Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Nexgrill Hardware and Accessory Expert? Answer questions, earn points and help others
