Question about Yamaha Wa16410 Us Remote Control Rav246
<!-- from fixya rte -->How do i scan for signals for other devices? - Yamaha Wa16410 Us Remote Control Rav246
When I put my computer on it comes up with scanning no signal and the screen stays black with the little light in the corner is yellow but sometimes leaving the computer on by itself
The monitor is stating that there's no signal from any device. It could be that the monitor cable is unplugged from the back of the tower, or the graphics card could be bad. "Scanning" suggests you're using a smart TV rather than a monitor. In that case, you may need to change the setup type to VGA, DVI, HDMI or whatever type signal the computer sends.
Oct 18, 2015 | HP Pavilion Computers & Internet
My jbl charge 2 power light stays on but wont turn on or off. What's wrong
if its connected via the included usb cable to your device , it will as power is being transferred via cable to units battery, if your using Bluetooth only , device will stay on as long as any Bluetooth signal is in range , and this can be any devices Bluetooth signal , even your thermostat will trigger this to stay on , use your phone to scan for other sources of Bluetooth ? it should develop a list of avail blutooth devices in range (they might not belong to you??)
Jun 25, 2015 | JBL Audio Players & Recorders
How to get NO SIGNAL off my TV screen and turn it on
If you are using a cable-system set-top box and running it to the Coaxial input of the TV, then you need to perform the channel scan. If you are using a set-top box and are using a composite or HDMI input cable to the TV, then no channel scan is required. You merely need to use the SOURCE button on the TV remote to choose the composite or HDMI input connection. Nd if you are getting a "no signal" indication on the TV, it IS on.
Mar 04, 2015 | Televison & Video
Why is it my scan maker 3840 having a light but it doesn't work? what should i do plz help me.... i need your help...
Scanner lights are indications of functionality where for example red is power display and green is scan in progress, yellow is indication of alternate signal once the device has been given instructions. The display of all available lights is indiction scan fucntioning. However, the device require computer connection from where the procedures of media is achievble. Scanner devices usually when attahced to computers also require softwares programs to perform as recognosed applications. Observe the computer for scanner devices program from where functions are attainable.
Feb 10, 2011 | Microtek scanmaker 3840
How to scan channels
The TV user guide should provide the procedures of acquiring auto scan. For example, your TV may be acquiring functionality from satellites dishs or cable receiver devices. Performing an auto scan achievable with the remote control device with adjustment to settings on the channel buttons would produce a signal only with available transmitter stations. Performing a channel auto scan would display no signals without available receiver devices often acquired with susbscription from a provder either cable TV, sattelite or disk network, show on demand for example. However, performing an auto scan on a new Tv should simply display a count list of possible available channels on which signals could be display when any is provided. Good luck
Jan 08, 2011 | Toshiba 32AV502U 31.5 in. LCD HDTV
GPS is not working. It says waiting for a valid GPS signal. What can I do to fix this?
Usually, when it's waiting to get a valid GPS signal, it is "listening" (scanning) for satellite signals to establish your current location. If you are in the open outdoors, i.e. not inside a building or under extended covers, it should get the satellite signals within a minute or so.
Jan 02, 2011 | Tomtom ONE XL GPS
Not getting a GPS signal. What do I need to do?
Usually, after you turn on the GPS device, it may take a minute or so to start up and lock into the satellite signals. While it is waiting to get a valid GPS signal, it is "listening" (scanning) for satellite signals to establish your current location.
If you still can't get a GPS signal, consider shutting it down ... using a "hard" shut-down (hold down the on/off button for 5 seconds or more ... to re-boot the system/software programs. Then, wait a while before starting it up again. Make sure your device is plugged in and/or the battery is NOT low when you're doing this.
Jan 02, 2011 | Tomtom GPS
Scanner on Sharp AR-M350u is showing NG800000 and is not sending scanned items.
This mistake NG800000 offset scanning device.
1 Try reinstall a driver on local on cord USB
2 Remove glass of the scanner and check displacement scanning device, it must softly move. Smazhte nodes mask, продуйте the sensors, check join a wire. Do Not use the long cord USB gets lost the signal, appear the hindrances.
Write, help. Good luck
Jun 22, 2009 | Sharp AR-M350U Copier
I have the aceraspire 3100 and I cant get the blue-tooth to work says same thing no BT device. i just paid about 60$ for a BT headset and really wat to use it is there a way to fix it?
please refer to pairing bluetooth devices. you,ll need to get the computer to scan/search for the required device, or pair to the device. this usually involves, using the vol up/down buttons or on/off of the receiving device, while the computers bluetooth scans for a signal.
if this resolves your problem, please rate as fixya.
Many thanks mike @ compurepair.
Nov 15, 2008 | Acer Aspire 5500 5570-2609 Laptop
Yamaha Wa16410 Us Remote Control Rav246 Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
