Question about Music
I have a Marshall VS65R amp that WAS working great until someone tried to daisy-chain another amp via the headphone jack and a couple circuts on the board cooked and look burnt. No sound now. Is it wo
Only the little circuts by the headphone jack are blackened.
    Top Expert:
  • Music Master
  • 3,107 Answers
Assuming the repair is beyond what you can do yourself, I'd estimate the cost of repair to be $75-100. You'd have to decide if it;'s worth it to you or if you'd be better off appling the funds to a new amp. If you liked it before it blew up, I'd get it fixed.
Posted on Nov 12, 2014
2 Suggested Answers
technical114
  • 1851 Answers
SOURCE: I have just bought a used Marshall VS65R. When I
Make sure that when the audio from the speaker cuts, the headphones are still working (try it several times). If this is correct the problem isn't at the preamp or driver tubes. Try to locate the wire that is connecting the speaker with the amplifier. There must be a bad connection at this cable or at the speaker's coil itself. Try hiting with a solid tool (the back of a screwdriver for example) the parts and the connections (not the tubes, just the mountings) while the amplifier is working in order to locate a loosing contact. Once you find it use a soldering gun to fix the connection.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Apr 22, 2010
Electricity flowing. Why won't amp turn on?
What type of Marshall, please?
First of all, control the fuse and let me know.
Oct 12, 2015 | Marshall Amplification Music
I have a MG50DFX and a MG15DFX, both amps head phone inputs don't work anymore. When plug in the headphone the speaker won't silence.
This is likely a bad switch contact in the headphone jack... they are really poor quality in most amps... plastic case and EASILY damaged by side forces on the jack. REplacement is the solution.
Nov 29, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
I have a Marshall MG100HDFX 100-Watt Amplifier half stack (solid state) and I now am not getting ANY sound out of the amp. I changed the fuse and the power module behind the fan, and still no sound,...
plug headphone in the effects send jack...If you get somme sound (won't be too loud) there, that means preamp sections are probably ok. Drive a signal into the effects return jack... If power amp responds, it is OK... If both these are OK, then suspect the switch contacts on these two jacks that forward the preamp to the power amp when effects unit is NOT plugged in.
These contacts are a chronic problem.
Sep 19, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Hi I have a marshall haze15w amp and stack, the problem seems to
There are many models of Marshal amps icluding 15Watt types.
First thing to try is to see if headphones have normal volume. If they do, then the headphone jack switch that connects the speaker is LIKELY bad.
If the headphones do not have any volume, LIKELY causes are:
1. Fried output power amp
2. Volume pot is broken or has bad solder joints to the circuit board.
Jul 10, 2010 | Marshall 15 Watt Guitar Amp
Hi, I have a marshall VS65R I bought in 96. It sat in storage for close to 8 years. I plugged it in and it sounded great....a week later at band rehearsal I played two songs and the sound went out...I...
Some of these have electrolytic caps in the power supply that are nearing end-of-life. I would take unit in for servicing if you are not electronically adept.
First thing though, check for a bad input jack as these often go bad. A wiggle test of the plug should make that possibility reveal itself.
Jun 15, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Thanks and regards
Stelios
Apr 22, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Marshall mg10cd amp has no volume
Common causes:
Broken input jack.
Blown power amp chip due to overdriving.
Smashed pots due to tipping over or transportation damage.
Blown power supply due to bad power at a venue.
In some cases, grounding the headphone jack can blow amp.
Feb 11, 2010 | Marshall MG10CD 10 Watt Combo Amplifier
No output from my Marshall MG15DFX
could be effects module or sound output i.c. also check send and return jacks
Feb 04, 2010 | Marshall Mg15dfx 15-Watt Combo Guitar...
Marshall VS65R is powered up it hums
Blown speaker NO (would not get sound at all)
Bad Reverb UNLIKELY (controls would deselect reverb and it would be out of circuit)
Bad preamp tube NO (controls have no effect)
Bad rectifier and/or filter caps LIKELY
Bad power amp POSSIBLE
Nov 29, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
Music Logo
41 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
