Question about Dryers
I have a garrison 46-0073-8 smoke alarm I need to replace . I can't find one that will have the 3 prong hook up so it will work with the others in my home where do I go in Edmonton
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: tried to replace 3 prong cord w/4 prong and now
Posted on Jun 05, 2010
I have a 5-year old Garrison smoke alarm. The LED does not flash every 45 seconds as the manual says it should, but the alarm sounds when I press the test button. Is the alarm working properly or not?
They recommend changing every 10 years so it is well in date.
Light 4 candles, and blow them out 6" under the smoke detector. If the alarm goes off, it is working :>)
Nov 27, 2016 | Home
Co detector garrison 46.0019.0 of may 2011 Rings continuously until batterynew removed
Junai, Try to vacuum/blow dust out of detector, if this does not work detector faulty and will need replaced. Most detectors have a label stating replacement date or expiry. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.kidde.com/home-safety/en/us/co-safety/about-carbon-monoxide-alarms
Looking for Answers about Garrison Garrison Plug in Carbon Monoxide Alarm
Why is my Carbon Monoxide Detector Beeping with pictures
Jun 19, 2016 | Alert Home Security
Where do I go to get a replacement if my smoke alarm has aged out.
If your concerned because it's a hard wired smoke detector (has 120v) any New replacement will work and they sell them at Lowe's, Home Depot, etc... there is typically 3 wires for a powered smoke detector, black and white (hot and neutral) red or yellow (to interlock with other smokes) Please make sure Power is OFF and this is a simple fix... I hope this helps ?
Feb 21, 2015 | Home
Is it normal for a garrison smoke detector to have a flashing red light ?
Yes in normal operation the red light should flash intermittently every 30-40 seconds.this lets you know the battery has sufficient power for detecting smoke.when the battery needs replacing the unit should beep/ chirp in singular sound every 60-90.if smoke I'd detected the difference is very obvious as the shrill beep is continuous and much louder.
Feb 19, 2015 | Home
Firex i4618
This is a smoke alarm and is not intended to be connected to your alarm system. While there is often a way to connect a listed relay for that purpose, connecting your smoke alarms to your alarm system can cause as many problems as not. Because the devices are not made to interface directly with the alarm system, proper supervision is usually not achievable. Loss of power might even cause false alarms. Some alarm companies even have policies in place forbidding such connections. Additionally, in the event of a false alarm you will need to call an electrician because most alarm technicians are not licensed to work on high voltage smokes. As a rule, you're much better off to add a few LV or RF smoke detectors to your alarm system for monitoring than to try to interface smoke alarms. Hope this was helpful.
Feb 01, 2012 | Kidde Firex I4618/4618 Ac/dc Ionization...
My new Firex 21007581 with a new battery keeps chirping. What is the problem and how do I fix it? Thanks Sal
He said it had a new battery so he already did that and why would you service a $12 throw away smoke alarm? This FIREX he identified is the 4618 and will also chirp while the LED light blinks, chirp is about 30 seconds after blink if the unit itself needs to be replaced because there is something wrong with it as opposed to a different chirp pattern for battieries. If still unerwarrantee FIREX will replace otherwise go buy a new one.
Sep 07, 2011 | Kidde 21007581 120v Firex 4618 Pro Basic...
We took the smoke alarm down because it was beeping and now want to put it back up but the red wire hanging from the ceiling is not hooked up to anything. What is it supposed to be connected to?
it could be a parallel wire, connecting the smoke detectors to each other so that if one goes off they all go off, do the other smoke detectors have the same wire ?
Jan 24, 2010 | Kidde 9-Volt Basic Smoke Alarm
Replacing plug
ok on a drier on your terminal block the center wire is neutral the other two are hot on a four prong cord the green or ground wire connects to the body of the drier if the dryer already has a green wire coneccted to the body of the dryer then take it loose and hook it to the neutral terminal of the dryer then hook the green wire or ground of the cord where it was if you need any more help let me know
Mar 30, 2008 | Amana NDE2330AY Electric Dryer
Dryers Logo
442 people viewed this question
Top Dryers Experts
