Need manual I need a users manual for an Akai AP-B110 turntable. Do you know if there are any for free download? None of the subcategories were exact so I just put in the closest I could. Thanks, Greg
  • DHOP Jun 12, 2008
    A friend gave me an AKAI AP-B110 about 15 years ago and I used it for a couple of years and put it in storage. I unpacked it the other day and tried to play it. I hooked it up to a tuner and speakers and tried to turn it on. Where do I turn it on? I know it is getting power because there is noise through the speakers when I touch the needle. I thought the turntable would began to spin when I unlocked the arm and lowered it onto the record. No such luck!
    Any suggestions?
  • 1,512 Answers
Hi Greg
Unfortunatly, ongoing support for Akai died when the company did about 7-8 years ago. They stopped making non commercial product. So there is next to no on line support from them. What do you need to know about the turn table.. perhaps I can help.
Posted on May 07, 2008
How do I connect this system together to get it to work?
The manual for the amplifier and all the other units are here. Use the search feature in the top right with just the model number 'AT-5210'. Getting the items in the right order helps. The turntable obviously goes on top. The Amplifier goes in the middle and all the other units connect to the amp.
Akai AM U61 Manual Stereo Integrated Amplifier HiFi Engine
Jan 14, 2016 | Audio Players & Recorders
Where do I get set of hinges for dust cover of AKAI AP-X1 turntable
Check on ebay for that tt and maybe someone has parts listed. Or try the manufacturer but if a unit is more than ten years old parts are usually no longer available.
Nov 22, 2015 | Audio Players & Recorders
Aai have the following AKAI Audio Stereo System and no Idea how to connect them. Please help Akai Model AP-D210 turntable Akai model CS-F14 Stereo cassette deck Akai model AT-K110 Fm Am Tuner Akai...
In general, outs to ins.
If nothing else, get the manuals for the preamp and the EQ. You'll probably have to pay for them.
Google it.
Akai PR-A04 preamplifier << This is the control center and where everything comes together.
Akai AP-D210 turntable (ONLY to jacks that say "PHONO"
Akai EA-G40 Stereo Graphic Equalizer (in the Tape 1 Out/In set)
Akai CS-F14 Stereo cassette deck (in the Tape Out/In set of the EQUALIZER) *
Akai AT-K110 Fm Am Tuner (to the Tuner inputs)
Akai DT-100 Audio Tuner (to the Aux inputs)
Akai PA-W04 Amplfier (to the amp outputs)
* This will allow you to Equalize the Tape on the Record or the Playback side.
Read some audio magazines or websites. Get to understand Tape Monitor Loops.
Don't use excessive EQ.
Mar 17, 2011 | Akai Audio Players & Recorders
Akai Ap-003 belt drive turntable pitch problem
Make shure that is a 50Hz turntable. If you connect a 60 Hz turntable in a 50 Hz system, the result is aprox 28 RPM in the 33 RPM position/
Dec 31, 2009 | Audio Players & Recorders
Can't find a users manual to download.
Thanks for using FixYa. You can find the Manuals for Crosley Turntables from these links---
Crosley Turntable User Manual Link 1
Crosley Turntable User Manual Link 2
Please do rate the solution and revert for further assistance.
Sep 26, 2009 | Crosley Audio Players & Recorders
Have akai ap-b110 turntable needs belt. Can you tell me the length/specs
  • If you have the turntable belt:
    • State the type of belt used (Flat, Square, Round).
    • Pinch both ends of the belt.
    • Measure the pinched length.
    • Multiply the pinched length by two (2x).
    • If the turntable uses a Flat belt, measure its width (usually 0.187").
    • If the turntable uses a Round or Square belt, measure its thickness.
    • Please include the make and model of the turntable with the belt's measurements.
  • If you do NOT have the turntable belt or it is shredded:
    • State the type of belt that the turntable uses (Flat, Round or Square).
    • Use a piece of string to tightly follow the belt's path.
    • Measure the length of the string.
    • Measure the width between the rims of the motor pulley that the belt can pass through (usually 0.250 inch).
Jul 08, 2009 | Audio Players & Recorders
How to remove platter from AKAI AP-B110 turntable
On my Akai turntable, I have to remove the fiberboard bottom cover (nine screws, nothing tricky) then there's a central brass air bearing with a small set-screw in the side. Loosen the screw, and the central turntable axle lifts right out of the bearing.
This is a belt-drive Akai - your mileage may vary.
Mar 24, 2009 | Audio Players & Recorders
199 people viewed this question
