Question about Health & Beauty
How to remove back tire from scooter - Health & Beauty
    New Friend:
  • 21 Answers
Let me know make and model and I will try to help
Posted on Nov 11, 2014
How do I change back tire on a Toa Toa 50 cc scooter?
A single bolt with a cotter pin holds the rear wheel on the axle, covered with a plastic dust cap. Remove the cap, Remove the pin, then use a pry bar to hold the wheel in place while you undo the axle nut. Once removed, tap the end of the axle with a rubber mallet or use a piece of wood and a hammer until the wheel comes loose. Remove, use motorcycle tire tools to remove tire, replace tire, and remount wheel. Use a new cotter pin.
Sep 28, 2014 | Motorcycles
How do i replace rear tire on 1999 yamaha 125cc scooter?
- Back End Removal" on YouTube
Yamaha Zuma 50cc - Back End Removal this is the closest thing I have found but maybe you can get a hint from this video to give you a better idea
May 02, 2014 | Motorcycles
Pursuit XL scooter, rubbing sound during right turns...
My first guess is that you have either loose lug nuts(5)on one or more of the wheels, or you have loose screws(6)that hold the wheel rims together as these have split rims. This is more common on scooters with flat-free tires as the tire and the foam insert will chafe against each other and produce a rhythmic sound as the wheel rotates. Try tightening all of the lug nuts first and see if that helps. If it persists, try removing the tire by removing the 5 lug nuts and pulling it off the axle. You'll see six bolts that hold the rim halves together. Re-tighten all of these and install the wheel to see if that cleared the noise. Note: The real wheels have a key-slot in the axle and a key which slides into this slot to hold the tire to the axle. Be careful not to lose the key when you slide the wheel off, and be sure to get the key back in the slot when you install it back on the hub. Here is the page for your scooter. Click on the owners manual and scroll down to page 37 for info on tire removal.
Jan 10, 2013 | Pride Mobility Pride Pursuit XL 4 Wheel...
How can I put chain back on my E200 razor electric scooter?Everything is in the way.
First your going to remove the deck.
Take off the chain tensioner
Next remove the motor and put the chain around the gear
Put the motor back on the scooter with the chain on
Then take the rear wheel off and put the chain into the gear.
Put the rear wheel back on along with the chain tensioner and deck
Your done!
Note: the reason why I say you have the remove the motor and wheel is the get the chain on. So you may only have to partial remove the motor or tires to get the chain on.
Apr 24, 2010 | Razor E200/300 Electric Scooter Battery
Air preassure in victory scooter
Most electric mobility scooters with inflatable tires require a tire pressure of 30-35 psi (be sure to check the manual of your scooter for the correct tire pressure). Do not allow the tires to become under-inflated or over-inflated. Under-inflated tires could make the scooter unstable and over-inflated tires can burst under pressure. Also, you should manually inspect the tires periodically to make sure they haven't taken any serious damage that could lead to a flat.
Jun 15, 2009 | Pride Mobility Victory 3 Wheel Electric...
Antitipping wheels dragging.
if there tires are the right pressure, sounds like the bar that holds the wheels has either come loose if possible or been bent downwards, I don't recommend you removing them.
Apr 18, 2009 | Pride New Mobility Celebrity 3 wheel...
Flat tire on Schwinn S350 electric scooter
Schwinn is a American company, so have no fear of your propose situation happening. But removing the chain is simple just un screw the motor and pull it out. After that the chain will be lose.
And for changing the tire follow my tire changing guide.
http://www.fixya.com/support/t5389765-bought_razor_pocket_mod_scooter_second
Oct 07, 2008 | Transport Schwinn Rechargeable Portable ...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
