Question about Worldwide 2003 Ford E350 Econoline 6.8L Alternator - 130 Amps
On my 2003 E350 I have only 6 volts to my fuel pump with a new relay when I jump my contacts it gives me 12 volts
I took it to a local mech he told me it was the fuel pump when I removed the tank I checked the voltage at the pump connection found I wasn't getting the correct voltage
    Habit-Forming:
  • 76 Answers
Change the fuel pump relay.
Posted on Nov 11, 2014
My 1993 E-350 club wagon wont start Code: 542 =
Replace the TCM to fix the converter clutch problem.. The line 12 volt is direct power from the battery and 7 volts out the I am suspicious off as I think that the coil for the relay is partially shorting out to give the 7 volts. As for the other wire 12 volts in would be ok but if there is nothing out unless it is a relay that has not closed because the relay coil has not activated correctly.. Check the readings against a new relay.
Nov 01, 2013 | Cars & Trucks
30amp auto shutdown fuse blows is it alternater
The ASD relay supplies battery voltage (12+ volts) to the fuel injectors and ignition coil(s). With certain emissions packages it also supplies 12-volts to the oxygen sensor heating elements. The Fuel Pump Relay is a separate relay controlled by the ASD relay input to the PCM. Fuse #12 (10amp) provides 12 volts to the coil side of both the relays and the ignition switch. Fuse #6 (30 amps) supplies 12 volts to the output side of the relay. Fuse #16 (15 amp) from the relay output to the Oxygen Sensors and Fuse #26 (15 amp) relay output to the PCM. Fuse #24 (20 amp) is Fuel pump relay output to fuel pump. Fuse #19 (10 amp) supplies 12 volts direct to the PCM.
look for burned or melted wires in the offending circuit.
sounds like you wiggled a wire while installing new relay.
Mar 06, 2013 | Cars & Trucks
No voltage to electric fuel pump relay?
voltage comes from fuse box, should have a fuel pump fuse, check for blown fuse, if not try jumping a fused wire from 12 volts to relay and see if fuel pump runs, hope this helps ?
Sep 03, 2012 | 2002 Kia Sportage
Car will turn over but won't start. Through the
No noise from fuel pump when you turn over the car .First thing get voltage at fuel pump relay checked, is there 12 volt to the relay.If no, then problem is again the relay.--------- To reconfirm the problem, try other test, that is remove the relay and by pass the relay terminals with a jumper wire .Then with 12 volt external battery give power to fuel pump connector and see, if the fuel pump starts, then its clear that fuel pump relay is faulty.----------- Also other problem can be fuel pump inertia switch.If the inertia switch is faulty then also fuel pump will not start.-------- The fuel pump relay on a 1995 Ford Explorer is in the power distribution
box, in the engine compartment, driver's side near the firewall.----------
The fuel pump inertia switch is in the right front passenger area
it is below the dash but above the carpet in the right hand corner.--------
Its a push button type inertia switch.
Fuel Pump Activation
When ignition switch is turned to START position, PCM operates fuel pump relay to provide fuel for starting engine. PCM senses engine speed and shuts off fuel pump by opening ground circuit to fuel pump relay when engine stops or engine speed drops to less than 120 RPM. When ignition switch is in ON position, EEC power relay is energized (contacts closed). Power is provided to fuel pump relay and timer in PCM. Fuel pump receives power through fuel pump relay contacts.
Inertia Fuel Shutoff (IFS) Switch
All models use an electrical interrupt switch in fuel system. During a collision or vehicle rollover, electrical contacts within inertia switch open, shutting off fuel supply to electric fuel pump. Fuel supply is interrupted even when engine is running.
A reset button is located on switch assembly. If electrical circuit trips, vehicle will not restart until switch is reset. Fuel system should be inspected before resetting switch.
IFS switch is located under instrument panel, near right side of transmission hump.
----------- If the fuel pump relay, the inertia switch and fuel pump all checked ok, and fuel pump is working with direct 12 volt source to fuel pump.Then problem relates to computer.The computer (power control module, PCM) is faulty and has to be replaced.--------- This will help.Thanks.Helpmech.
Jul 17, 2011 | 1995 Ford Explorer
I have replaced my fuel pump and fuel pump relay and the car(1988 Lincoln Town Car) ran fine for two months. Now it will not start. The fuel pump relay has 4.6 volts when the ignition is on, it is not...
Have to look at a wiring diagram to figure that out
At least I would.
Does the relay energize in your hand,
with batt & grd on coil & ohm meter on
it's contacts, to see if their burnt?
e.g. do you need 12 + volt for it to work
Your looking for a voltage drop ---maybe
Don't rule out the ignition switch it gets a lot of use
Jun 12, 2011 | 1988 Lincoln Town Car
Fuel pump not coming on,installed new one, white plug that has a yellow wire has 5 volts and ground is ok the 2 wires in the center shows 0
The plug you are referring to is probably the fuel tank pressure sender not the fuel pump. It would be plugged into a black sensor about 2 inches long pushed into a rubber grommet on the fuel bung. The fuel pump connector would have more that 2 wires going to it. most likely a heavy purple wire would be the power to the pump. It has to have 12 volts to it to work. The sender may have 3 wires, 5 volts, ground, and sense. the pump connector would have 12 volts, ground and 5 volts for the fuel gauge sender down in the tank.
If the 12 volts is not there, check the fuel pump relay. it is usually up on the drivers side firewall.
With the key in the on position without starting the engine, you should have 12 volts to the pump for 3 seconds then it will click off. Without cranking the engine you should be able to locate the relay by the clicking sound.
There is also the obvious, like checking the fuel pump fuse.
Jan 11, 2011 | 2003 Chevrolet Avalanche
Fuel not getting to intake
check to verify there's fuel pressure at fuel pump, always check for blown fuses first. if the fuel pressure is not present at the fuel rail then the pump is bad, providing that all fuses are good.
Apr 26, 2010 | 1992 Chevrolet Camaro
I have no power to the fuel pump unless I jump at the diagnosis under hood. I have 12 volts to the circuit opening relay and with the key turned forward I also have 12 volts to and the leg on the co relay....
fuel pump only runs for 3 seconds or when the engine is running. Cycle key with meter hooked up or ear on gastank.. Listen and watch. for a quick 3 seconds.. The spark your experiencing is most likely your touching a ground connection. If you have 3 seconds of power then you prabably need a fuel pump.
Aug 15, 2009 | Toyota Pickup Cars & Trucks
1987 GMC sierra , no fuel pump power.
The inline fuel pump fuse on the passenger side firewall is good? Are you jumping it with 12 volts at the test lead or the fuse?
Jun 26, 2009 | 1987 GMC V1500
Worldwide 2003 Ford E350 Econoline 6.8L Alternator - 130 Amps Logo
Top Worldwide Electrical Supplies Experts
Lawrence Oravetz
Are you a Worldwide Electrical Supply Expert? Answer questions, earn points and help others
