Question about Garden
How do I replace the upper drive shaft on a Ryobi RBC430SEC brushcutter?
    Habit-Forming:
  • 47 Answers
I couldn't find this model on google, but when replacing drive shafts in most brushcutters we used to slide the cutting head / gear assembly off the bottom of the shaft, remove the circlip holding the drive shaft if there was one, slide out the shaft from its square hole in the clutch at the motor end. If the shaft was broken we'd slide the motor part off the shaft to get the broken part of the shaft out.
Posted on Dec 31, 2014
5 Suggested Answers
boscia
  • 163 Answers
SOURCE: Ryobi TP30 straight shaft line trimmer convertible - drive shaft disconnected from motor
check both ends of shaft, they're usually a hex or torx head. sometimes the can strip or even snap off. if you find noticable damage replace the shaft
Posted on Nov 29, 2008
  • 376 Answers
SOURCE: Replacing Drive Shaft for a Ryobi 725r
The lower flex shaft should cost around $40, unless you order it online and have to pay shipping. You should be able to get one from your local MTD dealer. (Ryobi is owned by MTD)
Posted on May 25, 2009
  • 1341 Answers
SOURCE: Do I need Special grease for Brushcutter/Trimmer shaft
No grease is grease but there is sillicone used nowadays as it just looks clean to use. Now check if it does use some kind of oil in the system.
Posted on Aug 03, 2009
  • 2239 Answers
SOURCE: how do I compress piston rings ,when replacing piston in ryobi brushcutter?
Buy a small set od plastic ring compressors, they are readily available from small engine shops.
Posted on Aug 10, 2012
How do I replace trimmer line Ryobi RBC30SESNB brushcutter
You can find Ryobi Manuals at the website below. Page 9 talks about string replacement/line replacement
Ryobi RBC30SBSNB Manuals
Dec 06, 2016 | Ryobi Garden
Ryobi weed eater upper and lower shaft spins, but head doesn't spin, why?
If not a clutched model, likely the flexible drive shaft is broken. Check 1st to insure the engine head is firmly positioned into the aluminum shaft case. If it is remove at the engine, disconnect the cable as necessary and pull out the shaft for close inspection.
May 02, 2014 | Ryobi Garden
How do I replace piston in ryobi brushcutter
they make a tool to compress them then push the piston down and install the pin and clips
Aug 08, 2012 | Ryobi 30cc 17" String Trimmer Zrry30530...
I have a Ryobi RLT 30CESA with the strimmer attachment. What do I need to fit a Brushcutter blade to it
I would not put a brushcutter blade on this unit. The curved shaft quik disconnect may not hold up to the shock torque created by the brushblade. It may damage the drive shaft since it is a curved shaft quik disconnect model. You may have to purchase a straight shaft trimmer to get that job done.
Oct 02, 2009 | Garden
Aug 03, 2009 | Garden
Jun 30, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
104 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
