Question about Kodak Hero 9. Inkjet Multifunction Printer Color Photo Print Desktop
Why instead of my Kodak Hero 9.1 printer appears the Microsoft XPS Writer when I'm trying to print the document online?
When I clicked as always "Print" it showed me in the window "Printer" the "Microsoft XPS Writer" instead of my set up Kodak Hero 9.1. Please HELP!!!
    Sergeant:
  • 195 Answers
Go in to device and printers and change default back to ur printer. probs office or some other sw hijacked printers default setting
Posted on May 19, 2015
SDtester
  • 41 Answers
SOURCE: 2 Problems: 1) Unable to get printer to print from desktop; 2) Kodak SW won't install on laptop
Download and install the new software and printer firmware from kodak.com (link below - firmware and software is the same for all the 5000 units). Do not use the CD, and Uninstall all previous versions before installing the new software you download from the site.
http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?operatingSystem=mac_os_x_10_5_x&downloadLanguage=en
I hope this helps. If you still have problems respond to this message with what happens and I will try and get you more help
SDtester.
Posted on Mar 05, 2008
  • 19 Answers
SOURCE: My printer Kodak ESP 3 does not print word document
Have you called tech support?
Posted on Jan 14, 2009
SOURCE: My Kodak ESP 5 Won't print entire documents, only first page
Scott,  If you are using Mac and Adobe 8 or 9, see solution from Kodak site at:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=12998/7269&pq-locale=en_US
Posted on Feb 22, 2009
  • 59 Answers
SOURCE: Won't allow me to print
in the start search typy printers & hit entre then u will get the printer page open then try n make your current print default by right clecking in your printers icon, u will no longer have this problem
Posted on Mar 30, 2010
Geekman
  • 32281 Answers
SOURCE: printer won't print in colour, keeps saying recalibration needed
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Posted on Sep 27, 2012
Hi there
This can happen. Go to Control Panel > Devices and Printers.
Here you should see a hardware list of icons, including both your Kodak Hero and the XPS Writer. If the Kodak Hero is not there you will need to re-install the drivers and software from the disk which came with the printer. However, if it is there all you need to do is right click on the Kodak icon and from the menu that comes up click on "Set as default" and a green arrow should appear against the icon like this showing that the Kodak is the default printer and will show up first in any programme from which you print. 25277964-2fs4ue52shjy2lvm2lcqhtal-4-2.jpg
Cheers
Nov 10, 2014 | Office Equipment & Supplies
Unable to create pdf in Quickbooks 2008 pro running in Win 8
To make sure you do not encounter PDF issues in the future, always make sure you are on the latest release of QuickBooks. go to this link Unable to reconcile accounts or to create print or email pdf files and follow the steps for under How to fix it for 2010 and older QuickBooks versions only and if need any help follow http://www.techsupportquickbooks.com/intuit/ .
Sep 30, 2013 | Intuit QuickBooks Pro 2008: Windows
I try to print something and it takes me to a page that says save as xps file, but every time i hit save, nothing happens!
Do you have your printer properly installed in the system?
Go to control panel, printers, and see what printers you have installed. Among them there will be a "virtual" printer called "Microsoft XPS writer" - it is a special "printer" that saves your document in a special type of file. Not very useful in your case.
Do you see any other printers apart from the above mentioned? If so, then most probably the "XPS writer" is set as default printer, and you have to select the actual printer you have (I presume it will be HP Deskjet D4260, as in the topic), right-click it and choose "set as default". Then you should be able to print OK from whichever application you want to print.
Additonally, when you select File->Print from that application's menu, it will show you a window, where the chosen printer is specified; you can always open the drop-down list of printers there and select a different one (your actual printer).
If there are no other printers on the list apart from the XPS writer, it means that your printer is not installed in the system, and you have to install the driver from a CD that came with the printer. Or if you don't have the CD, go to the HP website, download and install the driver for your printer.
Good luck, and please come back with a testimonial if helped.
Aug 03, 2010 | HP Deskjet D4260 Printer
Avery design pro will not print with my HP C5500
I found an odd workaround. Probably a better one available, but this worked for me. When you select Print from Design Pro, in the printer drop down box select Microsoft XPS Document Writer instead of your printer. Click OK, enter a file name, and save. That will save a .xps file. Next, open the .xps file and print it.
Dec 13, 2009 | HP Photosmart C5580 All-In-One InkJet...
Printer problems
hi, you mentioned that your default printer is the xps document printer. if you already have a 5300 printer icon, you can simply right-click on it and left-click on set as default printer to make it your default. but if you still dont have an icon yet, better still, call kodak tech support at 800.421.6699 so they could assist you in generating one
Oct 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Photosmart 2575 printer is offline - won't print
In Vista make sure you are logged in as a administrator whenever you make any changes.
And if not to bring the printer online you will have to right click on the printer icon and right click on Run as administrator> and then try bringing the printer online and checdk if it works.
And you can delete the Microsoft XPS Document writer it is a default printer icon installed if in case you did not have a printer installed you can store them to print later.
Now that you already have a printer you can delete the Microsoft XPS Document writer.
Good Luck
Oct 02, 2008 | HP Photosmart C7180 All-In-One InkJet...
Good Day,
One thing you can try instead of deleting the doucment writer is to change the default printer. You can do this by right-clicking on the HP printer icon and selecting "set as default" from the drop down box. Also try turning the printer off and back on aswell as restaring the computer if you have'nt already. Did that printer ever work from that computer? How is it wired, by "switcher" do you mean a shared printer through you network(was printer sharing configured properly), or an A-B printer switch. Please clarify
Hope this helps for now
Jul 01, 2008 | HP Photosmart C6180 All-In-One InkJet...
Hey jonboy - You do not want to delete it. It is automatically installed with Vista. In simple terms, you know when you go to print something and it asks you questions like print all pages, print page 1, etc? Well XPS basically is there for so when you go to print, you have the option of printing to a file instead of paper. You've always had that option ( whether or not you knew it) but this is just a new way of doing it and that's why it's listed under printers. It's sort of like a virtual printer. I'll say no more about that and just hope you understood what I said. As far as the other printer, it's already selected as default, go back in where you found the printer status, right click on your Photosmart and click on use online. That should do the trick.
I hope you understood this stuff. If this solves your problem PLEASE rate this as fixed. If you still have a problem, DON'T RATE it yet just add a comment and I'll be happy to assist you further. Thanks.
Jeff
May 09, 2008 | HP Photosmart 2575 All-In-One InkJet...
Printer will default to "save as" screen when que to print
In administrator login the default printer is "Microsoft XPS Document Writer", make sure that the default printer is the HP Printer.
OR
You have to change in the Print dialog box, select the HP Printer instead of "Microsoft XPS Document Writer"
Cheers - Parveen
Feb 08, 2008 | Dell Inspiron 1501 Notebook
"please insert card'
reboot pc and unplug printer
Nov 13, 2007 | HP Photosmart 8250 InkJet Printer
Kodak Hero 9. Inkjet Multifunction Printer Color Photo Print Desktop Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
