Question about AMI - All Sales MFG 1994 Ford F150 AMI Billet Aluminum Interior Dash Knobs
Fuses ok cutoff switchnew steerihg wheel switches are good.but still wont work.
Where is the fuel cut-ofF
THE SWITCH EITHER BEHIND ONE OF THE KICK PANELS INTHE FRONT OF CAR OR INTHE SIDE PANELS INTHE REAR NORMANLLY IT WILL HAVE A PUSH BOTTON ON TOP TO RESET IT
Jun 06, 2015 | 2007 Hyundai Getz 1.4
Wont start
The only reset switch is the a fuel pump cutoff (inertia) switch located in the trunk near the driver's side rear wheel well. You'll see it if you peel the carpet back a bit - it's the red button in the black housing. However, that won't keep it from cranking.
Do you have an aftermarket remote car starter or alarm system? If so, start looking at that first - you may have an immoblizer switch in the hood. It's designed to keep you from starting your car when the hood is up. If it fails, it could keep your car from cranking. You may also have a "hidden" immobilizer switch somewhere in your car, typically under the dash.
Check your fuses/relays, including the ones under the hood. Your owners manual will tell you which are which.
Apr 05, 2014 | 2002 Ford Crown Victoria
Kenmore dryer model # 110-60212990 heater element not working. replaced element, thermal fuse, thermal cutoff
Hello
Check high limit thermostat continuity. If ok ,Check for voltage at thermostat side of the heater element.If voltage present timer ok.Most likely centifugal switch at motor.Motor has to be running for element to work.
It's all fixable!
Jul 28, 2011 | Kenmore Dryers
My 2004 expeditions air suspension stop working but the monitor says the air supensions is ok I was told to check the fuses but i am having a hard time removing some of the fuses to check it, especiaaly...
The air ride fuse shouldn't be that high amp. Check the air suspension cutoff switch. It should be under the right side of the dash and may have been switched off in error by a passengers foot.
Jan 09, 2011 | Ford Expedition Cars & Trucks
I need to know what fuse that powers the fuel pump in my 1999 ford expedition it has a 5.4 va 4 wheel drive
OK, there are fuses on the driver's side down below.
But, if you are having a fuel pump problem, it's likely that the fuse is alright and you need to replace the fuel pump. Same thing happened to our 1999 Ford Expedition Eddie Bauer Edition. It quit working. And the inertia fuel cutoff switch didn't help, either (flipping or pushing it).
So, if you have no fuel coming, it may very well be the fuel pump.
We changed ours around 112000mi.
Jul 17, 2010 | 1999 Ford Expedition
Dryer wont start when button is pushed.the thermal fuse was tested (good) the high limit thermostat was replaced as with the thermal cutoff. I did notice an abnormality on the cap of the electronic control
Did you check the door switch? Electronic control could be an issue but start with the basics and you have covered most of them already... good job.
Eric
Jun 12, 2010 | Kenmore 66862 Dryer
97 caravan ac wont kick onfuses are good and so are relays and has new compressor
Make sure you have enough refrigerant in system if ok check your low pressure cutoff switch, its probly open or wires are not hooked up tight.also check wires to compressor itself.
Aug 30, 2009 | Heating & Cooling
2002 Jetta TDI wont start, Battery is good, turns over it seems like no fuel is being pumped wont fire. glow plugs changed 10k km ago. alternator is good, timing belt is good its not ripped when the...
If you're car has been running fine, then suddenly won't start, the cause is frequently that the fuel pump cutoff has been tripped. Open your trunk, and look for a label for a fuel pump cutoff switch. Locate the switch, press it in, and see if the engine will start.
Jul 05, 2009 | 2002 Volkswagen Jetta TDI
Brak lights dont work
they is a switch under steerihg wheel that isnt makeing contact which is for the turn signals and emergency flashers is needs to be replaced or try to take some electrical contact cleaner and spray it in where u trun the emergency flashers on push them on and off while spraying this in there then check the brake lights if it dont work then replace the switch not expensive
Feb 12, 2009 | 1989 Oldsmobile Cutlass Supreme
98 ford escort fuel pump wont turn on after beating out dent
try looking for the fuel shut off button in the trunk or along the fender under the rug it will reset the pump it is a shut off in case of accident push it in it will be red
Jan 20, 2009 | 1998 Ford Escort
AMI - All Sales MFG 1994 Ford F150 AMI Billet Aluminum Interior Dash Knobs Logo
80 people viewed this question
Top AMI - All Sales MFG Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you an AMI - All Sales MFG Hardware and Accessory Expert? Answer questions, earn points and help others
