Took my comfort glow propane wall heater apart to clean inside how do i put it back together
    Scholar:
  • 146 Answers
What is the model number for the heater you have taken apart?
Posted on Nov 11, 2014
5 Suggested Answers
SOURCE: I TOOK ME KEROSENE HEATER MODEL (2304)
The link below will take you to the manual for your heater.
http://www.yourheater.com/DH-2304(Eng).pdf
Posted on Feb 28, 2009
SOURCE: kozy world propane wall heater. The pilot light will work
Sounds like you have a common problem with infrared heaters. They are very dust sensitive and they will light and then go out when they are dusty. If you have already tried to blow it out at home you need to take the heater to your propane dealer who will take the heater apart and blow it out correctly. They will then hook it up to their gas line and make sure that the problem is fixed. I hope that you haven't blown up into the bottom of the heater where the gas line is connected. There is a diaphragm up in there and if you blow into it you risk messing it up to where it won't work at all.
Posted on Oct 19, 2009
wilsodfarm
  • 986 Answers
SOURCE: Have a Dyna-Glo. Took it apart to change the wick
take the wick back out lower your nob and install wick, I hope this help you, I have made this mistake too
Posted on Oct 23, 2009
SOURCE: COMFORT GLOW PROPANE HEATER, THE PILOT LIGHT WILL NOT IGNITE
i vacuumed the line out, i taped the angle adapterso there was only a little bit showing and stuck it on the pilot hole for 3 minutes (I turned the gas off) and it fixed it
Posted on Jan 21, 2010
My propane gas wall heater does not turn off when it reaches its set temperature whats the problem
It has a thermostat that should shut it down, locate and clean if you can, try again , if it still is doing that have the temp sensor replaced
Jan 08, 2015 | Desa International Comfort Glow Infrared...
Tru glow propane heater plaques not burning properly
They need cleaning along with the injectors /lack of air .
Nov 11, 2012 | Desa International GWP20T GLOWARM Wall...
Can a Pentair minimax NT that is fitted for natural gas be retrofitted for Propane use
Probally the easyest convertion on the market. Where your gas line comes in the heater the line loops up over and down. There are two unions on this at the base of the loop. take these apart and their is a washer in one and you replace it with the Propane washer and put back together.
Sep 01, 2010 | Pentair Minimax NT Heater
I bought a comfort glow vent-less space heater model # CJ18NL. It had a natural gas valve on it and the guy said I could put on a propane valve, which I did. It's not lighting. Is this model only good...
According to the Comfort Glow Website, this is a Natural Gas unit. If you use propane you will need
a minumum 100# LP Cylinder and a pressure regulator. I have a Comfort Glow unit and went through the same process.
If you have it hooked up to a 30lb cylinder without a regulator I would think that if you purged the gas line
of air you should be able to light the pilot.
On a new unit you can expect to push the spark ignitor button at least a dozen times while holding
down the gas valve button.
Good Luck
Feb 19, 2010 | Desa International GWP20T GLOWARM Wall...
Have Model CGP30TB Copmfort Glow propane heater. Pilot light won't stay lit. Flames also coming from what seem to be air vents just below flame on pilot light.
sounds like an obstruction in pilot assembly.try using canned compressed air to blow directly into pilot. this technique is successful about 70%. if not,pilot assembly must be removed and cleaned thorougly
Sep 10, 2009 | Desa International Comfort Glow Infrared...
Machine seems clogged
Hello, i just finished a successful repair. i did have to take it apart, and there were springs and ss balls(at fog liquid pickup end that i unscrewed to give easy access to blocked pipe) and such so work where parts won't be easily lost and pay attention during disassembly. The problem with mine(several years old) was blockage in the metal line(pipe) that carries the fogger liquid. i used carborator cleaner and a compressor hose with low pressure. i sprayed in the cleaner and then put air pressure each way back and forth till it eventually yet suddenly cleared out then allowed unobstructed passage. then flushed it to clean it well. BE CAREFUL, it can suddenly spray the cleaner out, safety glasses saved me from a bad accident but my face and lips were stinging from the cleaner, and that was with the end facing away from me(but into a bucket and it bounced back at me). Anyway, reassembly took a bit but now it fogs great again. Mine might be a different manufacturer(burgess) but most likely the same basic scenario. Best wishes
Jun 27, 2009 | Fountainhead/Burgess Prod Black Flag...
Propane heater has spark but wont light
ODS/Pilot may be clogged make sure you clean it out according to the instructions in your owner's manual. If you need a copy of the manual let me know and I will try to find it for you. If it is still not working it could be the gas regulator or the ignitor cable. For Glow warm parts contact Master Parts at 800-446-1446 or you also can find them online at www.masterparts.net. I hope this helps you!
May 04, 2009 | Desa International Blower Glow Warm Wall...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
