Question about Kodak Moviedeck 475 Super 8 and 8mm Movie Projector Owners Manual
Kodak moviedeck 475 projector..keeps going to rewind...will not play movie
Will not play movies, plays forward for a few seconds and then automatically goes to rewind.
yvonmagic
  • 82 Answers
SOURCE: Kodak easyshare m1063. Windows Vista will not play movies.
hi , you have to dounwload , ( quick time ) programme i know i have one just like you , let me know Yvon chow !!!
Posted on Jan 02, 2009
benj888
  • 47 Answers
SOURCE: What format does a .mov need to be converted to to play on a DF?
You can try these these file formats and compression rates:
1 utf-8 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} File Format: MOV
Video Compression: MPEG-4 ASP, MJPEG
Audio Compression: MP3, G.711, PCM, ADPCM, 8-bit linear
File Format: AVI
File Format: MPG / MPEG
Video Compression: MPEG-1
Audio Compression: MPEG audio
You will have to look for a free video editing software and use it to be able to follow the above formats.
Posted on Jan 04, 2010
  • 412 Answers
SOURCE: problems with using a 140 carousel on a Kodak 4600
There is nothing wrong with your slide trays. Your projector needs an adjustment to the cycle contact assembly. The constant cycle mode is a dead-giveaway. You need to take the projector to an Authorized Repair Dealer for this adjustment. Should be relatively quick - - it takes longer to get the case apart than to make the repair!
Posted on Nov 04, 2010
  • 412 Answers
SOURCE: Automatic slide changer is stuck in
The problem is continuous cycle (like you don't know that already...). It indicates that an adjustment to the cycle contact is necessary. To open the projector, first unplug it and remove the lamp module from the rear of the projector. Turn the projector upside down. Remove the 6 - T15 TORX screws from the bottom (5 around the perimeter and one in the channel next to the cord wrap). CAREFULLY pull the bottom off (the power wires connect the bottom cover & top together!!). Once you have it open, leave the projector upside down, put on your safety glasses & plug the projector into the wall. At the center of the projector you should see a hub rotating about every second or so. Above it you should see a "J"-shaped wire. See the attached illustration.
You will have to, in repeated steps, unplug the projector, bend the "J"-shaped wire GENTLY & SLIGHTLY, plug the projector back in and cycle it a few times. Check for the position of the "J"-shaped wire to the pad, and GENTLY repeat until you achieve the position shown in the illustration.
Posted on Dec 30, 2010
  • 412 Answers
SOURCE: manual for kodak ektasound moviedeck projector 275
Check with www.micro-tools.com for parts and manuals!! They have an amazing inventory of classic Kodak parts for slide & movie projectors! Good Luck !! Jim
Posted on Jun 25, 2012
Set on Run Forward and after a few seconds it goes to rewind by itself
Hi i need more information about the material you used.
It's a VHS player?? or really old Super 8?
If it's VHS tape the problem is that the tape is too old and is glued by the age and climatic., you to forward all the band manually and after retry in the player. Have a nice day
Nov 10, 2014 | Televison & Video
How do i get a sony microcassette transcriber m-2000 to play/rewind/fast forward continuously?
Probably has a bad sensor belt (small belt attached to silver and black reflective wheel).
Aug 07, 2014 | Sony M-2000 MicroCassette Transcriber...
The VCR shuts off after just a few seconds of playing or rewinding or fast forwarding. The tape goes in, and when you push play (or any direction), the unit will try and play it and then it will shut the...
There is a part that is called an idler wheel assembly that is critical for play, rewind, and fast forward, and may have stopped working. The second possibility is that the drive belt that runs the idler assembly has broken or come off.
Jan 01, 2011 | Philips DVDR3435V/37 DVD Recorder/VCR
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Dec 07, 2010 | Dictaphone 1740 Desktop Cassette...
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
I want to play a movie on my vcr but when i puch
You will have dirt on the heads, the picture will show through when you scan as it is travelling past the heads at a faster rate. Either try using a head cleaning tape or remove the top cover & very gently use a head cleaning fluid (eg. isopropal alcahol) with a head cleaning stick or clean piece of card (Do Not use a cloth or cotton bud etc) very GENTLY with not too much pressure wipe the heads on the side of the head drum (the round center silver object) DO NOT apply too much pressure as you can damage the heads easily, wait a few minutes for the fluid to dry then try to play a tape.
Aug 08, 2009 | RCA Televison & Video
Video tapes only paly for about 2 seconds then stops
The heads need cleaning and/or the tapes are old and dirtying up the playing heads.
Run a wet tape head cleaner through an see if this improves.
May 23, 2009 | Televison & Video
Forward and rewind
hey...in k810i,a video can be played(viewed) from two locations. One is through the file manager>Videos. You cannot forward or rewind when you open the video file through this method. Alternatively, you can open the same video file through Entertainment>Video Player. You CAN forward or rewind using this method by holding the joystick towards right for forward and holding the joystick towards left for rewind......
Dec 08, 2008 | Sony Walkman NWZ-S616F MP3 Player
VCR plays for a few seconds and rewinds. Now, the VCR plays tape in fast forward mode
Most everyone I know had problems with the tv/vcr combo including myself. I'll never buy one again. I'm sorry you are having the same problem.
Aug 28, 2006 | Quasar VV-2002 20 in. TV/VCR Combo
Kodak Moviedeck 475 Super 8 and 8mm Movie Projector Owners Manual Logo
67 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
