Question about Water Heaters
Does the Maytag hot water heater model number 153.335440 have a flame arrestor?
  • Water Heaters Master
  • 5,089 Answers
Maytag has not sold water heaters for a long time..
If water heater is older than 10 years, then it probably does not have arrestor.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Gene
Water Heater Timers Save Money
Posted on Nov 18, 2014
co7196
  • 3433 Answers
SOURCE: The Pilot burner flame is large & yellow
the pilot is getting too much air and is an indicaiot of dirty or air/ fuel ratio imbalance. The pilot is wimpy and the thermocoupler has alot to do with the gas . Make sure your thermocoupler is on the tip of the flame. You may end up replacing it. because it is showing signs of eminnt failure. When it fals your curners won't fire up. Good luck.
Posted on Jun 09, 2009
WonderTech
  • 268 Answers
SOURCE: water heater not firing up
Make sure thermostat is turned to 120 to 150 degrees Fahrenheit. Turn the thermostat down and back up to see if it ignites. If it lights put the cover back on and set it to temp you want it to be. if not, you have a bad thermostat.
Hope this helps.
Posted on Aug 14, 2009
SOURCE: Our electric water heater doesn't work.
make sure it is wired correctly, check circuit breaker, check breaker built on to element. If all fails, and it is determined your not getting power to it, you may need a electrician. Be careful. good luck.
Steve
Posted on Oct 11, 2009
Gort007
  • 1187 Answers
SOURCE: Atwood water heater - pilot light and flame malfunction
Michael,
The thermocouple sensor may not be in the best position to sense that the pilot is lit.
Adjust the thermocouple mount or simply bend the thermocouple "wire" so that the pilot flame is touching the tip.
Posted on Oct 13, 2009
  • 7 Answers
SOURCE: no hot water in electric water heater
warranty is 6 yrs on parts
Posted on Mar 17, 2010
Richmond 5v40-7 gas water heater. Burner lights completely but flame is very low. Does not grow above 1/4 inch.
Is flame clear blue or yellow?
Yellow flame, clean the flame arrestor screen
Flame is blue:
Low gas pressure.
Bad gas control valve.
Dirty combustion parts.
Clean the water heater parts and catch up on maintenance.-
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Gene
Nov 01, 2014 | Water Heaters
Rheem water heater about 3 years old. No hot water.
Get more fresh air to unit and see if that improves problem
Low gas pressure
Bad vent
Lack of maintenance/ dirty combustion parts
Low amount of fresh air/ dirty air intake/ flame arrestor screen
Rheem will tell you to call service technician
Gene
Oct 20, 2014 | Water Heaters
Digital signal
air in gas line
clogged manifold tube
clogged burner ports
inadequate venting
screens prevent flammable vapor ignition.
Otherwise no danger.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
http://waterheatertimer.org/pdf/Find-Age-of-water-heater.pdf
Gene
hh
Oct 06, 2013 | Reliance & LP Gas Water Heater Control
Rheem hot water heater not kicking flame to high heat
1) Copy following link to troubleshoot by type of gas control valve:
2) Bad gas control valve, low gas pressure, dirty combustion parts, inadequate venting, clogged flame arrestor screen located under burner
Mar 06, 2013 | Rheem Water Heaters
Hot water heater womt light, flammable vapor sensor code
Most likely: Combustion chamber got too hot because air intake is clogged with dust, causing less air to flow upward through vent pipe ... the slowed flow of air caused combustion chamber to overheat.
What brand and model water heater?
Look at label on side of unit and add comment.
Otherwise call service tech to repair/ replace water heater and clean arrestor screen (air intake) and replace or reset parts as needed, depending on model number and brand water heater.
AO Smith, Bradford white, and Rheem are main manufacturers.
Each has slightly different repair protocol, and each gas control valve can also be different. So more information is needed.
Identify gas control valve:
Rheem TRD/ FVIR glass vial
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
How to remove combustion parts to inspect for Rheem glass vial and clean arrestor screen located under combustion chamber:
http://waterheatertimer.org/How-to-replace-thermocouple.html
Sep 30, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Reliant 501 Natural Gas won't stay lit
Reliance water heater?
Thermocouple is good if the pilot stays lit continuously.
501 is older model. Unknown if this unit has FVIR protection and sealed combustion chamber or open air intake on front of unit.
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
With FVIR protection:
Get more fresh air to the unit.
Clean the flame arrestor screen.
Test and replace the thermocouple:
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Inspect and clean burner and combustion parts
Test gas pressure, bleed air out of gas line.
Replace gas control valve.
Test draft air by lighting match and see if smoke is pulled into the vent pipe at draft hood on top of tank.
Aug 20, 2012 | Water Heaters
Water Heaters Logo
43 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
