All cd's piled up and had to dismantle Sony CDP c250z to remove them. Have it apart and wonder how tight or lax the belt should be. All the teeth are there, no obvious cracks, but a bit droopy.
    Champion:
    Habit-Forming:
  • 239 Answers
They should not slip because of the teeth, if they were too tight it would slow it down
Posted on Nov 11, 2014
SOURCE: Sony CDP CX 235 200 cd changer-cd's dropping off
Hi there.
I reckon that they are not being put back correctly by the loading mechanism! This is a common problem with these units. It is highly unlikely that they are actually falling off the carousel.
Open the unit, and watch it as it loads and replaces the cd's from the carousel. You will probably find that instead of grabbing the disc off of the spindle and putting it back, it might be grabbing before the cd is even in its grip. This then simply bumps the cd out of the way, and it will fall inside of the unit.
The good news is that it can be fixed with a bit of very gentle bending and persuading. But be very carefull when doing this!
Good Luck!
Posted on Mar 07, 2009
  • 4234 Answers
SOURCE: Sony CDP-XA30ES CD Player
Try opening up the top and cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, look at the back side of the optics and there should be a marking like KSS-xxx. This is the generic part designation. Any electronics supplier that supports Sony should have these.
Dan
Posted on Apr 08, 2008
  • 4234 Answers
SOURCE: Sony CD Changer does not recognize cd
The C601 will not spin up the disc unless one is detected. If the optics are bad and do not realize that the disc is there...
Try cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, the optics are bad. The optics in this unit are KSS-240 (I think). This part costs about $30-$40 depending upon where you get it. You can try to replace it or have a shop replace it for you. Add in the local labor rate for the total repair cost. This is a relatively simple repair. I have done 100s. It usually takes about 45 minutes plus the testing time.
Dan
Posted on Apr 15, 2008
cdj repairs
  • 68 Answers
SOURCE: Sony CDP-CX53 rotates the carousel and inserts the CD into the playing position, but it won't play the CD
It sounds like there is a cd tray alignment problem, there is no quick fix, all i could suggest is to send it to us or take it to your nearest dealer.
Regards.
http://www.audiovisualservices.info/
Posted on Jan 02, 2009
SOURCE: Sony CDP-CX300 How To Replace Drive Belts?
The Sony call center says the two belts are the same size. Supposedly, there is a third belt "under the motor board" but I have not been able to find it. That is the 42x1.2 (4219362601). The two easy ones to replace are 421606101 and only cost 1.95 from Sony.
Posted on Sep 13, 2009
A sony cd player belts for a cdp cx355.Do you carry these belts,and how much?
http://www.ebay.com/itm/SONY-CDP-CX300-CDP-CX335-CDP-CX350-CDP-CX355-CDP-CX400-Drive-Belt-Kit-3-belts-/152184107208?_trksid=p2141725.m3641.l6368
Nov 10, 2016 | Sony Audio Players & Recorders
I need the 3 belts for sony cdp cx355 cd player. Do you carry these belts
here are the belts. http://www.ebay.com/itm/SONY-CDP-CX300-CDP-CX335-CDP-CX350-CDP-CX355-CDP-CX400-Drive-Belt-Kit-3-belts-/152184107208?_trksid=p2141725.m3641.l6368
Sony CDP-CX400 Mega Storage CD player having issues ejecting disk. Can Load Error be cause by worn and "out of tension" belts? Table turns a bit slow and when I hit disk eject
Either a loose loading belt, or a weak loading motor can cause this fault. Check it. A weak loading motor can cause more faults. If the pulling power of this motor is low, the fault will occur. Replace this motor and the loading belt first. Check whether there is any gear wheels having broken teeth.
Feb 23, 2016 | Sony Audio Players & Recorders
Hi, I have a Sony CDP-CA8ES whose turntable acts weird. It seems to be out of sync, gets stuck in the open position, doesn't position discs correctly, etc. Any ideas? Thanks, Ed
hi,
may be ur cd players mechanical alignment have some problem , teeth of loading wheel or teeth in try may be broken. just check the same. if found faulty try to replace it.
ok
Dec 26, 2010 | Sony CDP-CA8ES CD Player
In/out dial on bottom of Sony CDP-C305 ... what does it do?
It is Transit Key to protect optical lens mechanism from shocks while transportation unit. remove it before playing unit.
Aug 06, 2009 | Sony CDP-C305 5-Disc CD Changer
Sony cdp-cx235 cd skip
need replaced laser pick up part no:
Manufacturer Sony Part Number 8-848-415-13 Description DEVICE, OPTICAL
Apr 07, 2009 | Sony CDP-CX235 200-Disc CD Changer
Putting a new door on my Sony CDP CX300
u must remove the broken old door carefully by removing the rubber belt which is connected to the dc motor and bear by there be a white colour plastic which holds the door u must remove that and then u must put replacement & once again u must connect those all properly so it s difficult... just visit technician....
Feb 02, 2008 | Sony CDP-CX300 CD Player
CD player door won't open
try to dismantle the unit and check the rubber belt on the motor
Dec 23, 2007 | Audio Players & Recorders
44 people viewed this question
 Grubhead
Grubhead
