Question about Refrigerators
What can I try next to prevent my food from freezing?
I have a GE refrigerator freezing food in the fresh food section. Model #pts25lhsarbb. I had the settings at zero and 38, bet the readins the display will show at time is zero and 34 , I have check the settings and they still show set to zero and 38. Since this started we have replaced all 3 temp sensors , mother board and display board. I have even tried adjusting the temps to 4 and 42, but that has not made any difference.
    Prodigy:
    An expert who has answered 500 questions.
  • Refrigerators Expert
  • 650 Answers
The damper door may be broken. I had this problem in the past and the fresh food was too cold. I replaced the damper assembly and all was fixed.
Posted on Nov 15, 2014
SOURCE: GE Monogram freezing food
I got the same problem.
Temperarily solution:
Open the top hook overnight and you will see the temperature will return to normal i.e. 1 degree F
I suspect there is the thermostat or some type of thermal sensor that prevent the freezer to operate during summer time
Hope it help
Posted on Jul 28, 2008
  • 74 Answers
SOURCE: GE Profile fresh food getting TOO cold
Faulty air damper is the usual cause , or possible sensor fault
Posted on Aug 28, 2008
  • 833 Answers
SOURCE: Fresh food section not maintaining cold temp
You're frozen up.  Defrost completely.  Then, clean your condenser.  Make sure to never leave open containers in the fridge...water condenses into ice.  If you still have problems, you may be low on gas.
Posted on Nov 21, 2008
  • 1218 Answers
SOURCE: Refrigerator is too cold and freezes food.
Good day,
If the machine is under one year old, all working components are under factory warranty. Call for warranty service from selling dealer, or if you moved out of the area, an authorized Whirlpool warranty dealer.
Posted on Nov 25, 2009
MNTECH
  • 1543 Answers
SOURCE: ge profile refrigerator PSS27SGNA BS....unit's
Check the air damper at the back top left of the fresh foods section to see if the damper door has broken and thus not able to close. It is electrically operated, but if it breaks, you can have your exact condition occuer.
Posted on Feb 03, 2010
Stuff is freezing in fresh food section
you probably have a bad fresh food sensor, but testing that is complicated for a homeowner, I would call for service and let them replace if necessary. probably 200 to 275 for the repair
Jan 02, 2012 | GE GSH25SGRSS Stainless Steel Side by Side...
Freezing fresh food
HI,
The problem is with the damper door.Check that it is not cracked.If it is cracked then you will have to replace it with a new one.
Goodluck..
May 17, 2008 | GE GTS20ICNCC / GTS20ICNWW Top Freezer...
The food on the refrigrator side is freezing. the water line is not working so i assume its frozen as well.
Hello Tina,
The problem with it freezing in the freshfood section is going to be because the air damper that opens and closes to let cold into the ref. section is stuck open and too much cold air is entering into the ref. compartment. This is a fairly common occurence with the GE refrigs. and by replacing the fresh food air damper which is located in the upper left corner of the fresh food compartment it will open and close properly and not allow too much cold air to enter where upon it freezes everything.
GENE
Sep 30, 2011 | GE PSW26MSR Stainless Steel Side by Side...
Refrigerator inside not getting cold enough. A GE refrigerator side by side.
If it is just the fresh food section and not the freezer. Check out this link to see a GE condenser problem. Make sure to clean that condenser once a year. In most cases when the damper assembly flapper door goes bad in the fresh food section, the fresh food side will start to freeze your food. The next thing I would check is what John is talking about. Pull the freezer back panel off to see if your evaporator coil is frost over. When this happens it will restrict air into the fresh food side(refrigerator side). Click Here to see what a defrost problem looks like.
Jun 23, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE refrigerator GFSS6KKYSS Model. Serial #: LS900091 It appears that there is ice on the back of the refrigerator and water is collecting on the floor of the compartment. What is the problem and...
This is a rather unique refrigerator in that there is a seperate evaportator (cooling coil) for the refrigerator section and the freezer section, where as almost all other refrigerators only have coils in the freezer section and use a fan to blow some of the cold air into the refrigerator section. This design will prevent cross contamination of odors between fresh foods and freezer sections, and allow lower humidity freezer at the same time as higher humidity fresh foods. All good things.
That said,..... you need to take the cover off the back wall from inside the fresh foods section and thaw out the defrost drain locted at the bottom of those cooling coils. If I remember correctly, there are a couple hidden screws, and the back panel needs to be pryed off using a putty knife, I think you will find 4 small arrows / pointers for the spots to pry at. With cover removed, use a turkey baster with warm water until the water flows out the drain.
Apr 03, 2011 | GE GFSS6KKYSS
The upper portion of the freezer turns off, causing the ice to melt. And the cooler side bottom drawer turns into a freezer. I can't figure out what's going on.
You have a frost blocked evaporator. Translation: The cooling coils, located behind the back wall inside the freezer section, have plugged up with frost (usually caused by a burnt out defrost heater, located at the bottom of these coils) which prevents the cold air from circulating inside the freezer, and into the top of the fresh foods section. At the same time, this blocked air flow allows very cold air at the bottom of the freezer section to migrate back into the bottom of the fresh foods section, and thus freeze item in the bottom bins of the refrigerator. Unload the freezer, take the shelves out and remove the back panel. Melt the frost with a hair blower, and change out the heater at the bottom.
Jul 08, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Our refrigerator is freezing our vegetables. it is turned all the way down.what is the problem?
Is food freezing in the rest of the fresh food side as well, or just the food in the lower half, like in the crispers. if its freezing everywhere in the fresh food section, you have a bad cold control most likely, without knowing the type or brand, i cant be 100%. If its a GE, you could have a different issue, but most any other brand will be a bad cold control.
If the food is only freezing in the lower half, then your evaporator fan motor is likely the problem, located in the freezer
Mar 19, 2010 | Refrigerators
Ice and water not working, then freezing in refrigerator, leaking
If the water tank in the fresh food section is leaking then you will need to replace it. the freezing in the fresh food section is due to the damper door not closing when it should. at the top left of the fresh food side there is a door that controls how much cold air it gets from the Freezer side. This door on your GE is controled by a motorized door witch is controled by a controlboard witch is reading sensors in your freezer and freshfood section for tempretures.
In short your freezing problem could be any of these:
temp sensor, Motorized damper door or control board. I would check the Motorized damper door first.
Jan 07, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Fresh food side too warm
Refrigerator nguyen@ite.net 40 F or lower is the recommended refrigerator temperature to slow bacterial growth and maintain quality. Freezing occurs at 32 F; adjust refrigerator accordingly between 32 F and 40 F to prevent unwanted freezing, such as freezing milk.
http://lancaster.unl.edu/food/ciq-fridge-freezer-thermometer.shtml
Jun 09, 2009 | GE GSS25JFM Side by Side Refrigerator
Refrigerator freezes fresh food section and always runs
Please read it appears that there are two defrost timers for your refrigerator one for the freezer one for the refrigerator
http://www.partselect.com/PartDetail.aspx?Inventory=310858&SourceCode=4#RepairStory
May 02, 2009 | GE Refrigerators
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
