Question about AeroBed Classic Air Bed with Air Pump
When will I receive my order?
Aero Rechargeble Ni-Cd pump
Battery life is over need new 2 nos.battery rechargeble for my Panasonic ES 7111. need service shop near Surat, south Gujarat.
If you are not able to source the original type battery in your city then the other option is to use AA or AAA cells to match the voltage and current rating. You can choose from NI-MNor NI-CD to suit the purpose - size matters.
Oct 11, 2011 | Health & Beauty
I need a replacement battery for the McNair Ni-MH 2.4V 2100mAh battery.
If you take your old battery to a Interstate All Battery they can rebuild your old battery plus they give a one year warranty on it.
Aug 19, 2011 | Niles IntelliPad CI Solo
Wont turn on anymore. shutter goes in and out and screen wont turn on
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
If your cam use manufactors rechargeble batt.:
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 04, 2009 | Kodak EASYSHARE Z1485 IS Digital Camera
Red light blinking then turns off new batteries
In order to clearly determine the fault the model of your KODAK camera is needed
However hope this will help:
If your cam use AA batt.:
Remove the battery
Contact KODAK:
Nov 01, 2009 | Kodak EasyShare C360 Digital Camera
Pressing Wide angle or Telephoto shuts camera down
Remove the battery
Contact KODAK:
Oct 26, 2009 | Kodak EasyShare Z1275 Digital Camera
Takes a few photos then dies even with new batteries
Remove the battery
Contact KODAK:
Oct 20, 2009 | Kodak EasyShare C613 Digital Camera
Camera will not charge or turn on although battery is fine.
Remove the memory card and the battery
Use the camera w/o the memory card
Contact KODAK:
Oct 13, 2009 | Cameras
Lens extends and immediately retracts
If the camera also switched off. Try this.
Remove the battery
Contact KODAK:
Sep 28, 2009 | Kodak Cameras
About battery of samsung s860 digital camera
no dont use rechargables,just use litium energizers,and you,ll be fine.hope i helped.p.s i sold digital cameras for 3years as a photo lab supervisor,and i have this camera myself,its awesome.
Apr 14, 2009 | Samsung S860 Digital Camera
Kodak easyshare C340 camera
Which batteries did you out in, they either need charging or are not the right ones
Mar 23, 2007 | Kodak EasyShare C340 Digital Camera
AeroBed Classic Air Bed with Air Pump Logo
491 people viewed this question
Top Aero Fish Experts
Richard Lindsey ...
Tom Chichester
ThothMer
ThothMer
Level 1 Expert
Are you an Aero Fish Expert? Answer questions, earn points and help others
