Question about Garden
<!-- from fixya rte -->Park brake does not disengage - Garden
  • Garden Master
  • 2,478 Answers
On what
Posted on Nov 12, 2014
Won't come out of park unless I turn key only half way on without starting truck?
The park lock system is tied to the brake light circuit, so if the brake lights (low mount lights only) do not work the lock will not disengage park lock except by bypass method. Start by checking the brake lights.
Jun 26, 2017 | Cars & Trucks
My 2004 18 cc totota wish is hard to pull gear lever out of park even with park brake on worst on cold start
Do you usually park on a hill? If so the park brake is not holding the vehicle, it is creeping away and putting pressure on the transmission parking pawl, which makes it hard to disengage.
Nov 23, 2016 | Toyota Cars & Trucks
Stuck in park what causes it and how do you fix it?
possible causes:
-on a hill without parking brake engaged, causing vehicle to jam into park. This can be fixed by pushing the car rearward while having an assistant shift out of park-with engine off. Be careful, and be prepared to hit the brakes soon as park is disengaged.
-shifter assembly locked in park. Look in owner's manual for park release button. Chances are the shifter assy needs replacing.
-linkage disconnected or shifter cable binding or broken.
May 08, 2014 | 2004 Suzuki Verona
Shifter stuck in park
Are the brake lights working, the safety lock on the gearshift is operated by the brake lights, if they don't work you can't get it out of park. Sequence is turn on ignition, put foot on foot brake (brake lights come on, park lock disengages). Check the brake light fuse.
Jan 01, 2014 | 1998 Acura RL
1500 parking brakes wont disengage
This may sound like a silly answer, but, how often did you use your parking brake previously?
Parking brake cables tend to rust inside the sheath if they are not used very often.
When you apply the parking brake, you use a fair amount of physical force to engage the park brake.
If you do not use your parking brake very often, the inside of the cable may be rusted enough that when you release the park brake, the cable will not release (cable will not slide inside the sheath), as there is only the pressure of the brake shoe return springs disengage the park brake.
Apr 11, 2017 | 1990 Chevrolet K1500
Shifter wont disengage from park-replaced park brake switch,but no help
you need to check to make sure the brake lights work, also the brake light switch is the switch not prake-brake switch, the switch is located above the brake pedal no the bracket that holds the pedal.first thing is to check all your fuses.
Jan 29, 2010 | 2002 GMC Envoy
Wont disengage from park you push the release button and press the brake and wont come out of park
check and see if the brake light switch is not faulty,could cause that problem
Oct 26, 2009 | 2001 Volkswagen Jetta TDI
2004 chevy trailblazer won't come out of park
ok there is a few things one when a car is put in to park a pin slides in to the flywheel push the car forword and pu on the e-brake then try to pull the car out of park. also there is a push button under the brake pedal make shure it has a good conection and try that might need replaced.it controlls the brake lights and an electronic sencor to disengage the car from park by letting the car know the brakes are on.
Jun 02, 2009 | 2002 Chevrolet TrailBlazer
Gear Shifter
The park is locked out until the brake is pushed, make sure the brake lights work, if not test the brake light switch with a test light, if all that is ok then the solenoid that disengages the park lock out is defective.
Sep 21, 2008 | 2003 Hummer H2
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
