Question about Taylor 702-27 Tabletop Soft Ice Cream Machine W/ Table 1ph 2008 Model Nice
Why would our Model 702-27, be kicking the breaker. Tried changing plugs, but as soon as the breaker is reset and then the machine is turned on it kicks. The machine is full of product, and was runn
Why would our Model 702-27, be kicking the breaker. Tried changing plugs, but as soon as the breaker is reset and then the machine is turned on it kicks. The machine is full of product, and was running Saturday.
    Sergeant:
  • 311 Answers
What breaker? The GFI on the wall plug?
If so,liquid may have entered the device and tripped the gfi breaker at the wall plug OR the main panel that provides power to that wall plug.
Posted on Nov 10, 2014
I have a Taylor C707-23 that is freezing the product in the barrel and not dispensing. Then the drive motor trips. Had the sensor probe changed same thing.
If this is an ongoing problem that you have had for a while, it sounds as though your viscosity may be set too high. You can adjust the viscosity by removing the 4 screws that hold the face plate on. You will see 3 potentiometers. You want the left most potentiometer. It Should be labeled "Viscosity". You need a tiny screwdriver to turn it. Turn it counter clockwise about 1/16th of a turn. If your Ice Cream is already frozen, You will have to let it cycle a few times before the ice cream reaches consistency. If its liquid, then you will know as soon as the machine finishes the initial freeze down cycle.
If this is a new problem, then it is highly likely that your beater motor is going bad. To check this you would want to test the amperage of the motor when you initially draw product from the machine. A single phase 1.5HP motor in the taylor ice cream machines should not draw more than 7 amp on an initial draw right after freeze down. Its normal to draw around 6 amps then drop for a few second. In order to trigger the reset, the beater motor has to draw more than 6.3 amps for an extended period of time. Your reset may be set higher than 6.3 but that is average.
Jan 16, 2018 | Taylor Ice Cream Makers
Brush Cleaning did not clear the (L / R) HPR> 45F (7C) AFTER 1 HR fault on my Taylor Model C723 soft serve ice cream freezer.
Certain conditions must be met. The machine needs to be empty. The freezer door must be off the machine. The power switch must be off. Once the machine is off, a 5 minute countdown will show. It will also show 4 temperature readings. All 4 of them must be above 60 degrees F. before the countdown will start. Once the counter reaches zero, the Brush Clean Cycle will be reset along with any temperature vs. time error codes. If at any time, one of the temp readings drop below 60 degrees F. before the end of the 5 minute countdown, the countdown will reset to 5 minutes and the machine will not reset. Generally, the freezing cylinders take longer to come to temperature. Even when you run warm water through it first, there is sometimes enough residual cold to bring the temperature back below 60. A successful Brush clean Cycle will display "Power Switch Off---Unit Cleaned" and the 2 digit green display under the main display will reset to 00. if this happens and you turn the machine back on and you are hit with the same message then you may have an issue with one of your boards.
Aug 02, 2017 | Taylor Ice Cream Makers
Taylor ice cream machine model C713-33 no yogurt comes out when the draw handle it pressed. It seems to be flowing backwards. The agitators are turning in the same direction as the working machines
IF your Taylor C713 is pushing the mix back up through the feed tube, the rotation is reversed. That would only happen on a 3 phase machine like yours.
If you've recently unplugged the machine to move it or something, you probably switched the plugs. Try switching them back.
If you need to reverse the rotation:
1. Unplug the machine.
2. Flip the black and white wires on the plug end.
3. Reassemble the plug and plug in the machine. Make sure everything is tight.
Soft Serve Parts C713
Jun 10, 2017 | Taylor Ice Cream Makers
Put a new motor in the left side, but when you try to run it, it keeps tripping the reset button and turning off. The left side controls the hopper cooler, so I come in and the hopper is warm on both...
Did you check the wiring ? This motor is reversible and you may not have the wires under the connection plate. A model number would be very helpful as I am looking at model # 339 manual.http://www.taylorfreezersales.com/op_man/0336_338_339op0.pdf
Jun 29, 2011 | Taylor Ice Cream Makers
Taylor 751 sp dead
Sound like you might have a loose wire or ribbon cable,might even be a loose wire on switch.Be sure to turn breaker off to machine and unplug it before you check them. Also check the motor reset.
Jan 24, 2009 | Taylor 632-27 Ice Cream Maker
Taylor 702-27 Tabletop Soft Ice Cream Machine W/ Table 1ph 2008 Model Nice Logo
107 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
