Question about Sewing Machines
Thread pulls out of needle after cutting. I have tried all the obvious usual solutions.
    Problem Solver:
  • 7 Answers
Before you cut, make sure to use the manual wheel to bring the needle down, as if it's about to make another stitch; stop the needle before it touches the fabric, pull the thread from the fabric a few inches, and then cut.
Posted on Nov 11, 2014
SOURCE: sudden knotting under fabric
I have an Elna 2005 machine and had a similar but opposite problem whereby the tension up top was too tight - thread wouldn't pull smoothly. I found adjusting the feed dog lever slightly helped the stitches a lot, even though the needle tension up top is no better. Hope that helps! :-s
Posted on Oct 29, 2007
  • 192 Answers
SOURCE: Bottom thread will not catch
Unplug the machine and remove the needle plate so that the bobbin case if fully exposed. Lift out the bobbin case and the cup that it sets in will be visible. Locate the "hook" on this cup. It is a finger with a sharp point at the upper edge of the cup. The hook is what grabs the thread from the needle while sewing.
  • Thread the needle.
  • Turn the handwheel by hand.
  • Watch the hook as it approaches the needle from right to left.
If the hook passes by the needle AFTER the eye of the needle is above it, you timing has slipped and the machine must be taken in for repair.
If the hook catches the thread from the needle, put everything back together and try threading again.
Posted on Nov 14, 2007
bargainbox
  • 1388 Answers
SOURCE: bobbin threading
You may have put the timing out, however, try this before you despair too much......
Ensure the presser foot is firm enough for the fabric you are using and that it will not just pull through easily by hand with the foot and feeddogs together (as the needle ascends), or things will not proceed, and you will be stitching in the same spot.
Generally a setting of 3 seems to work for general purposes, but if you are using very light or very heavy fabric, a sample is always a good idea before you start in earnest....also match the needle to the work for best results.
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
  • 323 Answers
SOURCE: Thread breaking.
Rethread the machine following these directions:
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Remove the bobbin case and bobbin. Pull on the bobbin thread to make sure it doesn't pull too hard. It should have some tension on it but not a lot. Insert the bobbin and bobbin case into the hook assembly and pull on the bobbin thread again.The tension should still be about the same. If it is tight, you need to look at the bottom of the pin that the bobbin case sits on and see if there are any threads looped around it. If there are , you need to remove them.
Hold the top thread , turn the hand wheel and see if the thread is catching someplace around the hook assembly. If it pulls the thread up easily, put some fabric in it and see how it works.
Make sure the thread is through the take up lever.
sewman7
Sewman7
Posted on Jul 10, 2008
talk2ginny
  • 34 Answers
SOURCE: Broken needle threader?
Hi - welcome to FixYa. I have this machine, and unfortunately, the cassettes can break. If the threader worked when you first got your machine, I would suggest buying a new cassette (even if your threader is working). A second cassette is very handy because you can thread your next color in the extra cassette before the machine stops for the next color change - when the machine does stop, just put in the second cassette, and thread the other with the next color - speeds things up alot. And, if one of the cassettes does break, you aren't sitting in a puddle waiting for a new one.. You can find the thread cassettes for sale on a variety of sites - this is where I buy mine:
http://webstore.quiltropolis.net/stores_app/Browse_dept_items.asp?Store_id=492&page_id=17
Some of the 270Ds came with a spool pin - look in your manual for a picture and for the instructions for installing and using the spool pin. You can use it for spool of thread that are too large for the cassette and I think you can leave it installed on your machine all the time. If you don't have your manual, leave a comment and I'll look mine and check the instructions.
Hope this helps. If you have a minute, a rating (good or bad) tells me if the information or solution I provide is helpful to anyone who visits FixYa.
If you would like me to write a tip on salvaging an embroidery project that has been pulled into a birdsnest, leave a quick comment and I'll add the tip. Thanks everybody, and good luck. Please feel free to comment if you need more help or have more questions.
Posted on Feb 05, 2009
I ran my Juki DDL 8700 without any fabric to test and the threads got sucked in and now the needle is jammed, when I turn the hand wheel it won't move the needle.
Loosen the needle. Once the needle is released, the threads holding it may loosen. Then gently try clipping jammed threads with tiny scissors and patiently try removing cut threads with tweezers..
Dec 21, 2017 | Juki Sewing Machines
I have bought new needles for my Riccar overlocker now the stitching is loopy and messy
Verify you are using the correct needles for your machine. Some needles vary by a fraction of an inch but will make a big difference in serging success.
Remove all the threads from the machine.
(Always cut the threads below the spools, raise the presser foot, and pull the threads DOWN through the needles--Never pull up!)
ALWAYS RAISE the presser foot when threading.
Be sure to always thread each thread in the proper order--threading out of order will usually fail.
Rethread from the beginning and give each thread an extra little tug when threading the tension disk.
If a thread breaks, it is usually less frustrating in the end to remove all the threads and rethread from the beginning. Trying to rethread a broken thread will most likely cause problems.
Apr 25, 2017 | Riccar Sewing Machines
When changing thread color do I unthread the needle by cutting it and pulling it through the needle or by taking the spool off and pulling the thread towards the spool?
Technically, it is recommended to cut the thread Above the tension disk, RAISE the presser foot, and pull the thread down through the needle. According to multiple articles and recommendations, you should NEVER pull the thread up through the tension disk (although that's what I've always seen and done multiple times before learning differently).
Jan 10, 2017 | Sewing Machines
Left needle not sewing
Assuming this is a serger/overlocker...
Check to be sure the left needle is installed all the way in the holder. Sometimes debris (threads, lint, etc) accumulate and prevent the needle from seating properly. Use the needle holder tool to hold the needle up while tightening the screw.
Cut all the threads between the thread tree and tension disks. Set all the tension controls to zero. RAISE the presser foot and pull out all the cut threads (always pull them Down through the machine, never Up).
Now, with the presser foot still RAISED, rethread each thread in the Order specified in the manual. Give each thread a little tug when pulling it through the tension disk. Make sure each thread is threaded through every guide as instructed. (Usually the upper looper is threaded first, then the lower looper--if this is your sequence, be sure to DRAPE the lower looper thread over the upper looper in its last step.) Then thread the needles. Pull all the thread tails under the presser foot and toward the back of the machine.
Now, lower the presser foot. Set all the tension controls to the midway point and test.
Feb 06, 2016 | Sewing Machines
Keeping the thread in needle when you begin to sew
after threading the needle pull about 6" of thread out the back under the press foot
that way the thread is jammed under the foot and is held in place for the next thread
bobbin thread should also be out the back
when you have finished sewing then lift the foot and move the material sewed about 6"" away from the foot before cutting the threads
Nov 03, 2015 | Sewing Machines
My sewing machine does not move at all
Is the bobbin winder on? If so, turn it off.
Otherwise, is there power to the machine?
And this happened while you were sewing? Cut the thread above the needle eye. Rock the handwheel back and forth firmly to try to cut the thread jam below the needle plate with the sewing hook. If that doesn't work, open the bobbin case area of the machine and try to pull the bobbin case out, cutting any threads you can see with a seam ripper. Still won't come? Take the needle out of the needle clamp and throw it away (it's bent!), and take the screws out of the needle plate (=throat plate) and take the needle plate off after cutting any threads you can reach under the fabric. Keep cutting and pulling out any thread you find, and eventually, you'll be able to turn the handwheel. Clean all the thread bits, lint, and junk out of the area under the needle plate, the bobbin and bobbin case, and the shuttle area... there will be directions in your manual on how to clean the machine, including the shuttle area. Reassemble. Put in a brand new needle, right way around and fully up in the needle clamp. Rethread from scratch.
Always hold the thread ends behind the presser foot for the first couple of stitches of each seam.
See also: http://www.picturetrail.com/sfx/album/view/22521551
Feb 05, 2014 | Brother LS-2125 Mechanical Sewing Machine
I have a white sewing machine model #426, the thread breaks at the needle as soon as it starts to sew. I cleaned and oiled the machine.
Could be a couple of things so best to trouble shoot the following possible causes:
Cheap thread, brittle old thread. Always store thread in an airtight container out of sunlight and don't use the cheap 5 rolls in a bag in the bargain bin in your sewing machine, fine for hand tacking but not good to machines. Brands like Gutermann, Metrosyne or Sylko Supreme are good.
Needle bent or has a burr on it or is in backwards. Change needle, flat shank to the back.
Thread is catching somewhere on the threading path from spool to needle. Or hooking up on the thread spool itself, some brands have a little notch cut in top to hold the thread tail, but thread can catch in this as you start to stitch. Turn thread spool up other way or use a mushroom cap over the spool to help thread to run off smoothly.
Thread top tension is too tight, should be on 5. When you lower the pressure foot and pull the thread from below the tension device, can you feel firm tension on the thread. Should still be able to pull it though. If you can't pull it it at all when set to 5 then device is faulting.
Obviously if you have tried all of the above and it is still faulting, or you thing the top tension device is the cause, then you could try cleaning the top tension discs (turn to zero and floss with dental floss, check one of my other solutions, I've covered this lots), then I'd suggest it needs a professional service.
If you don't have a manual for your machine they are available from Singer website, http://www.singerco.com/accessories/instruction-manuals, type in W426 then click "search", often free as pdf files.
Jul 11, 2011 | Sewing Machines
The upper thread is constantly breaking. What is wrong?
rethread the machine
check the top tension-usually 3 or 4 is good
change the needle & make sure it's inserted correctly (flat side to the back of machine)
some needles & thread do not work togeather--try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
also make sure the thread tail are 3-6 inches long & pulled behind the needle
Nov 05, 2010 | Husqvarna Huskystar 215 Sewing Machine
The needle keeps breaking and the thread wont stay threaded. the needle is not going straight up and down but it goes down and gets stuck almost
usually a 3-5 inch thread tail is helpful to keep the thread from coming out of the needle & pull the thread(top & bottom) behind the needle
flat side of needle goes to the back of machine
some needles & thread are not compatable----try this
on some machines the presser foot can't do a zig zag stitch
Oct 25, 2010 | Singer 3116 Simple
The thread keeps bunching up on the underside, while the top looks fine.
check to make sure the top thread has not come off the thread take up lever
also check that the thread is in the tension disk correctly--and pulls smoothly
also change the needle it could be bent or blunt or burred
clean under the needle plate ( becareful not to damage the screws, because the fabric can be pulled when it goes over them)
clean the bobbin area for lint or loose threads
also check the tension usually 3 or 4 is good
also maybe a special needle might be needed
also some needle & thread are not compatable-try this
Oct 19, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
