Question about PIAA 2001 Ford Windstar - All Windstar models - Xtreme White Bulbs
Hai sir good night my ford windstar 2000 no fuel injuctor open and fuel pump no opprate please help me
    Genius:
  • PIAA Master
  • 2,414 Answers
-Ask some one who know about car to help.
Good luck
mai Lor
Posted on Nov 10, 2014
2001 ford windstar, van has been setting for a year, got my license back and went to start the van, no fuel pump noise, replaced fuel pump, started just fine drove it around for a day parked it now wo
Can you hear the fuel pump run, if not it may have failed again. I have seen new fuel pumps last a day or two and then fail. If your pump is working then replace the fuel filter. Anytime you open the fuel system, you should replace the filter.
Apr 06, 2013 | 2001 Ford Windstar
My windstar starts but then dies ?
its a ford.... you should expect mysterious problems to pop up at any given moment.
Is there anything else that you can share that will help us solve this?
I am going to guess it is the fuel pump or fuel filter...
change the filter and that will allow greater fuel flow to the engine...
if that doesnt do it... you may need to change the fuel pump.
Aug 21, 2011 | 2000 Ford Windstar
2000 ford windstar toubleshoot code PO174
CODE PO174 - FUEL SYSTEM TOO LEAN CYLINDER BANK 2. POSSIBLE CAUSES LEAKING EGR GASKET OR LEAKING EGR VALVE DIAPHRAM. MAF SENSOR DIRTY .AIR LEAKS AFTER THE MAF SENSOR OR LEAKS IN THE PCV SYSTEM.EXHAUST LEAK BEFORE OR NEAR THE HO2S IS MOUNTED.WEAK FUEL PUMP,RESTRICTED FUEL INJECTORS.
Aug 06, 2011 | 2000 Ford Windstar
2000 ford winstar van will turn over but want start
Hi and welcome to FixYa!
There can be two things to cause your car not to start. If you have a faulty fuel pump there will be no fuel to burn so I strongly suggest that you have it checked. In case your fuel pump is good and it doesn't start then there can be no current to the plugs. If the coil pack is faulty it tends not to give current to the plugs that's why there's no fuel burn. I strongly suggest that you have it checked and replaced if necessary.
Hope this helps and thank you for using FixYa! have a good one!
Mar 08, 2011 | 2000 Ford Windstar
How do you check if there is power to the fuel pump on 2000 ford windstar. should there be power to the fuel pump shut off switch when checked with a test light?
yes. power comes from the fuel pump relay to that switch then to the pump Of course the wire will only have power in the crank mode, or for 2 seconds when key is turned to ON.
Nov 10, 2010 | 2000 Ford Windstar
2000 Ford Windstar is starting to chug a bit as if starved for gas, possible gas filter. Your thoughts
gas filter
fuel pump
fuel presure regulator
i can keep guessing if you like or you can investigate those for starters
Mar 23, 2010 | 2000 Ford Windstar
2000 ford windstar hard to start sometimes it will back fire. I don't always hear the fuel pump energizing.
Could be many things wrong at once.
Check your fuel pressure first, then check your spark plugs for spark, check your system for vacum leak.
Jan 05, 2010 | 2000 Ford Windstar
Cant get gas to injecters 2000 ford windstar it was 5 out last night and 25 out today weve been having problems getting it to start for the last 2 weeks
Disconnect your supply lines to the cylinders. Try starting the car while someone watches the disconnected lines. If fuel pumps from the lines you need to have your injectors cleaned or replaced. More likely it is your fuel pump that has gone bad. If you dont see any fuel flowing from the disconnected fuel lines, try replacing your fuel pump and replace your fuel filter too just to be prevent pushing any dirt and sediment from a dirty filter into a new pump.
Jan 03, 2010 | 2000 Ford Windstar
2000 ford windstar starts but instantly shuts down
It could a fuel problem like bad fuel filter, clogged gas cap vent, or even weak pump.
More info needed.
Sep 02, 2009 | 2000 Ford Windstar
PIAA 2001 Ford Windstar - All Windstar models - Xtreme White Bulbs Logo
Top PIAA Optics Experts
Lawrence Oravetz
Vernon Taylor
Are you a PIAA Optic Expert? Answer questions, earn points and help others
