Question about Tools & Hardware - Others
I have a dewalt 2nd fix nail gun the gauge seemed to be getting hard to pull down to change the nails so I put oil around it and now it doesn't sink the nails all the way in the architrave and skirting when I'm using it. What can I do to fix this ??
    New Friend:
  • 58 Answers
Take it in to have it fixed, meanwhile use a hammer.
Posted on Nov 10, 2014
I have a dewalt framing nailer that will operate with a max pressure of 120psi. I have been using it for 2 weeks with 100psi. Now the piston will not return after shooting the first nail, unless I adjust...
Your gun should work in the 90-120 psi range to get a consistant drive depth and with a few drops, 5-6 or a small squirt, of oil at the start of work and a few more in the afternoon if you are using it a lot. It is possible to use too much oil, if you over oil it and the bottom of the cylinder chamber gets full of oil or other gunk attracted to the oil it can get high enough to interfear with the return function. Also if you are using something other than pneumatic nail gun oil it is possible some o-rings were damaged. Either way you have to remove the head cap and check the internal o-rings for damage and clean out anything in the cylinder and head chamber.
Jan 21, 2012 | Dewalt D51823 Factory Reconditioned 2 inch...
There is a flow of air continually blowing from the gun at the nail loading location, causing it to fail to properly sink the nails into the wood
Can't be specific without model number, however, air leaking around nose area (where driver strikes nail) is indication of orings not sealing around cylinder spacer and body of gun and/or leaking at cylinder spacer and cylinder. Most likely grit has entered the gun and has begun to scratch metal and orings. Time for a reseal kit available thru Dewalt service center (or if you are a tinker-er, remove head and pull cylinder, remove fine scratches on body of gun with fine sandpaper and lube with plenty of silicone lube paste ). Final note, air could be leaking between cylinder seal at top of cylinder and headvalve. Air leaking here would also come out of gun thru nose, but the driver would be pushed down cylinder with nails removed. If no scratches are found and orings appear to be in good shape, then suspect this seal.
Dewalt used vinyl orings (gold colored) that do not last allowing leaks. The orings that come in their repair kits are also vinyl (not good). If possible replace bad orings with buna-n or viton from bearing house. Good luck
Mar 28, 2011 | Dewalt Air Tools & Compressors
The pin on my Dewalt dc616 cordless finish nail gun is ceasing up. How can i lubricate it? can i spray silicon into the nose of the gun?
Hello, W/D here.
The better way is to disconnect the air line from the gun, and place several drops of light oil in the gun while holding the trigger down. Oil daily. Then, re-connect the hose, and fire a few nails into scrap wood.
Another trick is to spray your nails with WD-40 before you load them into the gun.
Best regards, --W/D--
Feb 09, 2011 | Dewalt DC616 16g Cordless 18v Straight...
Nail gun doesn't shoot and air blowing out vent constant.
We used nail guns for years. I still own 6 guns, but they aren't used much anymore.
You have a 'blown head gasket.'
Or there is debris from the air hose that got lodged into the gun.
There is a head gasket and a trigger gasket.
Both can blow out any time from use, lack of oil, or they can stick open from debris.
You can take apart the head and clean it up and add oil to see if that solves problem.
You can order a gun re-build kit for your model and put in the parts yourself.
You can have a nail gun repair shop do the job.
Nail guns require gun oil.
If you don't use gun for a while, oil should be put into air hose opening and then left to run down into gun. More oil is better.
If you use 3-in-1 oil or some oil besides gun oil, then it will corrode the gaskets.
When storing air hose and guns, put tape over openings so they stay clean.
Before hooking air hose to a gun, you can also put a blower on hose and blow out the line first
Oct 21, 2010 | Dewalt Round Head Framing Nailer D51845
The gun won't put out any nails anymore......It is a cordless bradnailer..
If it is the cordless Brad Nailer and will not fire nails anymore chances are the drive belt came off track. Internally those DeWalt cordless nailers operate much like a Baseball pitching machine. And when you fire a nail the drive belt pinches the driver blade which fires the nail. Here is the product documentation from DeWalt's website. http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=68728&typeId=16768&documentId=35981
The Drive belt is part #59. I have never opened one of these before so I can not tell you if it is a simple fix, I would open it up and peek around just a few screws on the top should open it. If you do not feel comfortable opening that unit yourself, I would take it to an Authorized DeWalt repair facility.
Oct 09, 2010 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Dewalt cordless nail gun fires but doesn't seem to feed the nails very well, alot of misfires.
Try another brand of nails -- maybe your gun doesn't like those. Also, blow any dirt out of the nail magazine.
Sep 25, 2009 | Dewalt DC616kn 18 - volt 16 - gauge...
Brad nailer not firing nail...can hear brief air noise upon pulling the trigger
Porter cable makes a number of brad nailers (18 gauge) that very quickly suffer from the problem that you are having. You did not mention the model number of your gun but if it is one of these, (bn125a, bn200a, ns100a) kit # 60061 will fix the problem. It costs between 25 and 30 dollars. Google that part number or order from www.dewalt.com. Dewalt owns the porter cable brand. Before you order the kit, check that the driver blade is not bent and stuck. The driver should travel freely down the cylinder. When you install parts, use Danco silicone grease to lube (availabel at Lowes in the plumbing department) If your model # is different from those mentioned above, please email me and I will recommend a repair.
Apr 27, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Air never stops coming out of gun nail,and gun doesn't sink nails
strip and clean the gun ,you will find that replaceing the seals will help no end
best of look ian
Mar 23, 2009 | Dewalt Heavy - Duty 31° Clipped Head...
Dewalt dc618 nailer is not firing
I have both the DC616 and 618 and have used them sucessfully for about three years. Two main things go wrong. There is a drive belt that breaks (drives the spool that give the energy to drive in the nails), second are two small rubber bands on either side of the drive head that break. The bands can be accessed by taking off the front silver cover, the drive belt is access by spliting the case. Make sure you are using the correct nails or the drive pin may become bent and will jamb repeatedly. Hope that helps!
Nov 18, 2008 | Dewalt DC616kn 18 - volt 16 - gauge...
I have the above dewalt gun just its battery powered, and it doesnt fire the nails
if the nailer is for 18 guage nail use 18 gauge nail if not 16 guage will jam. if it is not the problem is the profile return asyy may jam in side.
Sep 18, 2008 | Dewalt DC616kn 18 - volt 16 - gauge...
Tools & Hardware - Others Logo
27 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
