Question about Cameras
My digital camera is Samsung Galaxy, Model no is EK-GC100 and it won't turn on.
I re-charged the battery. Still won't turn on. So I bought another Samsung battery - still won't turn on. I tried plugging it into the computer, but it won't recognise the camera because it isn't on. When I was charging it, I noticed the camera was warm (not hot) so I think something was happening. But still - won't turn on. Any suggestions?
    Top Expert:
  • Cameras Master
  • 6,702 Answers
When the camera is becoming warm while charging the battery, the battery must be charged. So no need to check for dirty contacts. If you have a multimeter perhaps you can measure the voltage on the battery. While just measuring the voltage, the battery must give a little more then printed on the battery. So when on the battery is printed 3,7 V toy should measure 3.8 or 3.9.
Anything less means the battery is not good.
Now the causes of not switching on. Sometimes the on / off switch is defect. Sometimes the (mini) USB connector is defect and telling the camera, there is still a plug in the camera. It won't switch on. Sometimes the display button must be pushed several times, so the display shows something. And sometimes, the camera is defect.
Carefull investigate the connector and on / off switch, but be aware cameras sometimes become defect, without telling you what is wrong.
I wish you luck.
Posted on Nov 10, 2014
jackboy
  • 2985 Answers
SOURCE: Canon EOS-300D not seen by computer/not turning on
Heat and batteries - maybe Try another battery Remove camera software from computer and put the disk in the box. Plug camera in switch it on and set it to upload mode Windows should find it as a new drive or[XP/2000/ME] will put up camera/scanner wizard.
Posted on Aug 06, 2007
SOURCE: Camera will not charge the battery
This isn't the best soulution but it worked for me. I cleaned off the contacts on the battery and when I placed it back in the camera I put a small piece of a thick rubber band under the door and closed it. This forced the battery farther onto the camera terminals and I was able to get a full charge on the battery.
Posted on Oct 23, 2007
Agent Allan
  • 480 Answers
SOURCE: mustek camera
Hey mari5,
You have most likely damaged the camera battery and it needs to be replaced. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jul 22, 2008
  • 225 Answers
SOURCE: Digital screen doesn't light up!
A common problem is battery drain. This is caused by a leaky component on the circuit board. Replacing the board is the only fix.
Posted on Jan 09, 2009
thenetguruz
  • 145 Answers
SOURCE: How do you get the
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
Posted on May 15, 2011
Samsung Galaxy Camera EK-GC100 stuck on boot logo
Last option that you can do is to hard reset the camera, please take note that this procedure will delete everything on the phone. Please follow steps below:
Switch off the cell phone.
Then hold and press 3 keys: Volume Down + Power button.
Next release all keys, when Samsung logo appear.
Select option "wipe data/factory reset" using Volume Down button, and confirm with Power button.
Choose "Yes -- delete all user data" form the menu, and confirm with Power button.
After that select "reboot system now".
Jul 15, 2016 | Samsung Cell Phones
Tip
How do you fix your phone if it wont charge? ...
All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.
or this.
  1. Turn the phone off.
  2. Remove the battery.
  3. Wait 10 seconds.
  4. Plug in the charger.
  5. Insert the battery.
  6. Turn on the phone.
How to fix phone that won charge properly AndroidPIT
SOLVED Why won my Samsung Galaxy II charge Samsung Galaxy II
How to fix phone that wont charge
How to fix Samsung Galaxy S6 that not charging Troubleshooting Guide
Why is my Samsung charger not working Google Search
on Dec 12, 2017 | Samsung Cell Phones
My digital camera is Samsung Galaxy, Model no is EK-GC100. Last week it fell down and the zoom lens has some problem. It can't zoom in or zoom out anymore, and it appeared the message: "there was a problem...
is there any sign of scratches to show its been dropped? if not samsung offer a 2 year guarentee, take it to any well known phone shop such as carphone warehouse (with proof of date bought) and they will send it away. be warned they will always tell you that samsung will try to fix it but really samsung will just issue you with a referbished one and then they will fix your one in their own time.
Oct 09, 2013 | Cameras
I have just purchased a Samsung Galaxy Camera EK-GC100
go to the setting option and check on there.
Mar 21, 2013 | Cell Phones
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
May 07, 2011 | Samsung TL 105 Digital Camera
Hi! My Nikon S570 model won't turn on. I haven't dropped it or anything and I charged the battery and it was complete. I've had this camera since February 2010. What should I do?? -Monica
i have a nikon s570 that is about 18 months old. (not under warantee anymore) it won't turn on, so we bought a brand new battery, charged it and it still won't turn on. Nothing. no motor noise, no lights, nothing. any ideas? nikon wants us to send it to them for evaluation and fixing....any thoughts?
Jan 15, 2011 | Nikon COOLPIX S570 Digital Camera
Cameras Logo
67 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
