Question about PNY 8GB USB 2.0 Flash Drive - Blue/Black
How do i get the security device off the pny flash drive?
Its Yellow and the packages says to remove after opening
4 Suggested Answers
ashishd19
  • 35 Answers
SOURCE: Need Windows ME Driver for PNY USB 2.0 Flash Drive Attache
Here's what you can do,
Download the files using the these links,
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbauth.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbhub.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbmphlp.pdr
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbntmap.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbstor.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbui.dll
Put all these files in one folder and when windows ask for the drivers, select the option to manually serach for the drivers. And point the search to the folder where you saved these files and it should fix the problem.
If this does'nt work, please let me know.
Posted on Nov 26, 2008
  • 275 Answers
SOURCE: PNY flash drive
Plug it into your USB port on the computer, works like a mini hard drive sort of. When you plug it in, it should ask what you want to do, see files etc. Just drag and drop files in or out.
Posted on Dec 04, 2009
bronk50
  • 27725 Answers
SOURCE: PNY flash drive will not eject
right click in the bottom toolbar select task manager to see whats runnng in applications also in processes to see whats ticking over
it might be your antivrus or another program thats runing
also
try right clicking on it windows explorer select eject
also you might have to resore it to default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
hope this helps you
Posted on Apr 19, 2012
How to download somthing on my pny and does not show its on
if you are referring to a usb drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
if you need more help with this post a reply
hope it helps
Jun 06, 2012 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
I have a PNY USB 4GB Flashdrive, and when i plug it in, it shows that it isn't plugged in. I try to look for it, but it shows nothing is plugged in. Please Help!
if you need more help with this or if i have missed the problem post a reply
hope it helps
May 13, 2012 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
My laptop can not recognized my 4gb genx usb flash drive
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
Jan 19, 2012 | PNY Electronics - Others
I purchased the PNY Clip-on Attache' Flash Drive 4GB but it is not working. HELP!
if you are referring to a problem with your usb drive
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
ports(com&lpt)right click update driver if this fails to fix the problem
hope this helps you
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Sep 16, 2011 | PNY Computers & Internet
PNY Attache flash drive not being recognized
hope this helps you
Sep 15, 2011 | PNY 4GB Micro Attache USB 2.0 Flash Drive
Windows XP home edition not regonising PNY pendrive micro attache 2G
control panel admistrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
Dec 27, 2010 | PNY 4GB Micro Attache USB 2.0 Flash Drive
Purchased pny 4gb SDHC from Staples with bonus National Geographic downloads. I find no code on or within the packaging?
You have to peel the packaging apart and you should find the code under the area where the card was. I have gotten several of these cards and the if the package identified it as one with NatGeo bonus, the code was there after carefulling peeling the parts of the package apart.
Aug 08, 2010 | PNY 4GB Secure Digital High Capacity...
Deleted files from my PNY 4GB flash drive are still taking up space.
Most flash drive comes with its on date support files on it. If those had not been removed then, yes it will show some space used.
Sep 09, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
PNY Optima Attache 4g Flash Drive
Change the drive letter of the pny drive to another letter, different than that of your accounting package. Right click "My Computer" click "Manage" select "Disk Managment" right click the drive, select "Change drive letter and Path" and then change the drive letter to something not used on that computer.
Jun 12, 2008 | PNY Technologies GeForce 6200 128MB AGP...
PNY 8GB USB 2.0 Flash Drive - Blue/Black Logo
42 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
