Question about Vacuums
How to turn on everstar VC_356 vacuum
Where is the switch to turn on..could switch be defective
  • 58 Answers
Could be, but many times the wire right be the plug breaks. Many users pull on the cord. Should pull on the plug instead. Pulling the cord and with a wiggle is worse.
Posted on Nov 10, 2014
Testimonial: "that is a possibility. have been looking for a manual...can't find one on internet. Thx, James"
2 Suggested Answers
SOURCE: Need belt for Everstar 5990 vacuum cleaner
I just replaced the belt on my Everstar VC-9550 and it works fine. I found it at Home Depot for $3.99. The belt is sold under Vac Belts item No. 51007 (Designed to fit Bissell Uprights, Style 7,9,10).
Posted on Jun 24, 2009
Need filter everstar vc 9550
I'm needing a filter for my everstar 3 stage heap vacuum model bck 9550, do u know where I can purchase one?
Oct 27, 2013 | Eureka 431A Optima Bagless Upright Vacuum
I have an Everstar slow cooker. i need to replace the ceramic pot. it is crAcked.
Hi This section is to do with Vacuum Cleaners. Please relist under the correct section. Many Thanks
Oct 27, 2010 | Vacuums
My vaccuum cleaner is an EVERSTAR 1200. I turned it on - everything appears OK until I realize that it is not suctionning. I cleaned out the canister - made sure the vacuum was not obstructed. Still no...
First clean the filter on top of the canister, do not wet it, blow it and get all the accumulated dust out. Then check the hoses for obstruction. There should be an emergency valve on the rear part, if it is open, you better ck the hoses.
Aug 29, 2010 | Vacuums
Where can I find a replacement belt for my everstar turbo 180 upright vacuum?
Home depot and Lowes stores sells replacement belts.
Sep 13, 2009 | Vacuums
Apr 05, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Nu-tone 475 keeps running even without hose plugged in.
If the central vacuum tank will not turn OFF even with the switch in the “OFF” position, then the low-voltage wires should be disconnected from the tank. Once this is done, if the tank continues to run and cannot be turned off with the switch, then most likely the relay inside is defective and needs to be replaced (but it could be a defective and/or shorted ON/OFF switch). If with the low-voltage wires disconnected at the vacuum tank, it can be turned off with the internal switch, then either there is a short in the low-voltage wires, or else there is a hose still plugged into an inlet somewhere. ~ TTURAMBAR
Nov 11, 2008 | Broan-NuTone VX475 Bagged Central System...
We have a Everstar Turbo Vac. 180 and so far its been wonderful.. All of a sudden it became really loud and spitted out the debree. took it to a vac. repair shop and he wouldnt even look at it! Any...
I found my Everstar near a neighbor's trash. I was going to look for another vacuum cleaner for my third level so I wouldn't have to drag my heavy cleaner up and down the stairs. I was totally and pleasantly surprised at this vaccuum cleaner. It had better suction than my dyson. Granted it is kind of a pain to pull out the dirt from the plastic canister but I got used to it. Then one day it just stopped. I know that when the Dyson stops it means something is stuck or clogged and you have to wait for the motor to cool down for it to start again. Same thing happened to the Everstar. It started again. I took the top part where the filter was and found the filter to be incredibly filthy. I washed it, dryed it and put it back and that was the cause of the problem.
Apr 24, 2008 | Vacuums
Need to buy parts
Per the Manual I received with my vacuum.... try e-mailing Home_Depot@Eup.cn
Mar 06, 2008 | Vacuums
Vacuum cleaner safety popped
I had same exact problem. It stopped sucking, just spitting out trash back. You need to clean all pipes, all of them. Then take canister apart and clean and wash top filter. It works like new now again
Nov 26, 2007 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
