Question about Motorcraft 1997-2004 Buick Regal Wiper Blade, 98-03 WW-22WA
Where is the windshield washer fuse located - Motorcraft 1997-2004 Buick Regal Wiper Blade, 98-03 WW-22WA
  • 58 Answers
Should be among the rest of the fuses in a fuse compartment. Is it a fuse problem, switch, motor ?. Try hot wiring the motor and work backwards from there.
Posted on Nov 10, 2014
    Sergeant:
  • 406 Answers
Look under your driver side either on the sude panel or just under the dashboard..if not there look under your hood..there should be a sorta lager plastic box with clips on tne fender well on tne drivers side...it is your control panel,,,that is where the relays and fuses are located..some cars have both fuse panels...good luck..
Where is the windshield washer motor fuse located ?
images for 2009 Nissan Rogue SL Where is the
Windshield Wiper Pump - Not working - Nissan Forum ' Nissan Forums
forums.nicoclub.com/windshield-wiper-pump-not-working-t581434.html
Oct 22, 2013 - Year of vehicle -- 2011 Nissan Rogue SL Leather/Nav Package ... rather an engineer and found that my windshield washer pump was not ... sprocket: Posts: 150: Joined: Thu Jun 11, 2009 1:27 pm: Location: Metro Detroit, MI ... windshield washer fluid switch backwards ?
Apr 27, 2012
Windshield WASHFLUID ISSUE!
Dec 11, 2009
Front windshield sprayers not working..AHH!!!
Nov 10, 2009
More results from forums.nicoclub.com
Jan 11, 2016 | 2009 Nissan Rogue SL
Where is the fuse located that controls the windshield washer pump
Hi Merlin
I THINK this is your fuse panel and location for the washer pump fuse. (See link below)
Hope this helps you out.
-Steve
2003 nissan altima fuse diagram Google Search
Apr 02, 2015 | 2003 Nissan Altima
Location of windshield washer pump
usaully located at the bottom of washer tank where you fill the window washer fluid some have fuses in the fuse box others the wires corrode or break at the pump or pump burnt
Jan 27, 2014 | 1996 Audi A6
The windshield washer will not shoot fluid on to windshield is it the Fuse
It may not be your fuse, your windshield fluid reservoir has a pump that when you activate the switch it pumps the fluid to spray your windshield. The fuse box should be located in the engine compartment on the left hand side or the right hand side of the engine.
Nov 21, 2013 | 2009 Kia Rio
Scion windshield washer fuse
my manual is for a 07 tc, the fuse that controls windshield washer is inside under panel by driver #42 5 spaces from the front, bottom row it is a 15 amp fuse
Jun 03, 2012 | Scion TC Cars & Trucks
How do you find and replace the windshield washer pump on the 2005 dodge magnum RT
The pump is located inside of the fluid holding tank itself. I would suggest checking the 30 amp (pink) fuse for the windshield washer pump before attempting to replace the pump. The fuse is located in engine compartment distribution block. Find the location of the 30 amp fuse by looking in your car's manual. If the fuse looks fine try swapping it out with an identical 30 amp fuse from the distribution block and trying the washers again. I believe there is one other 30 amp fuse (possibly for the headlights?) in that same location.
Replacement (if necessary) is no easy task as it would require removing quite a few parts of the front fascia of the vehicle including the front bumper and possibly passenger's side fender.
Dec 10, 2010 | 2005 Dodge Magnum
Where is the fuse located for the windshield washer motor
Hello and Welcome to Fixya
The fuse is in the engine compartment fuse box. See diagram in the owners manual section 6-11..to find out which one it is, or read the list (provided with amp labeling) on the inside cover to review the fuses there.
Locate the windshield washer fuse accordingly and replace it with the same labeled new fuse.
Do RATE my solution, If this helps you out.
Regards.
Dec 29, 2009 | 2006 Kia Sedona
Washer doesn't work and I can't hear the pupmp motor working.
The windshield washer pump is part of the windshield wash reservior.
There is an electrical connector located on the bottom of the reservior.
That is the pump .
If the pump is not in the reservior. I would just trace the washer fluid lines from the sprayer on the vehicle back to the pump. The lines just might lead back to the reservior for the windshield wash solution. Then you will have confirmed the pump is in the reservior.
You may have to get a new reservior. The pump might not be seperate item, I am not 100% sure on that.
I also would double check the fuses and any relays related to the washer pump.
Finally, I would check the washer switch if you replace the pump and still is not working .
Good luck
Mar 31, 2009 | 2002 Chrysler Town & Country
Winshield washer motor does not run
These days, most windshield washer pumps are mounted to the bottom of the washer fluid reservoir. Where’s that, you ask? Well, inner+fender+w+text.jpgyou know that spout you pour the fluid into—the one that disappears into nowhere? Well, the reservoir is actually 2384f71.jpglocated inside the front fender between the bumper and the front wheel. To replace the pump, you will have to jack up the vehicle, remove the front wheel and then remove the inner fender liner.
Jun 08, 2008 | 2001 Honda Civic
Motorcraft 1997-2004 Buick Regal Wiper Blade, 98-03 WW-22WA Logo
Top Motorcraft Garden Experts
Dennis Key
Dennis Key
john h
Are you a Motorcraft Garden Expert? Answer questions, earn points and help others
