Question about Bowflex Treadclimber Model TC10 Deck
The left tread on my treadclimber keeps tracking to the outside causing wear on the belt. I have tried to correct this using the front adjustment bolts but it keeps tracking left. Any suggestions?
  • 2,059 Answers
Mine has an adjustment setting on the rear as well and I lined mine up using the rear setting.
Posted on Nov 10, 2014
Both front tyres have excessive wear after only a few thousand miles on the insides. Appears to be similar rate of wear on each tyre. Tracking adjusted last service, so unlikely to be that. Any ideas?...
I think a real good place to start would be to have a front end alignment, and struts and springs checked. Most alignment places will check front end all over before performing the alignment, to insure that it isn't worn parts causing the problem, as well as insuring that you aren't driving under dangerous conditions. Your problem could be as simple as a camber adjustment to correct negative camber.( tire is leaning inward at top, which causes tire at road surface to run on inside of tread.) Weak struts and springs are also a consideration, especially if still original on a 95' vehicle.
Here's a link that explains alignment pretty well to help you understand.
http://www.familycar.com/alignment.htm
Dec 29, 2010 | 1995 Volkswagen Golf
My rear tires are wearing down to the steel tread on the inside only... both tires... from the outside they appear to have lots of tread left... any ideas?
you normally only get that sort of wear on the front and is caused by the steering being out of track the only thing i could suggest is have a laser track done at your local tyre shop and get them to ballane it all four tyres while they have it .ill look further into it for you
my email alicantemick@hotmail.com
Jun 27, 2010 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Track sliping
Adjust walking belt tension at the front of the unit using the provided hex wrench on the exposed adjustment bolts located on each side of each front roller. Be sure to adjust both bolts on each roller the same amount as to not disrupt belt alignment. Tighten (turn clockwise) each adjustment bolt in full turn increments. After each adjustment, restart unit and check to see if belt slippage has been eliminated. Repeat if necessary.If slipping feel persists after several adjustments, stop and see if it maybe the drive belt. Remove left rear plastic cover to expose “v” belt drive line and motor. Tighten nut on the motor tension bolt located on front side of motor in 1/2 turn increments until drive belt slippage is eliminated - DO NOT OVER TIGHTEN. Replace cover when finished.
Jun 27, 2010 | Bowflex Treadclimber
When walking in my Bow Flexn as in regular treadmill mode it feels like it slips under my one foot sometimes any clue as to why ?
If belt hesitates or slips when walking on unit it may be caused by either a loose walking belt or a loose drive belt. To determine the cause perform the following test: Stand beside Tread-Climber® fitness machine and set speed to 2 MPH. Step on one treadle and attempt to stop movement. If one belt stops but roller at rear and other belt continue to turn walking belt tension should be adjusted. If both belts stop but motor is still turning the drive belt tension should be adjusted.
May 22, 2010 | Bowflex Treadclimber
I have a proform treadmill that slips as soon as i step on track i looked at the belt it looks good how do i tighten up the track
There should be adjustment screws on the back left and right sides. The screws will be horizontal with the tread, and probably need an allen wrench to tighten. If the tread runs straight, tighten each side 1/4 turn at a time to keep them even. Check the tread after each adjustment, and stop as soon as the tread quits slipping.
Sep 08, 2009 | Proform Crosswalk 500 Treadmill
I need some details on how to adjust the front right tire because it is wearing to quickly on the outside tread
Your tracking is out and needs to be set up using a laser rig
It is toeing in and that causes the scrubbing effect.
Unless you want to try numerous settings on the right hand side steering link arm and watch the tire wear away as you do so take it to a tire shop and they will track it up in about 20 minutes
Jun 30, 2009 | 1993 Chevrolet K1500
Bowflex treadclimber 5000
Napa 8300 silicone is recommended. Apply under belts from front to back one fluid spray and also in bearing areas. Squeaking can also be caused by the center of the treadles rubbing to hard. If this is the case they need to be adjusted.
May 29, 2009 | Bowflex Treadclimber TC5300
Front wheel alignment
thanks for your reply/update the reason for front tyres wearing as you describe would suggest the steering tracking is wrong and for some reason ?the tyre wear on inner isindication the track is toeing out too much ? this fault could be ? simple adjustment req'd however dependand on make of tyres has to be considered when tracking as to whether they toe in or out or straight ahead ? also front wheel drive ? there could be other factors b4 tracking is adjusted such as steering joints wear ? or damage ? also suspension ? as i mentioned best to visit a good tyre depot and let them investigate while you wait and give you a reportas to fault normally free in uk if it is simply tracking req's re adjust then they can do it and charge for the adjusting not expensive and they may also recommend switching wheels from rear to front providing tread are good ? hope this helps best wishes
Mar 30, 2009 | 2003 Hyundai Santa Fe
Black dust coming out
I just got a BowFlex TreadClimber TC3000. I have been using it for about 1 week and I noticed black dust coming out of the back. It was near the treadles. I called BowFlex and they said that this is normal during the first few weeks of use. This is the coating coming off of the treads. They said I could vaccum it up. They also mentioned that they only time to really worry is if there is white dust. That is the actual treads wearing off. Hope that helps!
Mar 19, 2009 | Nautilus Exercise & Fitness
Treadmill adjustment on bowflex 5000tc
There are two hexagonal screws on either side of the front rollers, and four inset hexagonal screws on the back rollers. Turn it on the lowest speed while turning the ones in front, one at a time. You'll see the tread move from one side to the other. Tightening the screws bring the rollers out, pulling the rubber tread taught, and to the left or right, depending on which screw you're turning at the time. The treads should roughly be the same tension, adjusting both inside and outside front screws for each tread. If you have the dual rear rollers, you'd then have to stop the machine after finishing the fronts and tighten the four inset hexagonal screws on each of the rear rollers. No adjustment per se, just tighten them. If you don't, you'll have a sort of clunking, or clicking noise from the imbalance. The single rear roller is a little different, and the adjustment I believe, can be found on this site:
http://nautilus-technics.com/
Good luck.
Dec 28, 2008 | Bowflex Treadclimber
Bowflex Treadclimber Model TC10 Deck Logo
144 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Glenn Mayer
Glenn Mayer
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
