Question about Electrolux Refrigerators
How do I restart the icemaker in an Electrolux, model- EW28bs71IB0
I am an applianxe repairman, but have no experience with this model of Electrolux. Need to restart icemaker, but don't know how.
    Master:
  • Electrolux Master
  • 676 Answers
I can give you a service manual
Posted on Feb 06, 2016
Removal of large filter on electrolux model ewdw6505gb0
Electrolux Dishwasher Screen Filter 154624901 this one?
If they are hard water deposits, there is probably other parts coated with lime as well... try running a cycle with this in it- Ice Machine cleaner, it is safe on the plastic parts of an icemaker and meant to clean things that folks eat off of, so it rinses clean. I would use two bottles and then let it fill the rest on it's own...
Jul 09, 2016 | Electrolux Dishwashers
Washing machine suddenly total dead, and electrolux repairman said have to change the whole board 0062_0001a, can it be repaired? Thanks
ask repairman to give you total bill for fixing your washer an compare that total to buying a new washer I look up how much it would cost for a new Electrolux washer it would be cheaper to fix your
May 05, 2015 | Electrolux Washing Machines
REPLACE SHELF OVER ICEMAKER
Good Morning Friend,
I understand that you need to replace the shelf over your ice maker, in your Electrolux refrigerator. I suggest contacting the manufacturer with the model number of your appliance. They should be able to locate the part for you to purchase, and have it shipped out to you. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Electrolux Refrigerators
Electrolux side by side model ew28bs85ks4 icemaker was making a grinding noise and just quit completely no ice what to do?
If you can watch the icemaker run through it's cycle, with the door open of course, try and determine where it might be hanging up.
I 'trimmed' part of the replacement kit installed by our Electrolux repair technician where it was hanging up with the motorized parts, about 5 months ago, and it began completing it's full ice-making cycle once again.
Mar 28, 2014 | Refrigerators
Electrolux ice maker
Hello - Do you have the model number? What is your concern exactly? Is the icemaker not producing ice or dispensing water?
Oct 25, 2012 | Electrolux Refrigerators
I have a Frigidaire front loaded dryer that is just a few years old. It continually beeps and the lights on the front panel flash and after few minutes it shuts off. How do I fix this problem?
I had encountered issues like your concern regarding the problem Frigidaire dryer. Most of them had contacted the Frigidaire repairman to check and put in a new control board and it works like brand new. Though it costs $100 for the service but this amount will be refunded if you contact the Electrolux and ask for a code to give unto the repairman to cover the cost of the board.
You may contact also:
Chris Polk
Escalation Specialist
Electrolux Major Appliances
chris.polk@electrolux.com
So you may be guided, just send your contact information, and the best time to contact you. He would also need your model and serial number and a file number if available.
I hope it helps ^_^
Aug 26, 2012 | Frigidaire Electric Dryer
Ice maker makes knocking noice
It would depend on the model of your fridge. Most fridges, you would just need to change the icemaker, but if it is a whirlpool or kitchenaid, you can just replace the module on the front of the icemaker (part number 8201515)
May 19, 2012 | Electrolux Refrigerators
We are in Australia and have had an Amana XRSS287BW fridge freezer with ice maker for 5 years. The freezer is icing up near the ice maker, the condensor is not icing up. It appears to ice up and the fan...
they do not repair icemakers for the simple fact it is cheaper to just buy a new unit aka icemaker in fact the icemaker when the repairman buys it costs him between 47-90 dollars at which for him to disconnect the three bolts and reinstall the icemaker the charge usually starting around 189.00 first thing to do would be to look at the tube where the water is going into the icemaker and observe if you have a leak from the tube the next step would be to inspect the icemaker for cracks in the ice making tray if this is also ok has your repairman checked the t-stat this is a small two wire round disc like object located behind the back panel this is what regulates your temptreture and turns the heater on when your freezer gets to cold another thing to check would the drain tube that goes from the bottom tray under the condensor sometimes this also gets blocked with ice.In turn when it does get blocked the ice just builds up the t-stat is located as part number 3 on this diagram from this link http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-XRSS287BW0/1268/0165000/M0610184/00014?blt=06&prst=&shdMod= lastly if your fan is not spinning at the addequate speed that it is supposed to be spinning at then the amount of cold air would not be leaving your freezer to go into your fridgerator and when the heater kicked on the water that melted off the condensor coils would build up also as ice if your repairman is saying its the icemaker visually inspect the icemaker yourself here is a link also showing how to remove your icemaker http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-XRSS287BW0/1268/0165000/M0610184/00008?blt=06&prst=&shdMod= please message me back with your finds after you have visually inspected for yourself. i hope this opinion has helped in your appliance situation please remember to rank how this opinion has helped in your appliance situation and i await your reply
Thanks
Rick
Nov 09, 2010 | Amana Refrigerators
Electrolux Fixed well model Vegetable Washer is not working"
If this is a U-line just visit the website www.u-line.com and under specifications and documentations you should find a manuals
Feb 26, 2009 | U-Line Icemaker
Refrigerators Logo
79 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
