Question about Head Electrical Supplies
My lexus es300 1997 head lamp and tail lights went off. The car still starts fine and so is the battery. Any ideas what the problem could bee? Thanks for the help.
Head light and tail light not working on my car. Car still runs fine.
    Genius:
  • 1,966 Answers
-Check fuse.
Good luck
Mai
Posted on Nov 10, 2014
Honda xr 125 blowing 15amp fuse
me id start by looking real close at the wires to and from the head and tail lamps and handle switches , then id go farther at looking inside the head and tail lamp housings for say water or a rusty or damaged wire , finnaly arriving at looking at the battery voltage with a voltmeter when im reving engine this shouldn't go over say 12.8 volts if it does your voltage regulator is defective and is damaging all your bulbs
May 26, 2017 | Honda XR 125 L Motorcycles
Brake lights and rear deck light do not work on 1991 Lexus ls400. I checked all fuses,bulbs, and Brake switch and they are fine. Help?
Have you probed the tail/brake lamp socket to see if power is there or you just assume it is? also make sure the ground is good for the brake lights Do that if not done already and let me know.
Jun 22, 2012 | 1991 Lexus LS 400
2005 accent tail lights wont shut off
Pull that fuse or pull tail lamp relay, that should kill the lamps till you figure out the problem? You also have left an right tail lamp fuses, underhood fuse box. I don't know if tail lamp relay is faulty? Another concern, see the bottom wire on left of tail lamp relay, that is a ground controlled by the headlamp/multifunction switch, there could be a problem with that wire circuit or the multifunction switch. At the moment, I'm hoping just faulty relay.
Jul 10, 2017 | 2005 Hyundai Accent 1.5
Tail light, brake light and battery dash light illuminate at once
check all of the body grounds.
also check the bolted positve connections the power supply.
check and clean the battery terminals.
Aug 21, 2009 | 1994 Toyota Camry
Tail/head lights do not work?
Check the bulbs for burnt filaments. Take a multimeter and test your feeds and grounds at each socket. Possible multifunction switch failure. The switch that works your head and tail lamps.
May 14, 2009 | 1989 Nissan Pathfinder
'86 Mustang Head Light Switch Pin Out Connectors?
I can give you 94 mustang. Don't have 86 but maybe similar
7fc8945.gif Pin Number Circuit Circuit Function B1 38 (BK/O) Power Supply to Battery B2 195 (T/W) Tail Lamp Switch Feed I 19 (LB/R) Instrument Panel Lamp Feed IGN — Not Used R 14 (BR) Headlamp Switch to Tail Lamp and Side Marker Lamps H 15 (R/Y) Headlamp Dimmer Switch Feed DN — Not Used D1 54 (LG/Y) Interior Lamp Switch Feed D2 706 (GY) Battery Saver Door Switch Feed
Apr 30, 2009 | 1986 Ford Mustang
2004 Dodge Ram 1500 4x4 - Tail and Parking lamps are not working
there should be a fuse for the tail lights under the dash in the fuse panel....my interior lights went out here while back, and i had no brake lights.....fuse in fuse panel under dash.....
Feb 01, 2009 | 2004 Dodge Ram
1991 Lexus all brake lights don't work
Hi ....... Look up under the footwell and brake pedal, theres a switch mounted onto a metal bracket, they should self adjust to compensate for wear etc ............... remove from the bracket and make sure contacts and action is good.
Dec 24, 2008 | 1991 Lexus LS 400
Electrical Supplies Logo
50 people viewed this question
Top Head Electrical Supplies Experts
john h
downhille
Ted Maxwell
Are you a Head Electrical Supply Expert? Answer questions, earn points and help others
