Question about Air Tools & Compressors
Hi my paslode 1st fix nailer has started making a loud buzzing sound after firing. Iv had it serviced but still making the noise. Any idea?
  • 1,970 Answers
Sounds like air could be leaking from somewhere. Check all connections and listen carefully with it close to your ear after firing to see if its coming from inside the unit
Posted on Nov 10, 2014
5 Suggested Answers
  • 24 Answers
SOURCE: Paslode nail gun will not fire
Make sure the spark plug ignites. Take tool apart as in cleaning. Hold micr switch near fan and watch as you pull trigger. you will see a spark. If not check the lead to igniter
Posted on Apr 14, 2009
  • 10 Answers
SOURCE: paslode pneumatic nailer will not fire
Check gas expiry date, failing that reove four bolts from back and two from front nose and remove cylinder housing, check piston is free in cylinder and driver is right back, to check you have spark with battery in push and hold down switch arm just below fan and pull trigger you should see and hear the spark, if there is spark you may just need to clean arond spark plug to get a more positive spark, also check o-ring on fan housing as if this is damaged it will alow gas to escape and no ignite.
Posted on Apr 23, 2009
lester482529
  • 226 Answers
SOURCE: Paslode 5350/90S PM Powermaster Bends nails over
USUALY THIS IS CAUSED BY TO LOW OF AIR PRESSURE(NEED AT LEAST90-100PSI)OR NAILING INTO SEASONED HARD WOOD SUCH AS OAK,OR THE WRONG DEGREE PITCH OF THE COLLIATED NAILSHOPE THIS HELP'S.PLEASE RATE THIS .
Posted on May 23, 2009
  • 497 Answers
SOURCE: My paslode IM350 fires about once every 20
by service im assuming you mean replacing the o-ring and seals/gaskets. If not do that. But if you have it may be more of an internal problem with the air valve leaking around the piston.
Posted on Aug 10, 2009
Paslode im250 works fine but makes loud gun like bang noise, can I reduce bang sound.
Take a look at the internals and see if there is an air leak or muffler problem:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/paslode/IM250_A/
Jan 20, 2013 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode impulse framing nailer , iv cleaned gun and oiled , the fan works etc . seems to only fire if i have fully charged battery ,once used for about five minutes it stops firing . only way to get it...
When it stops firing is the little light on the side of the handle green or red? If it is red then the battery is draining down too quickly. Either the fan switch has malfunctioned causing the fan to run all the time (I have seen this before) or you got either a faulty battery or charger.
Mar 05, 2012 | RTO PasLode 900420 Impulse Framing Nailer
My paslodes will not fire with a fully charged battery and a new full cell. It only makes a sound like its engaging
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Feb 22, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Plaslode im250 second fix nail gun fires intermittently. Gas is loading fine and trigger working only fires about one in every ten pulls of trigger
heatman101
Dec 31, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode im65 does not fire unless you push push down twice for it to fire. have cleaned it around spark plug ect any ideas much appreciated
heatman101
Dec 12, 2010 | Craftsman Nailer Kit, Palm Air Driver
Hi .my im350 nail gun isnt working gas and battery ok and gun is cleaned.light on green .but when depresssed makes strange noise and lights on fire from fan end?
heatman101
Oct 24, 2010 | RTO PasLode 900420 Impulse Framing Nailer
I have a paslode gas framing gun when i want to nail something it makes all the sound but does not fire gas cell is good battery is good
heatman101
Sep 14, 2010 | Porter Cable FR350A Factory Reconditioned...
Framing nailer has freshbattery, good fuel cart, fan runs when you put pressure to the charging head nails,,,,, but will not fire.from what I've read up on this, it sounds like the combustion chamber has a...
heatman101
May 16, 2010 | RTO PasLode 900420 Impulse Framing Nailer
IM250 not firing.
heatman101
'l;l;
Apr 12, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Air Tools & Compressors Logo
69 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
