Question about New Aftermarket Blk Drl Style Led Projector Head Lights W/fog Signal 1999-2004 Vw Jetta Bora Mk4
Whats wrong with the heater that doesn't heat and smells like cup of noodle.
The heater doesn't heat up and cause the front wind shield to fog up and it smells like cup a noodle when turn on for awhile. Is it the heater or heating coil or something else. pls help. Thank you.
    Sergeant:
  • 269 Answers
Sounds like heater core.usually the passenger floor would be wet if heater core was bad I would try thermostat first
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Posted on Nov 10, 2014
Whats wrong when the passenger side floorboard is wet under the carpet, and the moisture is coming from underneth?
Most likely cause is a leaking heater core. Have your cooling system pressure tested and look for leak.
Feb 24, 2015 | 2000 Pontiac Grand Am GT
Dodge durango 2001 fogging up windows not defrosting
It's most likely your heater core that is causing the problem it could be leaking either from the core it's self causing anti freeze to get into your vents or from one of the hoses leading to it.....I am assuming that when your heat is on there is a dampness in the air this is what is causing the windows to fog up.
Feb 17, 2014 | 2001 Dodge Durango
When I turn my heater and defroster on, a bad smell starts and the windows fog up but the air is hot.
This may be due to a bad heater core or dirty core with a plugged water drain, first see if the a/c works. turn it on and see if the air gets cold and if the ac compressor works.
The way the defrost works to keep windows from fogging up is that when the front defroster is tuned on the ac should also be on, on most cars when you go to defrost it will turn ac on automatic. the system then uses hot and cold air to remove the moisture in the air to avoid window fogging. if your a/c is not working then that may cause window to fog, but if you are also getting a smell then the drain that lets out condensation may be plugged and then water builds up and also mold from always being wet and when heat is on you smell that.
i want you to run the defrost and when windows fog up wipe window with hand and see if it is greasy . if it feels oily then you may have a bad heater core, the core leaks coolant out and steam and causing windows to fog up with a flim of grease.
Feb 03, 2013 | 2000 Chevrolet Silverado
I changed the heating core but now my windows are fogging up when i turn on my heat and i also smell antifreeze coming thru the vents what seems to be my problem???
heating core has been plumbed in wrong or most likely has a leak in the system, as you are smelling the antifreeze - seems to me like the antifreeze is not reaching the core, have you mistakenly plumbed the intake/out take the wrong way round?, this would cause the windows to fog up as the heat is being taken away fro the core rather than being taken into the heater core
Sep 13, 2012 | 1996 Ford Crown Victoria
1994 Caprice LS. Little to NO heat.
It will be the heater core. If you can smell it inside the car and it's steaming up the windows the core will need to be replaced. Remove the heater core housing and check to make sure its leaking from the core itself. You might get lucky and have a leak from the hoses running to core instead. Hope that helped.
Nov 17, 2011 | 1994 Chevrolet Caprice Classic
I smell antifreeze and my windows fog up when the heat is on or off what could that be?
The only part that has coolant running through it under the dash, is the heater core, when it goes bad, you will smell coolant and the window will fog up, leaking heater core, replace it be for it start's to over heat your engine and cause more problem's in the long run.
Dec 03, 2010 | 2001 Dodge Caravan
Heater immediately fogs all windows and there is a sweet odor in the cab of 2003 Buick Rendezvous, defroster works fine, but will not clear the windows after heat is put on
Sounds like a possible heater core failure(hole in it) the smell indicates to me the coolant(anti-freeze) is leaking into the passenger compartment.
Check the carpet in front of the front passenger seat for moisture, this would confirm heater core leak.
Good luck !
Jan 28, 2010 | 2003 Buick Rendezvous
When my ac is my on wind shield fogs up, why is that?
Check ac drain tube on the firewall...if it normally drips out onto the ground and still is, it's OK...only other thing might be the heater core which may have a pin-hole leak. Loosing any coolant? If it only sometimes does this, it may have to do with humidity in the air but it won't do that all the time though.
Jun 26, 2009 | 1997 Chevrolet K1500
New Aftermarket Blk Drl Style Led Projector Head Lights W/fog Signal 1999-2004 Vw Jetta Bora Mk4 Logo
179 people viewed this question
Top New Aftermarket Office Equipment & Supplies Experts
gbob59
Bill Boyd
Art Vandaleh
Art Vandaleh
Level 1 Expert
Are you a New Aftermarket Office Equipment and Supply Expert? Answer questions, earn points and help others
