Question about Hoover Elite Rewind Bagless Upright, UH71009
<!-- from fixya rte -->Power button become lose is not working - Hoover Elite Rewind Bagless Upright, UH71009
    Genius:
  • Hoover Master
  • 2,415 Answers
-Bad connector. remove and check, possibly broken wire or need to tight more.
-Make sure Unplug before open and check.
Good Luck
Mai Lor
Posted on Nov 10, 2014
My Dyson DC14 picks up on hard floors and the hose works, but lacking suction on carpet
The DC14 has belts in the clutch that become stretched and lose elasticity. Even with great suction a vacuum will not clean well on carpet if the brush is not spinning fast enough.
Mar 04, 2018 | Dyson Vacuums
Power nozzle does not work. Light comes on on power nozzle but it does not vacuum
Many early version PN-2E power nozzles have reset buttons that are becoming faulty. The factory stopped adding the rest button to this model power nozzle so you can update your unit by removing and this my solve your issue. You have the trigger to stop the motor if you have an issue so the rest button has become unnecessary.
Mar 28, 2015 | Rainbow E series Canister Wet/Dry Vacuum
Dyson dc23 canister rug attachment loses power after about 5 seconds, push red button and restarts for less time. After 3 or 4 trys of it working for seconds it just doesn't turn on again. Reall
Hi Elizabeth, it's Jack at Dyson.
I'm glad to hear you've been in touch already and we're able to resolve the issue under your machine's 5-year guarantee.
In most cases, the issue you've described will be caused by something jamming the brush bar. It can usually be resolved by clearing the brush bar of any debris, threads or hair, and checking the Motorhead for any obstructions, as shown in the video below.
If you'd like further help and advice with your machine at any point, please get in touch with us.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 07, 2013 | Dyson DC11 All Floors Bagless Canister...
How dismount Nilfisk A100 for repair 220V cable
You need at the top the button puwer and kabel return too lose, yoy can do this to put something at the site from the button. You will see 6 screws.
lose it losre also the screw at de coverd panel and this one at the backsite.
Your problem will mybe at theconnection from the power button, is burned out.
Dec 20, 2010 | Nilfisk Vacuums
Works in FLOOR position but not in CARPET.
The power nozzle has a reset button. Push that and that should fix the issue. You could of sucked up the corner of a piece of carpet causing the brush roller to become jammed. If that doesn't work, there could be a problem with the hose. The hose perhaps isn't providing the power to run the power nozzle.
Oct 12, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Why is my swiffer vacuum working up to full power and then it needs emptied and then it loses power after I empty it?
it can't be that it loses power, it just gets loud when it's full, not so loud when it's empty?
Sep 07, 2009 | Vacuums
Power brush will only operate on push stroke
If the motor runs, the circuit breaker is working. If it only works on the push stroke, you probably have burnt contacts where the handle and/or wands and/or power head connect. When you push, the contacts are pressed together; when you pull, they are separated and the motor loses power. The only solution is to replace the connector parts.
May 06, 2009 | Vacuums
Hetty hoover not working. It was working ok until I opened it up to search the bag for a missing jigsaw piece and I put it all back and I hoovered the mess on the floor, then switched off and switched on...
Know cut off switch, its just not getting power ? 2 things its ether at the wall plug or in side the unit. I have never found a fuse in side them , so it may be just a lose wire did you try other plugs in the house . good luck DFD
Jan 22, 2009 | Henry Numatic "" Canister Vacuum
Problem with bissell powersteamer no power
If the motor started to run slow, then stopped, it may have seized and will have to replaced.
Mar 05, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Hoover Elite Rewind Bagless Upright, UH71009 Logo
67 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
