Question about Hotpoint Washing Machines
My washing machine hotpoint ultima wmd 940 is dead no power ,but the fuse in the plug is ok.
No more detailes to add to the question above i would be very much oblige for your help.
  • 31 Answers
The mains lead normally goes to a connector block at the top of the machine then onto a mains filter both of these can fail ie burnt out connections ect check these out first remember to un-plug machine first
Posted on Nov 12, 2014
  • 2,059 Answers
Is your circuit breaker in your electrical panel shut down.
Flip it off completely and push it on all the way. Check that out first.
Posted on Nov 10, 2014
Testimonial: "Hello Dan, The electrical part of it is fine the plug is working and the fuse in the plug is fine.It's just the machine is dead nothing happen when you switches it on. Thanks"
What does F-01 mean in my hotpoint ultima wt 940
If youhave a booklet which comes with the machine it should tell you in there .Alternatively contact Hotpoint customer service. they will advise.
Jul 15, 2014 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wmd 940 program counts down but machine not working
Good afternoon
Your washing machine has more difficult problems than I have met before.
The only thing I can advice you is to get an electrical expert from
a shop that specializes in your type of machine.
Whille you are waiting you could browse on the internet and look at MANUALSONLINE.COM
kolbrun
Feb 26, 2012 | Washing Machines
Hotpoint wmd 960 ultima,when press start button nothing happens apart from the clock starts count down to end of wash
if water starts but drum dont move.............
check the rear belt....if that is on then the motor needs new brushes............
easy fix ........... about £12 diy
cheers
Mar 22, 2011 | Hotpoint Washing Machines
Washing machine stopped working,no power,no display checked fuse,fuse ok.hotpoint wt761
Check the power outlet, the plug and the cable or with the appropriate tester see if you have mains power where the power cable connects to the machine wiring.
Jan 30, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hi i have an ultima wmd 940 hotpoint washing machine !! i have a split in the plastic piece which supplies water from the inlet to the tray!! what is this piece called and were could i get a picture of the...
a few sites yu can get on and actually type your model number and see the part you need are as follows:::
www.repairclinic.com
www.apdepot.com
www.sears.com
you should be able to type your model number on these sites and locate your part.
Jan 03, 2011 | Hotpoint Washing Machines
Wmd 940 wont fill,, water pressure ok,hose ok,f01
Solanoid. does it fill on any other programe. try hot wash, then rinse
Feb 01, 2010 | Hotpoint Washing Machines
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima WT9 60
the internal circuit board has come loose, switch off power take the top off and tighten the connections on the plugs inside
Feb 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
78 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
