Question about Health & Beauty
Where can I download the user's guide for my Mainstays Digital Kitchen Scale?
Model: EK9150K Uses one CR2032 Coin Style Battery
  • Barbie KingScott Nov 11, 2014
    I was trying to post a pdf file with the User's Manual for someone else who needed it, but I couldn't figure out how to upload the pdf file.
SOURCE: I have a chefmate digital kitchen scale and I do
I have the same problem. The only way I can figure out how to reset the clock is to take out the batteries and put them back in at 11:59 pm or midnight. Replacing batteries reset the clock to 12:00 am. So if you do it at midnight, you'll end up with the right time. But for the life of me, I cannot figure out how to actually set the clock using the availble buttons.
Posted on Jun 13, 2009
SOURCE: Can't open battery case
The middle part slides out. You'll need a small knife or a screwdriver to pry it out gently.
There are openings on two sides. One side has a larger opening than the other. Make sure you pry it out of the lager opening.
Once you gently slide it out, you'll see the two batteries. Make sure the positive side is facing up when you put them back in.
Hope that helps!
Posted on Aug 18, 2009
SOURCE: Kitchen scale, Salter, model 2006: change batteries
The 1 part just slides off.
Posted on Jun 28, 2010
  • 18 Answers
SOURCE: I replaced the battery with a DL2032 instead of a
This shouldn't be a problem, as the DR and CL are referring to the manufacturer. Both batteries are 20mm in diameter and 3.2 mm in thickness. Make sure you do have the 2032, rather than the 2023 1.5v alkaline batteries.
I would recommend taking it into the store where you purchased it.
Posted on Dec 07, 2010
fb62685
  • 4 Answers
SOURCE: I just bought I digital
I had already solved this after a lot of playing and research, put I thought I;d post it on here for others as the answer was different for other scales listed here. What I did was press the 'Button 1' and 'Button 2' together for 5 seconds. This powered it up and then the display showed 'Cal' with a number on the screen. I pressed 'Button 1' again and it said 'Zero' and then displayed the numbers '0000'. Then I added 1kg of weight and it said 'Cal1'. Then I added 3kg of weight. It said 'Cal2'. Then I added 5kg of weight. It said 'Cal3', then 'Pass'. It then returned to normal mode and now started weighing correctly. I calibrated the weights (Flour and Sugar packs) on another set of scales first, but they were only a few grammes wrong so would be close enough anyway. I hope that helps!
Posted on Dec 04, 2012
Sony pcvrx514 cmos battery part number
Hi
This appears to be a desktop machine, and most motherboards use a CR2032 type coin style battery.
If you can get the battery off the motherboard being careful not to damage any part of the motherboard then the type and voltage of the battery is usually engraved on the metal case.
If this not the case then compare the physical dimensions - very carefully - between your battery and a CR2032 and if they correspond try the CR2032 before looking elsewhere.
Cheers
Aug 26, 2014 | Sony VAIO Computers & Internet
What battery does an OXO small kitchen timer need?
I'm assuming you're referring to OXO's Magnetic Digital Timer model #1127980. The instructions require a CR2032 (coin-type) battery which is accessed by gently prying the battery cover off with a coin. You can download the instruction booklet here:
http://www.oxo.com/download/1183_gg_1127980_booklet.pdf
Jul 12, 2014 | Oxo Hardware & Accessories
How to put a battery in an oxo magnetic timer
I assume you're referring to OXO's Magnetic Digital Timer model #1127980. The instructions require a CR2032 (coin-type) battery which is accessed by gently prying the battery cover off with a coin. You can download the instruction booklet here:
Apr 16, 2013 | Hardware & Accessories
Replacement battery for 5786 taylor scale
Fixya does not sell replacement batteries.
Dec 23, 2012 | Taylor Health & Beauty
Can i replace the battery in my Royal EX2 Exacta Scales Postal scale?
90 day warranty on this scale to begin with so when battery dies after 10 years, you have no warranty to preserve. Royal EX2 Exacta Scale - royalsupplies.com - manual downloadable.
You will need a Phillips #1 and I think a #0 for best fit. 2032 lithium coin battery (fresh, so it will last another 10 years). 1) Peel off large label from bottom (Xacto knife to get under a corner). 2) Remove 3 screws attaching pan to mechanism. Use magnitized P0 screwdriver here. 3) Remove 4 rubber feet, and four P1 screws under them. 4) Opposite side of display from the button is the black battery case. Use P0 screwdriver to remove three screws. Replace battery. 5) Put back together...
Don't mess with the mechanism inside (at least not if you want a calibrated scale) any more than you have to while changing the battery.
Jul 04, 2012 | Health & Beauty
Garmin watch battery replacement
The Forerunner 50 uses a coin cell battery (CR2032).
Any watch repair shop can change the battery.
Also, contact Garmin Tech Support for assistance.
1-800-800-1020
Mar 26, 2012 | Garmin Forerunner 50
What type of CMOS battery should I buy for HP compaq - d/530s/P2.66/40bc/512E/4UK?
Being a desktop, take the side off and take a look. They are usually 2032 or 2016 button style Lithium Ion.
They can be purchased from most Jewelers, and Hardware type stores.
Feb 17, 2011 | HP Compaq d530 SFF PC Desktop
Health & Beauty Logo
1,069 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
