Question about Greenworks 1700 PSI 1.4 GPM Electric Pressure Washer 51012
How to get detergent to feed into Greenworks 1700 psi washer
Pressure washer works well but liquid does not feed
    Sergeant:
  • 159 Answers
In addition to the comment above regarding the need to use a low pressure (soap) tip, there's a chance the tanks or the hoses from the tanks to the valve and/or from the valve to the pump is plugged with dried detergent. The easiest way to clean out the hoses, unless you can see the plug with the detergent bottle removed, is to remove the top cover and pull all the hoses and flush them out. Removing the cover is not too bad. There are several recessed screws underneath, including a couple above the wheels that requires removing the wheels and axle.
Posted on Jun 02, 2016
  • 62 Answers
The only way that it will feed detergent is by using the correct nozzle for the detergent. It's a lower pressure tip which allows the valve for the detergent to open. It's the black tip. It's either that or if it's an older one, there is a twisting wand that controls the pressure and spray pattern, which has to be twisted to the widest pattern with lowest pressure
Posted on Nov 10, 2014
Testimonial: "Greenworks rep tells me that my model 51012 does not draw deterg because the feed hose or siphon valve is clogged/damaged. How to clean or repair valve"
  • Jay solan
    Jay solan Nov 12, 2014
    Greenworks rep tells me that my model 51012 does not draw deterg because the feed hoGreenworks rep tells me that my model 51012 does not draw deterg because the feed hose or siphon valve is clogged/damaged. How to clean or repair valve" iphon valve is clogged/damaged. How to clean or repair valve"
I have an electric greenworks 1700 psi pressure washer that starts then stops repeatedly how do ya fix it
Sounds like the thermal switch is shutting it down. It is either bad or something is causing the motor to run too hot.
Jul 30, 2016 | Greenworks 1700 PSI 1.4 GPM Electric...
On page 25 under trouble shooting for greenworks 1700 it states that you can turn nozzle tip to a high or low pressure position. how is that done?
The owners manual was badly written by someone in China whose English is a second language. The output pressure is set at the factory. The only thing the consumer can do is change the spray pattern by changing the nozzle. 0 for pinpoint, 25 for small fan spray pattern, 40 for large fan spray pattern, and Soap for dispersal.
Jul 08, 2016 | Greenworks 1700 PSI 1.4 GPM Electric...
I have a model 51012 washer..I need replacement nozzles. where can I get them? thanks.
Go to their website and check out support. Some outfits will only sell parts thru their "authorized" dealers.
Jul 19, 2015 | Greenworks 1700 PSI 1.4 GPM Electric...
Wiring diagram for replacement motor
Here is a pdf file maybe this will help.
The power cord has three wires there should be a green =ground black hot white neutral.
http://www.greenworkstools.com/uploads/documents/51012_1700PSI_Pressure_Washer_E_Manual.pdf
May 15, 2015 | Greenworks 1700 PSI 1.4 GPM Electric...
How to repair non-functioning detergent bottle
Are you really sure it's not working? Most of these only dispense detergent when the lowest pressure spray head is attached. If that's not the problem then the next most likely thing to check for is a blockage in the tubing that connects your detergent bottle to the main unit. If this was not fully rinsed out after the last time it was used, any residual detergent remaining in the line will often solidify which results in blocking the line. Good luck
Nov 10, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
How to widen nozzle spray width?
Try taking the nozzle apart and cleaning. Could be a small particle in it.
Jun 08, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
I let it freeze
the whole washer :)
sorry but the ice can make large damage in stuff like that. Disasseble it and carefully open your eyes :) look for cracks... It may be a sealing, or a whole pump may be broken...
Apr 16, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
How do you take the hose reel off on a greenworks 1700 psi pressure washer?
There should be a clip that holds it in place, see link.
http://www.ppe-pressure-washer-parts.com/greenworks-51012-pressure-washer-parts
Jan 12, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
Greenworks 1700 PSI 1.4 GPM Electric Pressure Washer 51012 Logo
496 people viewed this question
Top Greenworks Garden Experts
Ed60062
Level 1 Expert
Marc Taylor
richie46
Are you a Greenworks Garden Expert? Answer questions, earn points and help others
