Troubleshooting audio from VSK-4000E, how can we tell the unit is bad?
Poor sound from head phone jack
  • 16 Answers
SOURCE: iRiver headphone jack
By the sound of it, I think your headphone jack might be damaged by "tear and wear". In that case, there's little you can do aside getting it serviced. If its warranty is void or expired already, you MIGHT be able to repair it yourself, if you're handy with soldering iron (and, possibly a hot glue gun). However, that would require quite a precision work, patience and vigilance 'cause you could easily damage other electrical components, either by physical means or by burning them out with excess heat... if you're willing to risk it, that is.
To sum it up: you do need to service it.
Posted on Feb 18, 2008
SOURCE: HP Pavilion dv4000 model audio out jack problem
reinalyn cute 21
Posted on Mar 11, 2008
tgvern
  • 281 Answers
SOURCE: bad front audio jack
In most cases the front jacks are in addition to the rear ones. It's not an either/or situation. If the speakers are connected to the rear jacks (usually green for speakers and pink for mic) and there is no sound, you might have a problem with the onboard sound. Try connecting to the rear jacks with a good set of speakers and try it out. If this doesn't work then we can go from there.
Posted on Dec 31, 2008
SOURCE: Dell DJ 30 head phone jack has a bad conection.
Yeah i just fixed mine. Take out the black plastic on both ends. 4 tiny screws underneath, then 2 small metal ends. You will see the board on both ends.
Take out the battery fron the botton. Then TAKE OUT THE SCROLL BUTTON. After that you take out the board. Looking at the headphone jack, you will see 3 small metal connectors inside the jack. try to bend them a lil towards the inside of the connector. I actually put a very tiny piece of metal between the metal and the black plastic in order to force them out.
I was able to fix it, but in the process i broke the scroll button. If you decide to not fix yours and you want to give me the broken dell dj, let me know, i could use the parts.
Posted on Sep 28, 2009
dragoneyes76
  • 105 Answers
SOURCE: one of the speakers sound really bad when volume
About the speakers, you need to replace them with factory OEM speakers.
The touchpad and the headphone outlet will get hot if the laptop is hot inside. You might want to check the fan for dust and clean it. So the heatfan extracts the heat from inside. Avoid using your laptop on a surface without airflow, such as mattresses or pillows.
Posted on Jul 31, 2011
LG 55LS4500 55 in. TV has sound through speakers, no audio except a hum from headphones and the optical digital to analog output fiber lights up but no sound output What board is bad?
Hi Louis,
The audio circuitry is located in the main board. Try unplugging the TV for a while and try again if the audio comes back.
I would suggest to check all your settings in the audio section first and if everything seems OK then the main board should be replaced.
Feb 26, 2017 | LG 55LS4500 55 Inch 1080p LED LCD HDTV -...
Technics su-g50 amp left speaker cuts out
Make sure you are using the correct size Philips, probably #2 not #1(I have taken apart thousands of pieces of audio equipment and with the correct tool and a little elbow grease...). Then as far as cutting out, check to see if any of the potentiometers(A.K.A.: pots) are scratchy(volume, tone controls, etc) also the RCA jacks and speaker connections. A little WD-40 or fader lube works wonders on dirty pots and jacks Then look internally for poor or cracked solder joints. You can use the back end of a plastic pen to lightly tap components and lightly flex the board to narrow down the bad solder joint or poor internal connection. Do this while playing music or download a Tone Generator app and hook your mobile phone to one of the inputs (i.e. front panel, or CD). Tone generator set to 0.2V @ 1kHz works fine and turn the receiver volume up enough to hear the tone. Then start troubleshooting... Don't forget there is 120 volts AC inside as well as a lower DC voltage that you need to be concerned about and the large filter caps stay charged for normally a short while after being shut off. On newer audio equipment with switching supplies that DC voltage can be in the hundreds of volts but not in your case. Hope this helps!
Sep 30, 2017 | Panasonic Technics Stereo Graphic...
Vsk-1019ah-k wont turn on, light is blinking, disconnected all audio and still wont work. Light blinks and when i turn it on after a minute it shuts off. How can i fix it?
The audio outputs in the surround sound unit are shorted, you will need a professional to see how bad it is to assess for repair.
Mar 28, 2012 | Pioneer VSX1020K Receiver
My denon 3808ci reciver has sound out put when you connect head phones but nothing coming out of the speakers when the head phones are disconnected?
hi,
In all receivers when you connect the headphone it will swich off the speakers. Its normal. When you use the headphone there is no need for external speakers its the principle behind this. .
ok
Sep 09, 2011 | Denon AVR 3808Ci Receiver
Were can i plug my cordless head phone's in?do i need the yellow&red cable's?
You need the audio cable with RED (RIGHT channel) and WHITE (Left channel) RCA plugs at one end, the other end will have to match the Headphone base unit input jack which can be RCA or miniphone jack.
The cordless headphone base unit can get the audio signal from the TV headphone output jack or from the RED and WHITE RCA audio line out on the back of the TV.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 09, 2011 | Televison & Video
I have an lg 32ld350. I plugged in headphones into it as to not annoy anyone with the tv and when i was done i unplugged them and now i have no sound unless i use headphones. Even with them unplugged it...
Turn off ur tv.Tries take the head phone steal jack plug it in and unplug it out do this like three or four times.Tries the tv menu audio resetting again.The audio should return.Don't used ur tv head phone again the input jack socket it have problems,just lower ur tv volume for not to annoy anyone.Or used the tv head phone jack socket again will damage it for good, and will never get sound out throught ur tv speaker again.
Apr 16, 2011 | LG 42PX5D 42 in. Plasma HDTV
I have a earing problem i have tried conecting a no wire head phones to the tv but i cannot get it to work please help thanks
make sure you are connecting your wireless head phone base unit to the audio OUT jacks on your tv. many tv's now have several in/out jacks that all look alike. if your head phones are not stereo, then plug it into the RED audio OUT jack. if still problems, let me know
Feb 03, 2010 | Televison & Video
No sound when i plug in head phones into headset jack, but when head phones are not pluged in i get sound from computers speckers.
Hi jasonbutera,
Follow these troubleshooting steps:
1) plug in your head phones into another headset jack in another computer or port - this verifies whether the head phones are good or not.
If the head phones are good, then we know the sound ports are not good. If the sound ports reseatable than give it a try. If the is an integrated sound port, than there is really nothing you can do other than replace the system board. If your pc is under warranty, by all means take it back to be repaired.
Hope this helps and good luck.
Jul 27, 2008 | Everex Computers & Internet
Audio in
Unfortunately, the "Bus audio in" jacks are only for use with Sony add-on components, like Sony CD changers. Without a Sony component connected to the Bus control jack, the audio input can't be selected. To add an auxiliary input to this head unit, you need to purchase an adapter: http://www.crutchfield.com/S-EMPSKmYtPsH/cgi-bin/ProdView.asp?search=sony+aux&i=127AUXONS
Jun 16, 2007 | Sony CDX-F5500 CD Player
Computers & Internet Logo
David Payne
David Payne
