Question about Jeep 1998 Grand Cherokee Laredo
Will a defective fuel pressure regulator cause an engine to run wide open on a 4.0 jeep 1998
Gas pedal has no effect. when you start the car it runs wide open
    Sergeant:
  • 149 Answers
No, it would have no effect on idle speed. There probably is a large vacuum leak, and that would leave the idle speed uncontrolled and racing.
Posted on Nov 11, 2014
    Sergeant:
  • 406 Answers
No it will not..air to the engine allows for accelerating not more gas..actually they work together..it would an air flow problem have the codes read to see what code come up..one other thing..is your vehicle equipped with a cruse control? Sometimes the linkage to that gets hung up..have someone start the vehicle and turn on tne cruse control and you watch what the linkage does.. Hope that helps good luck..
Posted on Nov 10, 2014
Where is the fuel sensor on a 1997 jeep grand cherokee
Have you checked the fuel filter? I would pull the fuel line apart before the filter to see if the pump is putting gas into the line. With key on, the pump should run for 2 seconds to pressurize the lines and fuel rail. And when the engine is cranking over, the pump should be running constant and putting gas into the line. If gas shoots out, possibly the filter is clogged or the fuel pressure regulator on the fuel rail is defective. If no gas comes out, possibly the pump filter sock is clogged or the pump is defective.
Very unusual for the pump to run and have NO fuel pressure.
Aug 07, 2014 | 1997 Jeep Grand Cherokee
Chevy troubleshooting
Had a s10 one time and had similar problems turned out after I got rid of it a friend figured it out it was the computer and the Catalac converter how ever you spell it hope this helps Merry Christmas
Dec 09, 2017 | Cars & Trucks
1994 jeep wrangler engine missing at mid range
check fuel pressure regulator and fuel pressure. should be between 45-50 psi and hold steady.. shut off car and let sit 5 min if pressure drops more than 10 lbs one of the two is bad...
Jul 07, 2012 | 1998 Jeep Wrangler
Jeep won't run unless you hold down gas pedal? what could be wrong? We have a 2004 grand Cherokee.....we finally got it to start but once we left of the gas pedal it dies. ANy help would be greatly...
its not getting enough fuel to engine. it could be a plugged fuel filter, low fuel pump pressure, or a bad pressure regulator. check the fuel filter first and then go from there. also be sure plugs and wires are ok.
Jan 20, 2011 | 2004 Jeep Grand Cherokee
Car Turned off LIke it Was out of gas...
You should be able to hear the fuel pump running after cranking it enough to build up some oil pressure.
If the pump does run......try adding some fuel.
Aug 18, 2009 | 1983 Ford Ranger
1998 Jeep Grand Cherokee has a rough idle at first
You do have a filter and it's mounted right on top of the pump on outside of tank...it is also the pressure regulator. You really should put a pressure gauge on the fuel system and check it out though. you may find there is a problem elsewhere. Good and proper testing is the only way to get answers about problems especially now that systems are all electronically controlled.
Jul 10, 2009 | 1998 Jeep Grand Cherokee
Car will start and engine will run but will not stay idling
fuel filter, tps sensor, maf sensor or fuel pressure regulator
Apr 21, 2009 | 1996 Jeep Grand Cherokee
1999 jeep c. 4.0 litre engine. Fuel drips from muffler wont start
How is this car running? Remove the vacuum line from the pressure regulator on the fuel rail and check to see if there is any gas coming out of the line. If you see gas then the regulator is bad.
Dec 13, 2008 | 1999 Jeep Cherokee 4WD
1998 Nissan Maxima
You may have a problem with the check valve in the fuel pump, if this valve is defective the gas drains back to the fuel tank and causes long crank times, you can test this by hooking up a fuel pressure guage at the fuel injector fuel supply line on the top of the engine, run the engine for a moment and quickly record the pressure when you shut down, that pressure reading should not drop more than 5 PSI overnight, if the check valve is bad the pressure will most likely start to drop right away, but do the over night test anyway. If this is the problem you will need to replace the fuel pump in the gas tank.
Nov 03, 2008 | 1995 Nissan Maxima
Jeep 1998 Grand Cherokee Laredo Logo
81 people viewed this question
Top Jeep Toys Experts
Glenn Smart
Glenn Smart
 Brian Main
Brian Main
Are you a Jeep Toy Expert? Answer questions, earn points and help others
