Question about Car Audio & Video
My 2002 mazda mvp ausio system is not working but
My 2002 mazda mvp ausio system is not working but I can insert and eject the CD but cannot do the in tape cassette also the display is not showing the clock or any thing plz any one tell me whats wrong with it. Thankyou
    New Friend:
  • 66 Answers
Internal board damage. Also the ribbon cable for the soft load on the cassette is not engaging. This can happen due to just ware from the age of the unit. Cold solder joints are usually the culprit, that is why the display will not light. Check yards for a newer used deck it just might be easier unless you have a shop you can send it to.
Posted on Nov 10, 2014
5 Suggested Answers
SOURCE: Message reads eject. won't eject
My camera did the exact same thing. I called Canon tech support and they advised to unplug power cord, remove large main battery, and remove smallbackup battery. The small back up battery is under a small door under the main backup battery. With everything disconnected, turn camera to "camera" and then to "vcr" and then to off. Wait a few seconds. Put everything back together and try to eject again. The tech said that resets all the mechanical parts. However, it did not work for me. They now want me to send it to them for a paid repair. I have done some research on the internet and this is a VERY commom problem and it usually costs about $150 to correct via Cannon. Many times the problem occurs again. I am very very frustrated. I pulled my camera out last night to get it ready as my wife is 9months into her pregnancy. Now, I have to send my camera away for 5-9 days. Really really upset.
Posted on May 29, 2007
ctf1800
  • 4402 Answers
SOURCE: inserted cassete in wrong way in Sony camcorder CCDTRV68, not ejecting cassette Error codeC32:20
Sony camcorders C:31:23 error
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Posted on Mar 17, 2008
SOURCE: Tape wont play or eject.
i just read about this c:31:22 problem while looking for a solution to another problem I am having. Someone suggested removing the battery, switching the camera to the "camera" setting, and then turn it off, put the batter back in and it should work. Good luck.
Posted on Jun 16, 2008
  • 3 Answers
SOURCE: will not accept cassette - keeps responding "eject cassette"
Had the same problem and took the battery out of the camera to reset. Worked fine after that.
Posted on Apr 11, 2009
Cassette stuck in the dash. eject button will not eject the cassette
You should take the tape deck out of the dash. Most aftermarket ones have two pairs of holes that you can insert long nails into to disconnect it from the dash. Unplug all the wires and open it up. It has probably eaten the tape and you will have to cut it and pull the strands off the capstan to get the cassette housing out. A pair of forceps, tweezers, and wooden handled cotton swaps and rubbing alcohol are helpful for cleaning and removing the strands of broken 3 7/8 ips tape.
Mar 04, 2015 | Chrysler 2002 Concorde LXi
1990 lexus ls400 cassette player will not read or play my cassetes. i put in my cassettes but my front tape flap doesn't close and it automatically switches back to the radio.
The player has to seize the cassette as it is inserted and seat it in the correct position to be played. Sometimes the manual eject linkage becomes defective or misadjusted, preventing the cassette from seating correctly. The eject button may depress fully without causing ejection or it may depress but not cause ejection.
Dec 03, 2013 | Nakamichi 90 94 Lexus Cassette Tape Radio...
Handy cam hi8 dcr
Try removing the battery and charging it. Then put the battery back on the camera. This will reset the cassette system. The cassette should open or close depending upon what status it is in. Once you get the camera to eject fully, clean your heads with a dry head cleaner cassette for Hi8 video. If your camera is still eating tape, could be a broken pin or damaged heads.
Aug 26, 2013 | Sony Handycam DCR-TRV280 Digital Camcorder
2001 Tahoe cassette tape cleaning
I think you need to remove the unit and have it repaired, it is faulty.
Jun 07, 2017 | 2001 Chevrolet Tahoe
Tape stuck in player - error code e13 shows
I just got a tape unstuck myself. Everytime I would hit eject it would make a clicking noise.
Here is what I did:
First I watched these videos to remove the radio.
http://www.youtube.com/watch?v=29MTa4FLjtk&feature=channel
http://www.youtube.com/watch?v=fqvk_PNo9Kg&feature=channel
Then I unscrewed the bottom panel of the radio.
Unscrew the brass screws holding in the cassette player portion of the radio.
Now flip the cassette player over to see your tape, etc.
When I pressed the eject button, I noticed a little motor with a worm gear would move a a gear which moved several other gears until it eventually moved a black gear which has a little post that moves the metal arm which moves back when pushing in a tape and moves forward when ejecting a tape. But I would get a clicking sound which seemed to be due to one gear trying to move a stuck gear.
I forgot the exact details of how I managed to get the tape out, but when I did get it out I noticed when I turned on the radio, it would act like it was trying to play a tape. But when it found out it couldn't, it would try to eject but would fail once again with the gear clicking sound.
I think I tried moving the black post on the black gear that moves the arm that pushes the tape out. Eventually I got to the point where the arm was pushed forward like it should be when a tape is ejected. At that point I was able to insert and eject a tape without any problems.
Mar 22, 2009 | 1998 Buick LeSabre
Tascam DA 40 DAT Machine ." Loading error "
The DAT machine needs new belts and maybe some cleaning. These fail all the time due to old belts that lose the tension that is required.
Dec 10, 2008 | Tascam 122MKIII Single Dual Cassette Deck
Honda Radio button lights do not illuminate
were the lights working before?
sounds like a defective radio.
Nov 23, 2008 | 2002 Honda Accord
My Camcoder says eject the cassette
Use a Sony head cleaning tape they work perfectly and you let them run there 10 second corse. Then your sharp will run perfectly...
Dec 20, 2007 | Sharp Viewcam VL-Z7U Mini DV Digital...
Cassette player connection
hi there, you just have to make sure that you're cassette deck is clean..then try it...if it won't work, you have to buy a new cassette adapter..i can assure u it'll definitely work..
Dec 03, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
Car Audio & Video Logo
52 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
