Question about Canon PIXMA MX310 All-In-One Printer
I just change the phone on my cannon mx310 but cannot get a dialing tone on phone
Changed to a cordless BT phone but no dialing tone from phone
  • 88 Answers
I would check with your phone service provider to check for any fault on the line . I had the same problem with my phone and it was a fault with line . It was alright a couple of days later . The bt engineering team discovered it was a fault underground
Posted on Nov 10, 2014
barrie_b
  • 14 Answers
SOURCE: how can i make phone calls on canon mx310?
Are you sure the phone cable is in the right jack? Look for the icons beside the 2 jacks - the one that looks like a phone connects to the phone. You should also apply Canon's firware update at http://www.canon.com and search for fumx310swin1040en.exe if you have Windows or for an iMac the file is MX310 series Firmware Upgrade Utility Ver. 1.040 (Mac OS X) with a file name of fumx310sosx1040en.dmg
Too bad Canon can't be bothered to email it's registered users to notify them that the machine they sold us was shipped with defective firmware and attach the fix to the message to save us from hunting for the solution.
Posted on Jul 18, 2008
  • 417 Answers
SOURCE: i need to dial zero before i get dial tone cannon MX700 cant send fax ???
You can set dial preferences in fax options using the 0 for the switchboard.
Posted on Nov 04, 2008
  • 479 Answers
SOURCE: Canon MX310 just set up - phone rings like incoming fax
check out the connection some where loose or also check out connecting the external phone line to the printer and whether the same problem occurs or not.
Posted on Dec 10, 2008
  • 191 Answers
SOURCE: How to change the ink catridges in cannon MX310
please your open the printer head couver and you there ink catridge
and out of printer and add ther in place in printer and close the printercouver
Posted on Sep 14, 2009
canontech
  • 1219 Answers
SOURCE: canon mx310
Did you connected the line at "L" slot or try with your phone operator to check your tel. lines
Posted on Jan 12, 2010
Both phones have no dial tone and don't work - could it be because they don't support digital?
Hi, Welcome to FixYa.
The cordless phones supports pulse dialing than tone now a days.
If your provider supports pulse dialing & tone you can just change the tone to pulse to use cordless phone. Otherwise you have to request for pulse dialing from your provider.
We appreciate your feedback; it will help us improve this Web site.
Please select 'YES' if satisfied.
Jul 08, 2009 | Panasonic KX-TG2352 Cordless Phone
GE 900 Mgz cordless phone, model 26936GE2-C
How many handsets do you have on this system? Just the one for the base unit?
May 21, 2008 | Uniden Cordless Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Can't change to pulse dialing
The Vetech phone will only support tone dialing. It does have a menu option that turns tone on or off but it still will not allow pulse dialing. I had to change the phone service from pulse dialing to tone dialing to get the phones to work. As it turned out, the phone company no longer charges extra for the tone service.
May 11, 2009 | Uniden Cordless Phone
No dial tone
no dial tone. the handset shows "searching".
Nov 08, 2008 | Uniden Cordless Phone
BT Studio 1000 4 handsets
To Mrs Sue Groom,
You probably need to register the handsets to the base.This is the user manual for the BT Studio 1500
http://www.shop.bt.com/content/uni2/documentation/43py/023626.pdf
Mar 21, 2008 | Xact Communication XG2200 Cordless Phone
GE cordless model 26928GE2-A
Dial tone is OK, but can't dial out
• Make sure the tone/pulse setting is programmed
correctly.
TONE/PULSE DIALING
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
Feb 06, 2008 | GE Cordless Phone 900 MHz
Ringtone
Here are the instructions for changing ring tones for the BT Freestyle 2200 Cordless Phone.7bb89b5.jpg
Oct 25, 2007 | British Telecom Freestyle 2200 Trio...
Cordless phone
press menu then globel setup and then press dial mode then change the the dial tone you want
Oct 19, 2007 | Uniden DECT 6.0 Cordless Telephone...
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Canon PIXMA MX310 All-In-One Printer Logo
51 people viewed this question
old marine
old marine
