I have an element tv that is not turning on. It is about 5-6 years old, never had any problems till now. Would it be worth getting the part it may need to fix, and where can I get it?
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Nov 11, 2014
premtech
  • 934 Answers
SOURCE: dark picture and green tint
Most TVs of that caliber have a life expectancy of about ten years.. In 2009 we'll be passing into the HD era and that Tv won't work without a little help from an HD converter. What you're describing sounds like some transistor problems on the crt board and possibly voltage regulation. Not too expensive for a reputable shop, but my best advice would be to get an estimate first. If you need help finding a reputable shop contact NESDA, (National Electronic Service Dealer's Assn.) they should be able to direct you to a member's shop in your area. Its like going to the AMA to find a doctor. If the cost is more than half the cost of buying new - get a new one... Good Luck Bill
Posted on Jun 03, 2007
Vrya
  • 62 Answers
SOURCE: Sony Wega wont go on
Hii....
When the " SONY Bliking Codes " generated the circuits self diagnostic to trigger the pulse because some error accure....5 times blinking mean there's something wrong whit RGB level,the level not balance after 2 second due at first time the tv on...the protection circuit will send the error report,the tv will have no picture or sound....you will need to check at M board there's much things you have to do...
Thanks
[Vrya]
Posted on Mar 22, 2008
  • 4234 Answers
SOURCE: 22 year old 20" Mitsubishi TV
The problem with sets of this vintage is parts. There are a number of possible reasons for the loss of color. Some are simple and parts are still available, others are not. Considering the labor cost for any TV repair these days, I'd say that you got your money's worth out of this set and invest in a new one. If you'd like, post the model number and maybe I can get you the probable defective parts along with their replacement costs.
Dan
Posted on Sep 09, 2008
ladywinn
  • 5138 Answers
SOURCE: I get a red screen on my rca d52w15 tv. It is only 3 years old.
Have you took back off to see if all 3 of the tubes are lighting up R-G-B Tubes? These sets Sold for $1,000.00 and up.
Posted on Dec 28, 2008
robotek
  • 1512 Answers
SOURCE: my piture is getting smaller and my color is gone
Hi Jwalden
The picture shrinking is an indicator the the regulated HT power supply rail is going low in voltage resulting in EHT supply for the tube doing the same. . This will relate to component failure in the power supply itself, probably capacitors. It will progress, and eventually the set will stop. To be totally honest with you, it could run to $180-250 to overhaul the power supply and a few other areas of concern in a set this age. They were always a little on the "cheap build" side to begin with, so I would not recommend you spend anything on it, your money would be better put towards a new one. I know that this does not fix your problem, but is advice from a TV tech that knows. Thanks for using FixYa. I am happy to answer any other questions you may have. A FixYa rating of this advice to you is a great reward for the time I have taken to address it with you. Cheers regards rbotek
Posted on Jan 22, 2009
I have an element elchs261 tv that is not turning on. It is about 5-6 years old, never had any problems before this. Would it be worth fixing?
Sorry, No. It is usually a turn on circuit. Check to see if it has a reset button on the back somewhere, you might get lucky and it had a power surge and automatically took it off line to protect the boards. If it does, just reset it.
Nov 10, 2014 | Televison & Video
Bad picture until tv warms up
well its a problem fo an ic causing the issue that needs to be replaced
May 30, 2008 | Toshiba 57HX81 57" Rear Projection...
I have a 8 years old apex tv. while watching tv the picture went out but it still has sound. i can't see the channel numbers or volue bar is it worth fixing
I WOULD SAY NO ! THE PICTURE TUBE IS PROBABLY AS MUCH AS THE TV IS WORTH. i had a very nice sony trinatron tv. the picture tube whent on it at about 5 years so I CALLED FOR REPAIR AND THE PICTURE TUBE WAS 2-300 DOLLARS. good-day !
Jan 20, 2012 | Apex Digital Televison & Video
My Sony KDL 46XBR4 when first turned on has vertical lines, or sometimes very dark picture for about half an hour, then the picture clears up fine, as long as I keep the tv on. Now, it is dark, almost...
That is correct. Sony has extended their warranty on panels for this model until Oct. 31st 2012. Just give Sony a call or simply take your set to an authorized service center and you will get your set fixed for free.
May 19, 2011 | Sony KDL-46XBR4 46 in. LCD Television
Is 9 year old Fujitsu Plasmavision TV worth fixing?
Hi
Can i please know yout TV model number to assist you better.
Thanx
Jul 22, 2010 | Fujitsu Plasmavision 42" TV
Ice forming on freezer back wall of 6 year old top
u have a defrost problem unplug for 4 or 5 hrs with door open will work like new till u can get a tech out to replace parts
Mar 17, 2009 | Kenmore 18.9 cu. ft. Top Mount...
Sound but no picture
Hello Dabizot,
With the price of the new tv's, I would recommend getting a new tv. It's only a 19" and you can get a flat panel 19" for less than $ 200.00 It may cost you $ 100 plus to get it repaired along with any new parts. If you want to spend less money try looking at the yard sales, people are always selling used TV's for cheap.
Nov 16, 2008 | Neovo AG AG-01 TV Tuner Picture Frame...
Rear screen tv
replaced flyback transformer
Sep 17, 2008 | RCA F36650 36" TV
Pioneer elite pro 118
if the tv is more than 10 years old no its not worth replacing the power supply.if its 5 years or newer yes it owuld be worth the money
Jul 17, 2008 | Pioneer PRO-200 60" Rear Projection...
Tv troubleshooting
5 years old toshiba tv is not that old as per reputation of toshiba. it is not a big problem. it might be due to power supply some part must be defective. it can be fixed easily. But if you want latest feature& digital quality picture go for new one.
Sep 15, 2007 | Toshiba 30HFX85 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
