Question about Water Heaters
<!-- from fixya rte -->HOW DO I DRAIN THE WATER HEATER - Water Heaters
    Master:
  • 467 Answers
There is a valve at the bottom that looks like a hose connection. Turn off the Electricity or Gas to the Water Heater!! Turn off the water supply to the Water Heater. Hook a hose to the Valve, run the house outside, Open the valve.
Or
Posted on Nov 10, 2014
How do I drain the water tank
Anon, Make sure gas or breaker(power) is turned off to the Heater so it will not come on during draining,connect a hose onto bottom valve of water heater, run hose to a floor drain and insert, turn your water main off so as not to fill tank while draining, open water heater drain valve, water will then drain from attached hose into floor drain until empty. For water to run faster you may open a near by hot water tap, this will allow air into tank as you drain it, do not forget to turn this tap off before refilling tank. You then can turn main back on for a bit if you would like to do a flush of sediment from the bottom of tank.
See links below for more instruction and video.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Drain Water Heater Today Homeowner
How to drain water heater
http://www.bobvila.com/articles/how-to-drain-a-water-heater/#.VxqJ6NQrJxA
Apr 22, 2016 | Water Water Heaters
How do i drain a water heater
What kind of water heater do you have?
Tank, tankless, under-counter, portable, solar?
If you have ordinary tank-type water heater, then open drain tap at bottom of heater.
Be aware also that older heaters, the drain valve will possibly leak afterwards and you will need a garden hose cap over the valve.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Sep 01, 2012 | Water Heaters
I have a Richmond model 8MV50-2B. I'm having issues draining the tank to check the electrodes. Normally, on a water heater there is a shutoff down near where you attach the garden hose to drain the...
Problem is not clear.
Is water heater clogged and not draining?
What kind of shut off is normally located down near drain valve on electric water heater?
If you have gas heater, you can normally just rotate knob to pilot to shut off burner.
If you are draining electric water heater, normally you turn off circuit breaker, attach garden hose to drain valve, open drain valve by turning counterclockwise, open TP valve or open bathtub faucet, and then water drains out.
Open following links for illustrations.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Aug 13, 2011 | Water Heaters
I just noticed that my hot water heater that is 6 years old is dripping very slowly from the bottom faucet, how can i stop this leak. thank you.
If you mean the drain valve, then buy garden hose cap at home center.
Cap will have rubber washer that seals tank.
If drain valve is plastic, the cap may not thread on without sanding down end of plastic drain valve.
Otherwise replace drain valve, which is simple if drain valve is brass, but can be difficult if drain valve is plastic.
Turn off power to water heater: Electric: turn off circuit breaker. Gas: turn knob to pilot.
Turn off water, open bathtub spigot on Hot side, drain water heater, remove drain valve with wrench.
If plastic drain valve breaks while being removed, then 'gently' break out broken part using hammer and big screwdriver.
Buy new drain valve at box store in water heater department.
Put teflon tape on new drain valve threads.
http://waterheatertimer.org/Water-heater-is-leaking.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 06, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water heater drain valve leaks
You have two choices. First make sure you are dealing with the drain valve and not the temperature and pressure relief valve. Then you can either cap the drain valve with a garden hose cap or you can drain the water heater and replace the drain valve - if you chose replace make sure you get a water heater drain valve (3/4" MPT).
Please rate my answer!
Mar 18, 2009 | Fasco Bradford White Hot Water Heater...
Water Heaters Logo
46 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
