Question about Vehicle Parts & Accessories
My jeep was just in a wreck where someone t-boned the front right side. The wheel was ripped off and majore damage happened to the area under the hood. The car is totalled because of how old the jeep
Jeep grand cherokee collision repair
  • 62 Answers
I don't see a question here...
Posted on Nov 10, 2014
I have a leak by the front passenger side. I checked my break fluid and it is low, how can i tell if i have a leak?
clean the area real well fill brake fluid to level.pump brakes check the leak to see where its coming from
Dec 10, 2010 | 2000 Jeep Grand Cherokee
How do I replace spark plugs on the back or right side of the engine?
There are two ways to replacing the 3 rear spark plugs.
1. You can remove the two dog bone engine mount in front of the engine bay and tilt the engine forward, so you can reach the spark plugs over the top of the engine with extension and swivel with the ratchet.
2. You can jack up the front end up and go from the bottom of the van. Your going to also need to use extension and a swivel with the ratchet and have to work by feeling your way around.
Careful not to damage the spark plug wires if your not going to replace them.
Good luck and be safe, the easiest way for you to tilt the engine forward is to place the transmission in park and place the parking brakes on with a block in front and behind the back wheels. Disconnect the dog bone engine mount, remove the block from the front of the back wheels. Take the parking brakes off and push the Montana forward and this will tilt the engine forward. Once tilted, place the parking brakes back on and relocate the block to the back wheels.
Follow the instructions in revers to connect the bog bone once again and be safe, better that you have someone help you tilt the engine if your going to do the #1 method.
Thank you for using fixya
Oct 10, 2010 | 2002 Pontiac Montana
Chrysler 2000 what happens if ball bearing is not fixed drive with a humming sound
if front wheel bearing worst wheel falls off and rips out one side of front brakes and some suspension parts--wheel collapses into fender and front end damage --wheel seizes damaging spindle if driving put car into skid the longer any part is allowed to operate while damaged usually will break and cause more damage
Jan 25, 2010 | 1996 Dodge Intrepid
2001 and 2002 jeep grand cherokee. while making hard left hand turn experience rumbling sound doesnt happen when driving straight or right turns. Cant decide if sound is from front or rear area
Try checking the bearing in the left wheel if the rumbling is on the left side. Sometimes bearings can be worn down and sometimes may even twist or bend.
Aug 21, 2009 | Jeep Grand Cherokee Cars & Trucks
Coilapse of left front wheel suspension, 2006 Jeep Compass
Photograph everything and find exactly what came apart. Likely the brake hose was torn out when it came apart so that's secondary damage. When replacing a bearing hub, it's necessary to remove brake assembly and are working in the area where you have the problem but without seeing exacacly what happened, I can't think of anything further to tell you. Get an outside opinion on the cause from someone who can actually look it over.
Glad that did not happen while going down the road!!
Jul 19, 2009 | 2006 Jeep Compass
Scratched front bumber
Get it fixed by the other parties insurers. It will and should not cost you a cent. Failing that there are several non insured loss recoverers out there. Just search online.
Jun 09, 2009 | 2001 Jeep Grand Cherokee
Is it worth my deductible
It maybe if you plan on keeping the truck,there is obvious mechanical damage to the front end weather it's minor to major I can't tell you,it may be a bent tie rod or bent wheel or the frame may be bent,either way driving the truck in this condition will damage the brakes(not the one already damaged)steering and prematurely wear your tires at the very least and could cause major damage to the rear axle,you need to get some estimates and compare them to the deductible,because it may cost just a couple of hundred to repair the mechanical problems or it could cost a couple thousand just to do the mechanical,add at least a thousand more for the body damage.Your truck books at about $3800 to $4500 with all options,but factor in the economy and It's possible the insurance may call it a total loss also,Hope this info helps.
Jun 01, 2009 | 1999 Ford Ranger SuperCab
Noise from front end more so when you are turning
You also could have received a bad axle. Sometimes the rebuilds don't hold good tolerance and can make the same noise you are trying to get rid of. Is it full-time 4wd? Maybe the driveshaft ujoint also.
May 19, 2009 | 1998 Jeep Grand Cherokee
Noise from front end when turning
This is your front hub assenbly.
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
