Question about Michael Kors Womens Watch 5187
How do I buy extra links for MK 5187 watch?
Need to find two extra links and pins
Where can i buy extra links for Rotary watch,serial number 4577
Any local jeweler can supply or order the links for you.
Oct 17, 2016 | Rotary Watches
Michael kors watch band adjustment
I need to buy an extra links for MK watch... Please where can I get ir
Feb 21, 2012 | Watches
I need extra links for the Nixon 42-20 crystal bezel chrono. The watch is too small.
I have looked at the Nixon site and it says that spare links are provided in the bottom of the box, see below.
Do you still have the presentation box?
"The compartment at the bottom rear of the watch stand can be opened and closed, and it contains the user manual and extra links and pins."
Apr 07, 2011 | Nixon Watches
Shorten the length of a Kenneth Cole "New York" watch band
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
Jan 19, 2011 | Watches
Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    http://www.pulsarwatches.com/home2.asp#FAQ
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    Purchase a link for a fossil link type watchband.don't have link
    My experience with Fossil has been poor customer service support for the items they sell. I could even get a flat normal crystal replaced. You can call and wait for customer service. You can also buy another one of the same model on Ebay and use the proper tools to cannibalize the links from another of the same model. You will need pin pusher tools to remove the links and replace them. Do a Google search on watch link removal to learn how this is done.
    Dec 03, 2008 | Watches
    Watch band links.
    you would have to either have custom links made or buy a whole new band to be made the links pop out by pins and then shortened placed this way back together
    but if you dont have extra links buying longer band is your better sollution cause creating a link or 2 to fits can be costly
    Jun 10, 2008 | Seiko SXGL61 Wrist Watch
    Remove the extra links in a luminox 3204 watch band
    It was nothing more than split pins holding the links together. I pushed them out removed the links and pushed them back in.
    May 12, 2008 | Luminox Navy Seal Dive 3204 Wrist Watch
    Michael Kors Womens Watch 5187 Logo
    Top Michael Kors Watches Experts
    Ansel Alberto
    Ansel Alberto
    ray gallant
    Are you a Michael Kors Watch Expert? Answer questions, earn points and help others
